Question about Xerox Phaser 6700Dn - Printer - color - duplex - laser - Legal, A4 -
Duplex not enabled xerox phaser 6700dn - Xerox Phaser 6700Dn - Printer - color - duplex - laser - Legal, A4 -
5 Suggested Answers
SOURCE: Xerox Phaser 8560 Not Duplexing
Check to make sure that "Plain Paper" is selected as the paper type for tray 2 in the printer's internal setup. If it's not set as the default then the printer may think you have labels or some other special media loaded that can't be printed in duplex.
1. Go to the printer.
2. Use the up and down arrow keys to hilight "Paper Tray Setup" on the main menu and push "OK".
3. Use the up and down arrow keys to hilight "Tray 2 Paper Type" and push "OK".
4. Hilight "Plain Paper" and push "OK".
5. Press the return button (the one with the little rounded arrow symbol) to return to the main menu.
That should solve it.
GOOD LUCK!!!!!!
Posted on Mar 18, 2009
  • 141 Answers
SOURCE: It is constantly jamming when we try to do a duplex print
Since duplex doesn't get used a lot, much dust collects in the duplex unit. Remove it and thoroughly clean it by blowing dust off. Look for scraps of paper that might have settled in there.
Posted on Aug 04, 2009
SOURCE: My Xerox Phaser 6250 won't duplex all of a sudden
I don't have an answer, but I can add some detail since I have the same problem (6250 that suddenly won't duplex).
I have a wired network with multiple Vista machines connected and have been duplexing just fine for YEARS with the same PCs and same drivers. One day my wife complained she couldn't duplex and I messed around, updated drivers, rebooted everything, etc. etc. and finally gave up and sent the print job from my laptop where it duplexed just fine.
About a week or so later I noticed that my laptop would no longer duplex either! Once again I updated the drivers, rebooted, tried different settings, etc. etc. but no luck.
I'm pretty convinced that a Windows patch has caused this issue (which is why there is a timing difference between my machines). I've rolled back my system to remove several patches and things seem to work fine again, however I'm not exactly sure which patch causes the problem AND within a few days Microsoft reinstalls the patch automatically.
Unfortunately I'm not confident that Xerox will put much effort into fixing this driver problem since this is not only an "old" printer, but I don't think many people do much duplexing (so there won't be many people yelling for help).
I'll let you know if I find a better work-around or fix.
Posted on Jan 06, 2010
  • 57 Answers
SOURCE: Xerox phaser 7760 saying "non-phaser imaging unit"
There is a snippet on the Xerox website to solve imaging unit recognition problems, link below. http://www.support.xerox.com/support/phaser-7760/downloads/engb.html?operatingSystem=winxp&fileLanguage=en_GB Usually this problem only occurs if the NVRAM has been reset or the engine board has been replaced without backing up the NVRAM. You can download the snippet to your printer through Centreware or by downloading the 'File Downloader' utility from the same page above.
Hope this helps.
Posted on Jan 22, 2011
Duplex copying on xerox phaser 3300mfp
I have the same problem and was told by the telephone helpdesk that the machine cannot copy double-sided to double-side. The duplexing referred to is copying 2 single-sided documents onto one single sheet on both sides....Like whoever does that! This is misleading on Xerox's part . Colin B.
Jul 08, 2012 | Xerox Phaser 3300Mfp/X Mono P/C/F/S 30Ppm...
Xerox Phaser 8550DP printing duplex
are you not able to get even the print menu?
Jul 22, 2008 | Xerox Phaser 8550DP Printer
Xerox Phaser 7760. Set document to print as double sided, and it prints single sided. Printing from Mac. Drivers up to date. Any ideas?
There are a few solutions to this problem.
1. The 7760 does not duplex from the MPT 2. The 7760 will not duplex certain paper types eg. envelope, transparency, labels, thick card stock,special. If your paper type is set to any of these it will default to simplex printing. 3. Conflicts in driver settings will cause the printer to default to simplex printing. 4. From the machine settings, duplex can be enabled or disabled. (Though driver settings should override this).
Hope this helps.
Jan 14, 2011 | Xerox Phaser 7760DN Laser Printer
Can you please tell me how to print double sided? Thanks
Xerox Phaser 8400 does not support double sided prints. You have to have a Duplex Unit for Phaser 8400 part number 097S03177 to be able to print double sided. If you have the duplex unit, on the Print dialog box just click Preferences and under 2-Sided Printing select 2-Sided Print then Apply.
Nov 16, 2010 | Xerox Phaser 8400 Laser Printer
Phaser 5500 will not duplex
its definitely a driver related issue.....download latest driver from www.xerox.com
Nov 09, 2009 | Xerox Phaser 5500/DN Laser Printer
Xerox phaser 6120 not duplex printing since it's wireless network
You have to go to printer properties and look for "optional functions" or something to that effect, and check the option "duplexing unit" or similar.
By default the computer does not know, that your printer has duplex capabilities.
Oct 27, 2009 | Xerox Phaser 8400 Laser Printer
How to set up printer to print double sided. Printer Xerox Phaser 8400
First look at your printer identification.
You can see it in either the display or on the startup or configuration pages.
It must have a "D" in the name for you to be able to do automatic duplexing. i.e. 8400DN or 8400DX . Then you can scroll to printer setup
and select defaults, and then turn on the duplex, or double sided printing.
If yours does not have a "D" i.e. 8400, 8400N then you would need a new sim card to enable the duplex option.
Oct 22, 2009 | Xerox Phaser 8400 Laser Printer
Jul 14, 2009 | Xerox Phaser 4510/B Laser Printer
Dec 11, 2008 | Xerox Phaser 6250DP Laser Printer
Xerox Phaser 6700Dn - Printer - color - duplex - laser - Legal, A4 - Logo
183 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
