Question about Clothing
How many pairs of shorts come with And 1 Men's All Courts 2 Shorts?
How do I return 2 pairs of shorts because I purchased the wrong size?
since you didnt buy them from fixya how could we know???
Aug 22, 2017 | The Computers & Internet
No power to ignition coil
2004 Suzuki Forenza , so say title.
what engine?, 2.0L or out side usa with 5 engines used.
power to.,.
  1. check fuses yet, that be first. (all electrics that.)
  2. scan it next to see DTC errors related to IGN COIL.????
  3. RTM , the manual is 4 bucks read that yet?
https://suzukipitstopplus.com/Products/1027-2004-forenza-service-manual.aspx
so are you saying there is no spark on all 4 cylinders.
that be first, 1 &4 dead or 2 &3 dead. (coil pack pairs, not with wires scrambled, they most not be connected WRONG)
if only 1 pair fail we have a cure.
if all 4 die, other ,,, see?
tests matter, doing all tests on wasted spark, tells you whats up.
test with 2 spark plugs. new.
shells gounded.
1 and 4
then 2 and 3. pairs.
all 4 fail, or just 1 pair? a key fact. on all wasted spark systems.
if you scan and get DTC shows, cmp dead, ckp dead or
ignitor 1 dead, well, ???? do you>?
coil pack
if pin 2 is 0v, cranking
the fuse EF10 is blown or the pump relay open.
to fix cars like this, you need the book, the schematic,
as seen here.
the ecu fires the hidden coil pack drivers.
if one plug goes open , you lose 2 cylinders
if one HV wire goes open, same.
see?
if one HV wire shorts to ground only THAT cylinder goes dead.
pin 86 is 12vdc cranking
pin 85 , the ECU grounds this pin to send power to the coil pack.
pin 30 is obvious, 12vdc all the time.
Nov 14, 2015 | 2004 Suzuki Forenza
Where can I buy pink frayed edge denim shorts?? I keep seeing them in magazines and want a pair so badly! Preferbaly somewhere online that offers returns in the UK in case they dont fit properly.
love these!! also comes in other colours in case you want more pairs..http://www.boohoo.com/restofworld/icat/shorts/denim-shorts/lea-acid-wash-frayed-edge-denim-hotpants/invt/azz54452
Feb 28, 2013 | Clothing
I need size 48
http://www.dsquared2.com/
men or women's clothing? the website has both. or try ebay,
Jan 16, 2013 | DSquared slim washed destroyed denim jeans
The machine only works intermittently
had the same problem with Kenwood Prospero.
look for 2 pairs of watty (1.1 kohm 2W?)series resistors. At junction of the
2 pairs there is glue which degrades with heat and becomes conductive. CAREFULLY scrape away the old glue after removing the resistors. Check for shorts and resolder the resistors. You may be lucky. I was
Sep 18, 2012 | Kenwood Prospero Compact Km265 4.3 Litre...
On day one 1 pirate recruits 3 men,on day two 2 pirates recruited 8 men, on day three 3 pirates recruited 13 men. Can you find the pattern & find out how many men 5 pirates recruited? What about 10...
From the second step the difference between pirate x and pirate x+1 is 5.
1 pirate- 3 men 2 pirates- 8 men 3 pirates - 13 men 4 pirates- 18 men 5 pirates- 23
Jun 27, 2010 | Mathsoft StudyWorks! Middle School Deluxe...
3 medium beeps on pc; repeating
Hi John. If you already swaped the Memory, it's the video card. I'm giving you what the beep means according to the different types of BIOS, because basically Ascent is a clone PC. I hope it helps.
(you will have to open the computer to see the BIOS type.)
BIOS AWARD
1 long beep and 2 shorts -- Video error
2 short beeps -- non-fatal error.
1 beep corto -- OK.
BIOS AMI
1 short beep -- Memory error.
2 short beeps -- ECC error.
3 short beeps -- Memory error.
4 short beeps -- change atery
5 beeps cortos -- bad processor.
6 beeps cortos -- bad keyboard.
7 beeps cortos -- video memory bad.
8 beeps cortos -- video bad.
BIOS PHOENIX
1-1-2 beeps -- Problem with cpu/motherboard.
1-1-3 beeps -- Cmos issue.
3-4-1 beeps -- Video issue.
BIOS IBM
1 short beep -- Post normal, ok!.
2 short beeps -- POST error, will show on screen.
NO beep -- CPU issue or Expansion card issue
1 long and 1 short -- motherboard error.
1 long and 2 shorts -- Video issue.
1 long and 3 shorts --EGA video issue.
3 longs -- Keyboard error.
Apr 29, 2010 | Systemax Ascent Pro A20 (988185) PC...
I have a pair of shorts with a waist tie that is caught under the agitator. How do I get the agitator off to untangle the shorts?
WEll, hard to know with no brand specified, but usually the agitator can be removed by unscrewing a retainer bolt, typically under some cap at the top of the agitator itself.
Oct 05, 2009 | Washing Machines
Clothing Logo
183 people viewed this question
Top Clothing Experts
treeeee
treeeee
shuyumeng
shuyumeng
Erin Wood
Erin Wood
Are you a Clothing Expert? Answer questions, earn points and help others
