Question about Kuppersbusch Dishwashers
Have error 2 reading on Kupper dishwasher - Kuppersbusch Dishwashers
How to turn on my Whirlpool dishwasher? It doesn't turn on. Usually I see what looks like 2:05 Now I just see a read out of 01
Reset the breaker or reach in under the sink and pull the plug on the dishwasher. Wait 10 and plug it back in. Sounds like an error code but that code is not standard on Whirlpool that I can find.
Apr 02, 2017 | Whirlpool Dishwashers
Will the door on a dishwasher cause an error on the machine
yes
if the machine program reads the door open, not locked or door sensor is faulty , it will read an error code
Dec 14, 2016 | Dishwashers
My Frigidaire Stainless steel FFHB2740PS D.D. has an error code that reads 5H. What is wrong?
I appreciate your inquiry, friend!
Based off the information you have provided your Frigidaire dishwasher is displaying an error code of "5H". That appears to be the time remaining on your wash cycle. Typically an error code would be displayed with a number and an "E". What is the current problem with your dishwasher? Are you getting long wash times? There is a sensor inside of your dishwasher that reads how dirty the water is, if your dishwasher continues to circulate dirty water it will tell that sensor to continue washing. You may want to check your filter, which is located at the bottom of the tub, for any debris. Additionally, if your drain hose is restricted it may be providing dirty water back into your tub. I hope this information is helpful to some degree. -Matt
Feb 24, 2015 | Frigidaire Dishwashers
E 2 error message on bush dishwasher?
I read somewhere , "E2 specifically means that the water level safety system has been activated. In plain English, this means an overfill, and the secondary water level switch has been activated. "
Nov 23, 2014 | Bush Dishwashers
AEG dishwasher C2 error
Dear Sir:
Please read the instruction manual for to fix this error.
If you do not have go for free download: www. fitness.manualsonline.com or www. retrevo.com
see the wiring diagram for help.
May 07, 2012 | Dishwashers
Error message ' L E ' ?
LE means lthe motor is locked up.
1- Disassemble the filter and work your way down to the steel chopper blade
2- Inspect to see if food debris clog up.
3- Remove it and see if the side labeled "this side up" is really up, if it out of the position then it is a problem.
Jul 04, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
2H accures in digital read out. NO Cycles start, just a humming
Do you own an LG LDF6810ST dishwasher? If not, please reply with the manufacturer name, model and serial number.
Are you saying that the display that normally shows the time is displaying an code of 2H? On an LG, that means 2 Hours, (120 minutes) and is not an error code.
On an LG with a symptom like this, I would arrage to replace the main processor card (PCB). You would be getting an error message if the motor (wash or drain) had failed.
Mar 30, 2009 | LG LDF6810ST Stainless Steel Built-in...
E-2 Error on LX30 Hobart Dishwasher
E-2 error is a fill problem. Water did not reach the lower probe within the time out. (innitial fill only
1- Is the bottom probe clean?
2- No fill water (check valve, hose,fill screen in end of hose, and fill source.)
3- low water pressure, should be 20 PSI flow.
4- Fuse 1FU blown.
5- Check wiring to fill valve.
6- Check relay board function.
Feb 15, 2009 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Dishwashers Logo
Top Kuppersbusch Dishwashers Experts
Craig Butler
Craig Butler
ray gallant
Tom Chichester
Are you a Kuppersbusch Dishwasher Expert? Answer questions, earn points and help others
