Question about Samsung LA32B450 32 in. TV
Tv volume turns itself Up as well as Down and also changes channels
My T.V. Turns itself up when we turn it on, I changed the batteries in the remote and still had this issue, I then tried to turn the volume down via the button down the right hand side of the T.V. (if you are looking at the screen)and this changed the channel even though I was pushing the Volume Down Button. The T.V. also turns itself down all on it's own, we can watch DVD's with out any of these problems occurring but once we go back to T.V. mode it happens again. This is very aggravating not to mention noisy for my neighbours and sister living upstairs from me. Any help would be greatly appreciated. Thanks Wendy
  • 9 Answers
SOURCE: Plasma-No picture
Main logic board $124 fixed mine email me rudog3369@yahoo.com!!!
Posted on Apr 30, 2008
Enquiry
  • 152 Answers
SOURCE: Speaker Noise when volume turned down LTN226W Samsung
this is due to leakages in your internal circuit... this generally happens due to aging... the part which has suffered damage has to be found and replaced... but this part can be identified only physically testing the voltages and currents on the internal circuit...
Posted on Nov 09, 2008
SkyGuy08
  • 27 Answers
SOURCE: Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Posted on Apr 04, 2009
CAYPIANAN
  • 227 Answers
SOURCE: Samsung LCD TV LT-P2045U power issues
yes my friend check the capacitors in the power supply. some techs call them pregnant capacitors
open the set carefully and check the power supply.always remember to unplug the set before you do anything.
Posted on May 12, 2009
tcobiz
  • 35 Answers
SOURCE: cox universal remote won't control samsung tv ln52a650 volume
This is a tough one, I can come up with possibly 2 solutions, 1 being that if the batteries are low you will sometimes lose partial control of some of the functions on the remote, and if that is not it, then I have another that this one happened to me once, The infrared on the TV was not picking up the volume button I was sitting at an angle, so everytime i sit in that chair everything works but the voulume control i have to point it right at it on direct line and not from the side...Hope this helps...Steve
Posted on Jun 13, 2009
I have a tv that turns off if I try to change the volume.,it restarts by itself 5 minutes later. It happens from either of 2 remotes and the volume button on the tv. Any idea what I should replace?
power fault the drain on changing channel which is around 3 volts is draining the tv a weak capacitor is probably the problem. to add to if you turn the volume up it will probably jump up and down on sound.
Jun 30, 2017 | Televison & Video
Can not turn off and volume turns down by it self changed batteries in remote
Need more info to assist you with the issue. Does the tv work except the volume turns down by itself even with the batteries removed from the remote? If so its either the Tact switch for the vol down has an issue or the main board has an issue. If the remote wont work the tv properly either or not at all too then i would say the main board is causing both conditions. If you require further assistance please let me know.
Jan 01, 2013 | Samsung 50 in. Plasma TV
Toshiba 32AF44. While watching a baseball game yesterday, the volume bar appeared by itself and scrolled down to zero. The bar will not disappear. It's like someone is holding the down button. Tried...
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Mar 04, 2017 | Toshiba 32AF44 32" TV
Remote fall on floor and now it is stuck on one channel and I can not turn off the TV or change a channel or lower the volume
Hi, well you can do everything from the axtual TV itself, have a look on the TV you will find a setof buttons/keys. these allow you to controll almost everything that the remote can do.
here you can change channel change volume etc.
The buttons usually there are 6- 7 marked On/Off, Channel up/down, Volume Up/Down, Enter/OK & Menu. Now pressing these will bring up the onscreen display and you can adjust what you wish.
Now with the remote, it's probably best to obtain a new one..
Sometimes disassembly may fix it, but it sounds like it has a bad problem.
To ensure it doesn't interfere remove the batteries.
Aug 19, 2010 | Televison & Video
Why does my 26 insignia do the following without touching the remote: volume up and down, changes channels and menu screen pops up
It could well be your remote control has a problem. Try removing the batteries from the remote control and see if the problem goes away, if it does, try new bateries on the remote controller, if that does not work you may have to get a new remote controller
Mar 24, 2010 | Insignia LCDTV26 26 in. Television
Television turns on and off, turns up volume and changes channels
Hi
Replace all tact switches at the control panel... all switches is have bad resistance thats why your system is abnormal!
Thanks!
Feb 24, 2009 | RCA 27V520T 27" TV
MENU SCREEN POPS UP, TV CHANGES CHANNELS, TURNS SOUND DOWN
Yes. Its probably a stuck button on the TV's front panel. Try pushing or wiggling each button on the panel. It could be the channel up/down buttons or volume up/down, menu, etc.
When there is a button that is making slight contact, it keeps the microprocessor busy attending to the command its erroneously receiving from the offending button and may not allow other functions to work when this occurs.
It doesn't matter which button is stuck, any of the symptoms you describe can happen.
michtech
Feb 17, 2009 | RCA P52926 52" Rear Projection Television
TV Volume turns down by itself - Philips 29PT8319 Matchline 27"
Most likely the volume down button on the front of the TV or the switch that it activates is sticking. Should be an easy fix otherwise.
Feb 05, 2007 | Philips 27PT8320 27" TV
Samsung LA32B450 32 in. TV Logo
20 people viewed this question
Jerry Greenberg
Jerry Greenberg
