Question about Samsung ES65 Digital Camera
Problem with the display
When switch on the camera display will be blank there is no pictures
When I switch the camera on the screen in blank
when you connect the camera with a cable to the television the screen is blank because that the default settings what you get in camera the television screen acts as a LCD of the camera , when u move your camera to click pictures you get the display on the television screen
Nov 21, 2010 | Canon PowerShot A75 Digital Camera
Camera switching on ok but lcd sceen blank
Your problem can be the result of a number of causes - two common ones I will list here.
Most common cause would be a failed printed connecting cable between the main camera electronics and the flip out display panel. This special cable passes through the display hinge and is sometimes subject to failure.
A second possibility is a faulty display backlight.
You can check that the camera is still producing video output by using the AV cables conected to a TV display with the camera set to CAMERA mode.
I trust that this information is of assistance. RHN
Jan 02, 2010 | Sony Video Cameras
When FinePix V10 digital camera is switched on the LCD screen is blank, The lens works but does not display picture. FujiFilm Digital Camera FinePix V10
Hi, When you say the screen is "blank" Is it totally blank or do the icons appear on screen? can you review any previous pictures etc?
As the camera still powers up it is possible that the ribbon for the screen has popped out of it's socket.
My email is listed in "the only way i know how.." In my tips n tricks section on my profile if you would like more advice.
Aug 15, 2009 | Fuji Cameras
CCD problem
your display must have been switched to blank mode..check the manual on how to cycle it to display normally...usually it's the button that has a square icon
Aug 11, 2009 | Panasonic Lumix DMC-FX8 Digital Camera
I have Canon EOS 300D digital Rebel. I have had intermittent problem with the camera display screen going blank even though I put a freshly charged battery in. Usually I can take a couple pictures then the...
Strange, intermittent problems with the EOS Digital Rebels can be caused by a defective shutter release switch. We charge about $85 to replace it.
Nov 12, 2008 | Canon Cameras
Display is blank
there is a probably a problem with either the screen or the camera itself...
either case take it to a repair shop!
Oct 16, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Display is blank
I can take perfect pictures indisde a building, but taking a picture outside, I can see the item but if I take the picture and looking at the picture the screen turns blank, seems to me that there is to much light exposure.
Aug 18, 2008 | Sony Cyber-Shot DSC-W1 Digital Camera
Display goes blank
I tried Solution #1 (twice) with no luck. But, when drilling down thru the options in "menu" I found one that said "reset" and tried that. Voila! Back in business. Display no longer blanks in 1-2 seconds. Don't know if this only works after reformatting internal memory or not. So, if no luck with "reset" try to reformat then reset.
Jun 28, 2008 | Casio Exilim EX-Z55 Digital Camera
Sony digital camera dsc s40
code error 61 related to internal lens problum.i think lens movement moter stuckup this is reparable
Jan 13, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Samsung ES65 Digital Camera Logo
14 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
