Question about Konica Minolta Office Equipment & Supplies
How to adjust color on a Konica C250 - Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,696 Answers
Run the gradation procedure after toning up all four image units, run the registration procedure also
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jan 18, 2016
3 Suggested Answers
  • 12 Answers
SOURCE: How do I get into service mode on a Konica Minolta
hi,
you can get in service mode by pressing: utility counter -> job details ( on lcd) -> stop -> 0 -> 0 -> stop -> 0 -> 1 .
Select "imaging process adjustment", then "graduation adjustment.
The copier prints a coloured sheet, you have to place it to the glass and the machine will read it.
Repeat sequenze 4/5 times. You have to make it in all three section " graduation mode" "resolution mode" and " i'm not remeber".
You can find clear information about graduation adjustment in a installation manual procedure.
Contact me, i can give you a pdf file.
Sorry for my bad english.
Bye.
Posted on May 15, 2009
taminol
  • 62 Answers
SOURCE: Hi In our office Konica Minolta C250 ,it show message mulfunction. error:- c0206
C-0206 relates to tray 3.
With the copier turned on do the following
Open paper tray 3, remove paper, close tray, open then shut front door, load paper into tray 3 - hey presto!!
If the fault comes back you could have paper stuck behind the tray or have a defective lift up motor.
Regards
Taminol
Posted on May 27, 2009
Misfeed detected after replacing atdc sensor
For which color did you replace? because you are dealing with a color machine C250 that is part of the image unit so which color??
Jun 24, 2016 | Konica Minolta bizhub C250 All-In-One...
My konica minolta c250 is not ready but displaying warming up for a very long time and it did not ready still yet
Warming up means that the copier is not getting hot enough in fuser section, Secondly during that time certain internal house chores are done by the copier to prepare it for READY TO COPY. Are all the image units and toner cartridge OEM!!!??? second has each image unit and toner properly shaking ensure toner in toner cartridges and developer in the image units is spread evenly across each pull each out. shake side ways to ensure spread evenly, last time toner full was run nd gradation adjustments run ?
Dec 02, 2015 | Konica Minolta Konica Bizhub C250 Color...
KONICA MINOLTA BIZHUB C250 Printed only magenta
Does the demo page do the same? Mite have image control board failure. And electrical storms on a good surge protector not a Ace hardware 19.99 special, of course nothing against Ace Hardware :). Could also be a High Voltage board failure. Meter count page OK print out.
Apr 19, 2015 | Konica Minolta bizhub C250 All-In-One...
Konica C250 has a faded line on the prints. Prints colors well except for the Faded line.
The developer powder needs to be replace. for whatever color that's faded, wont be the drums.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Sep 06, 2014 | Konica Minolta bizhub C250 All-In-One...
Konica C250 color issue
Needs to have a gradation adjustment done through service mode. If that doesn't fix the problem, you will need to replace cyan drum unit.
Feb 16, 2014 | Konica Minolta bizhub Office Equipment &...
What is error p-21 of konica minolta bizhub c250?
P-21: Color regist test pattern failure
1 Wipe clean the surface of the transfer belt with a soft cloth, if it is dirty.
2 Change the image transfer belt unit if the transfer belt is damaged.
3 Change the PH unit.
4 Change PRCB.
run halftone prints from service mode to isolate which color is having an issue.
check all image units
Jan 22, 2013 | Konica Minolta bizhub C250 All-In-One...
P-21 and p-5 error message. and fully cyan color comes.
here is the link
http://www.ebookbay.com/ebook/938/konica-minolta-bizhub-c250-sm
if you have any problem contact me.
Download
Nov 27, 2011 | Konica Minolta bizhub C250 All-In-One...
How do I get into service mode on a Konica Minolta Bizhub C250 copier and how do I adjust the color settings once I am in there?
hi,
Bye.
May 13, 2009 | Konica Minolta Office Equipment & Supplies
ERROR CODE SC45-20 MINOLTA 500
Color registration problem Restart copier and leave the front door open,will bypass the error code page.Press HELP,then press KEY OPERATOR MODE, scroll down to 21 EXECUTE ADJUST OPERATION, select COLOR REGIST AUTO ADJUSTMENT, then press OK, PREVIOUS SCREEN. After adjusting, it will back to normal. If the code number back on again, then it was the transfet belt off alignment. If you know how to pull the transfer back to center position, problem solve, if not, call technician.
Feb 11, 2009 | Konica Minolta bizhub C250 All-In-One...
19 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
