Question about Crafts & Hobbies
Konica c250 Konica minolta C250
  • 214 Answers
SOURCE: Konica Minolta bizhub C250
i think that your fax is not set up right, or maybe the machine is missing admin and machine e-mail address, that can cause too this problem.
Posted on Dec 31, 2007
SOURCE: Konica Minolta Error code C-D351 on a Bizhub C250
Hi
I have come across this kind of problem.
Is your BizHub on the network? If yes, please switch it off completely, and take the Ethernet cable out of the BizHub.
Wait for atleast 30 seconds and reconnect the cable. Now start the printer again and see if the error message goes away.
Hope this helps!
Posted on May 21, 2008
SOURCE: The printer has stopped functioning all together.
C3851: Abnormal Low Temp. (Heater)
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Posted on Sep 03, 2009
Testimonial: "This is exactly what I needed to do to fix this error. I got it fixed a long time ago but this is the correct answer!!!"
  • 55 Answers
SOURCE: Error code c0202. What is
Most likely there is paper stuck in the very back behind one of the trays. Take both trays out and see if there is any paper jammed (could be a small piece). Put trays back in but leave them open, turn off the printer, unplug it, wait 5 minutes, plug it back in, turn it back on and push in the trays.
Posted on Dec 23, 2010
SOURCE: How can I delete job
1. Click "start" and go to "Run"
2. Type "services.msc" at the prompt which will open the Services
window .
3. Scroll down the alphabetical list in the right window pane until you come
to the entry with
the name "Print Spooler"
4. Right-click this entry, then select "stop". This will stop the computer
running the process that holds your print queues.
5. Leaving that window open for now, click again on "Start", and then click
"My Computer" to open a Windows Explorer window.
6. We've stopped the queue service, now we just have to clear the jam that is
already there. To do this we navigate to the print spool folder which is hiding
within the Windows folders. Usually Windows is
installed on C: drive, but you
should be easily able to tell when the Explorer window opens which drive it is
on.
The usual path to the spool folder is
C:\WINDOWS\system32\spool\PRINTERS, So click on your Windows drive (usually C), then double-click on the Windows folder, and then find the System32 folder and double-click on that. Windows may warn you that you are about to view system files, but click
"View files anyway" message and search out the "spool folder". Within the
Spool folder is your Printers folder, and you should open
that.
Posted on Feb 02, 2011
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
Unable to power up konica minolta bizhub c250
here is the linkhttp://www.ebookbay.com/ebook/938/konica-minolta-bizhub-c250-smif you have any problem contact me.
Dec 06, 2011 | Konica Minolta bizhub C250 All-In-One...
How and where to solve /fix error code C-D301 on bixhub c250
here is the link
Download
Konica minolta code c-1190
here is the link to download service manual
Download
Nov 11, 2011 | Konica Minolta bizhub C250 All-In-One...
Error code c5201 on konica minolta c250
call a service tech but if you are brave... here is the problem http://www.copytechnet.com/forums/konica-minolta/21588-c252-mainmotor.html
Mar 11, 2010 | Konica Minolta bizhub C250 All-In-One...
Hi In our office Konica Minolta C250 ,it show message mulfunction. error:- c0206
C-0206 relates to tray 3.
With the copier turned on do the following
Open paper tray 3, remove paper, close tray, open then shut front door, load paper into tray 3 - hey presto!!
If the fault comes back you could have paper stuck behind the tray or have a defective lift up motor.
Regards
Taminol
May 13, 2009 | Konica Minolta bizhub C250 All-In-One...
Crafts & Hobbies Logo
76 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
