Question about Canon Powershot Sx150 Is 14.1 Mp Digital Camera black 5664b001 Sx-150
I have canon sx 150is and want to fix an adapter for filter and lenses
Want adapter rings and holder for lens and uv filters for canon sx 150is
    Sergeant:
  • Canon Expert
  • 488 Answers
Try looking on the web site for Premier Inks in the photography accessories section
Posted on Dec 27, 2014
3 Suggested Answers
cammedic
  • 667 Answers
SOURCE: Broken ring around 75-300 zoom lense
Hi Pamela,
You can order directly from Canon USA,
Canon's info: To order an internal replacement part, please call 1-800-828-4040. The hours of operation are 9:00 A.M. to 8:00 P.M. EST from Monday to Friday. When calling, speak the term "order parts" when the speech routing system asks the reason for your call. You will immediately be routed to the Parts Desk for assistance.
Posted on Jan 30, 2008
old marine
  • 2147 Answers
SOURCE: Filters
If it is the EF-S 18-55 mm lens, the filter diameter is 58 mm.
Posted on Apr 18, 2008
Uv filter stuck
Sometime the filter gets screwed on too tight. If you can't remove it there is a tool available that grips the outside of the filter tight and allows you to unscrew it. Google filter tool. Remember...Lefty loosey Righty tighty.
Jan 18, 2014 | Canon 58mm Uv Filter Lens For 18-55mm 50mm...
Will the Quantaray 49mm to 55mm step up ring work on a Sony a100 DSLR camera
The step-up ring will on any lens with a 49mm filter thread, regardless of the manufacturer. The easiest way to find out whether it works with any given lens is to see whether the ring fits onto the front of the lens (you could also read the filter size written on the lens itself).
If it doesn't fit, purchase the appropriate step-up ring. That will be much cheaper than buying a whole new set of filters.
If the new lens(es) have a 55mm filter thread then you don't need the step-up ring at all. The filters will mount directly onto the lens.
Mar 17, 2013 | Cameras
HOW TO PUT Fotodiox 49mm Filter Thread Macro Reverse Mount Adapter Ring for Sony E-series
The ring threads onto the front of any lens with a 49mm filter thread, just like a filter. The front of the lens then fits onto a camera body, effectively mounting the lens "backwards" or reversed. With most lenses, this allows the lens to focus very close, for close-up or "macro" photography.
Mar 14, 2013 | Fotodiox 49mm Filter Thread Macro Reverse...
Dear sirs; What type of uv filter fits a quantarary tech 10 28mm - 200mm zoom lens. I have several 62mm filters and the zoom lens does not accept the normal threaded screw on format common to lenses
First, make sure that the lens diameter is 62mm. It should say on the front or on the body of the lens. If this is correct, it could be a unique mount that would require a specific brand. If it's quantaray, it might require quantaray filters. If it's an old lens, it might require an attachment to the front of the lens that would act as a filter holder for the square filter tiles.
Jun 04, 2012 | Cameras
Will a Vivitar 58 mm UV filter attach to a Nikon d3100 18-55mm lens?
Not directly. The 18-55mm takes 52mm filters. However, you could purchase a 52-58 step-up ring to allow you to adapt the filter to the lens for significantly less money than a 52mm UV filter. One such adapter is http://www.adorama.com/IRXRA5852.html
Aug 03, 2011 | Vivitar Cameras
I have a Canon Power shot S3 . Can I use a Sigma AF-Mf zoom lens 100-300mm to it. If Yes, what type adapter to use.? I also have a 35-80mm canon lens. can this be used ? Thanks.
Your camera is a fixed lens compact model. You cannot fit other lenses to it unless they are specifically designed as supplementary lenses which screw onto the existing lens filter thread.
There are no adaptors you can safely use either, the only ones would be lens reversing rings which are used to mount lenses backwards for ultra close-up macrophotography, but the weight of the lenses you propose on the end of your existing lens would break your camera.
If you wish to use interchangeable lenses then you need to obtain an SLR or an interchangeable lens rangefinder camera.
Oct 03, 2010 | Canon Cameras
Lens adapter needed
Get yourself a step ring, 52mm for you S8000FD, this has a thread on the end and allows filter attachments. I have an S8000FD and have since bought a step up ring, UV filter and Polariser, plus another lens cap which fits on to the end via a pinch mechanism rather than clamping like the one provided by Fuji.
May 23, 2008 | Fuji FinePix S8000fd Digital Camera
Filters
Apr 18, 2008 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
Lens Protection Size!!!
Get a CLA-1 lens tube. It screws into the camera body. The other end accepts 43mm accessories. Put on a 43-49mm step-up ring. Into that screw a 49mm UV filter. (The step-up ring is needed to separate the filter from the extended lens.) Leave the UV filter on at all times. Throw away the lens cap.
Sep 11, 2005 | Olympus Camedia C-3040 Zoom Digital Camera
S7000 Filters
i think most any filter is compatible. Definately you will want a polarizer and possibly a UV for general lens protection. A Gray Grad would be nice I hear. Just make sure to take into consideration any accessory lenses you might be going to purchase before commiting to a specific thread size as you can get step down rings to adapt down but not as good to go up. And you will need an adapter to use screw mount filters. Or look into a Lee filter kit or Cokin kit that would be more adaptable to different lens. usually the guys at a local Jessops can give you some good advice. Have fun
Sep 04, 2005 | Fuji FinePix S7000 Digital Camera
Canon Powershot Sx150 Is 14.1 Mp Digital Camera black 5664b001 Sx-150 Logo
116 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
