Question about Crafts & Hobbies
Konica c250 Blue is printing purple
  • 214 Answers
SOURCE: Konica Minolta bizhub C250
i think that your fax is not set up right, or maybe the machine is missing admin and machine e-mail address, that can cause too this problem.
Posted on Dec 31, 2007
Kevin Hayes
  • 167 Answers
SOURCE: C250 Waste toner
Actually you are supposed to replace the whole container.
You can order this as part of your service contract just like toner, the cost would be included.
If you are shaking it out, be aware it is VERY flamable in such a fine powdered state.
Posted on Jun 06, 2008
taminol
  • 62 Answers
SOURCE: A blue line , 2mm, appearing at bottom of page.
Hi Info39684,
It sounds like your Cyan imaging unit has gone down.
Have you thought of changing the orientation of your paper from A4 protrait to A4 landscape. If the blue line is at the bottom, changing the orientation should hide the problem. It's not going to fix it, and if you use A3 then you will see the line again. It's just an idea and you could save yourself £250 on a new unit.
Regards
Taminol
Posted on May 26, 2009
taminol
  • 62 Answers
SOURCE: Hi In our office Konica Minolta C250 ,it show message mulfunction. error:- c0206
C-0206 relates to tray 3.
With the copier turned on do the following
Open paper tray 3, remove paper, close tray, open then shut front door, load paper into tray 3 - hey presto!!
If the fault comes back you could have paper stuck behind the tray or have a defective lift up motor.
Regards
Taminol
Posted on May 27, 2009
  • 51 Answers
SOURCE: Konica Minolta - Biz Hub C250
any error code appear
Posted on Aug 31, 2009
Purple not printing correct. it looks blue with a purple streak
Hi Mandy,
Is this is new cartridge that you are using ? Sometimes due to the ink level variations this can happen. Or the printer color / print quality settings need to be checked.
Thanks
Seb
Jun 02, 2015 | Konica Minolta Bizhub C550
KONICA MINOLTA BIZHUB C250 Printed only magenta
Does the demo page do the same? Mite have image control board failure. And electrical storms on a good surge protector not a Ace hardware 19.99 special, of course nothing against Ace Hardware :). Could also be a High Voltage board failure. Meter count page OK print out.
Apr 19, 2015 | Konica Minolta bizhub C250 All-In-One...
Konica C250 color issue
Needs to have a gradation adjustment done through service mode. If that doesn't fix the problem, you will need to replace cyan drum unit.
Feb 16, 2014 | Konica Minolta bizhub Office Equipment &...
Blue printing as purple
that is because of a registration error, the cyan (Blue) is not laying on top of the magenta (red) so you get purple, have a tech come out and check the registration procedure.
Feb 16, 2014 | Konica Minolta Office Equipment & Supplies
Printing printing purple instead of blue
registration error which mean the colors are not laying on top of each other, in this case magenta (red) and Cyan (blue) giving you purple, need to have a tech come out and run regisrtation procedures
My Minolta Bizhub c250 has lines of blue and red going though the images. It also seems to be printing Dark. Is this likely a drum issue or something to do with the fuser or transfer belt?
Open the front cover pull out the Cyan,Magenta,Yellow,Black image unit,clea used a vacum cleaner the copier inside.Open the right cover and remove 2 srews,remove the transfer belt unit and clean the transfer belt cleaning blade and the transfer roller unit located on the right cover.
Feb 01, 2013 | Konica Minolta bizhub Office Equipment &...
KONICA BIZHUB C250 DOCUMENT FEEDER PRINTING ON ANGLE
Clean the feeder paper feed,separator roller with cloth and alcohol.
Colour printing
Hi Alan,
Please ensure that the printer driver is set correctly.
Go to your Printer & Faxes menu, right click the C250, click printing preferences, click the Quality tab and make sure Colour is selected. Apply the changes and bingo!
The above assumes you are using Windows and a PCL driver.
Hope it helps
Regards
Taminol
Mar 05, 2010 | Konica Minolta bizhub C250 All-In-One...
Folding and Stapling a Booklet on Bizhub C250
1)The print driver has two collate buttons and you only need to uncheck the first one (which is the windows driver not the Konica Driver) or
2) Install a new driver
Oct 02, 2009 | Konica Minolta bizhub C250 All-In-One...
Hi Info39684,
Regards
Taminol
May 18, 2009 | Konica Minolta bizhub C250 All-In-One...
Crafts & Hobbies Logo
70 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
