Question about HP ZD7168CL Notebook
Removing a BIOS virus
System runs very slow and hard drive not recognized
    Sergeant:
  • 239 Answers
Get the software from HP to "Flash" the BIOS.
Try a flash drive if the hard drive is not recognized.
Posted on Feb 16, 2014
My system is running slow
Slow computer If you have a virus program installed, it is most likely is running a scan on your hard disk. It can slow down your computer especially if you have a large hard drive. After scanning is completed then the computer will be faster.
To make your computer (hard disk) lean and mean, uninstall any programs you do not use.
Also you need to maintain your hard disk by running Disk Cleanup this will remove old temp files and old compressed files etc.
This will reduce the number of files the virus scanner has to scan. Plus running Defrag. this makes your files contiguous so the system can access files off the hard drive quicker because it does not work as hard.. Disk Cleanup and Defrag should be carried out at least once a month.
If you have 512Mb of RAM installed then installing more RAM will speed up your computer. After installing your graphics card, you may need to disable the built-in graphics card in the BIOS for the new graphics card to work properly.
Apr 22, 2013 | Computers & Internet
What is the reason of very slow speed of laptop hp 6710b intel core 2 duo
Apr 20, 2013 | Computers & Internet
Extremely slow running
Mar 29, 2013 | eMachines T5274 Desktop PC
How do i speed up my laptop
Mar 21, 2013 | Computers & Internet
My computer is slow
Feb 07, 2013 | Everex StepNote NC1502 Notebook
Bios currupted antivirus shut down can`t change settings
Download an updated Bios for your computer from another computer. Remove the Hard drives and using a computer that is not infected and has good Virus Protection connect the Hard Drives up 1 at a time as slave drives to the good computer then scan the drives to remove viruses. Once the Bios is downloaded copy it to a portable media your computer can access extracting it from the .zip file if needed. Insert the media into your computer and run the Bios Update from the removable media. This should fix the bios problem. After your hard drives are scanned and cleaned reinstall them and boot the system. You should be up and running. Good Luck.
Jun 25, 2010 | Computers & Internet
My nc10 reported the 'operating system not found' a week or so ago. I've tried everything including trying to reload windows xp from a USB [as the netbook doesn't have a cd drive] At this point I just want...
Sound like your hard drive has crashed so bad that the notebook does not even know it is there. I would replace the hard drive and try to reinstall from external cd-rom . Make sure the external cd-rom is recognized in the bios settings Good Luck
Nov 23, 2009 | Samsung NC10-14GW Notebook
My system work very slow.
Sir you can download an trial software named as system mechanic as it can be downloaded from iolo.com
hopefully it will makes your computer fast as it is now.
Jul 10, 2009 | Microsoft Windows XP Home Edition
Windows is so slow
The most common reason for slow processing speed is insufficient RAM memory.
Increase the RAM, if RAM available is no more than 512MB, then it must be upgraded.
Check also your hard drive state. If you have less than 1GB free, that will slow down the system. Go to Start>>Programs>Accessories>System Tools>Disk Defregmenter and do a Defrag of the hard disk.
If you have at least 1 GB RAM, and you took care of the hard drive, then you can check the process starting up on their own and remove the useless one, or spot mala-ware that can affect speed. You can use a software like Hijack This, and search on google te function of each process started on the list reported by the software.
You can download Hijack this here MajorGeeks | If download does not start, then click at the top of the page, where it says Click Here If It Does Not.
Be careful if you delete the wrong files using this software you can harm the system, and Windows may not work properly.
If you think you have malaware you can also install Spy Bot, and do a system scan. Download Spybot from The home of Spybot.
If all the above does not work, and there is no malaware, then you usually reinstall the system.
Check also the bios settings, BIOS can downgrade the CPU speed on default , even if this is uncommon on recent BIOS.
If a computer is still slow with a fresh system and enough resources then it is one of those rare occasions when you have an hardware fault.
Hardware that can cause slow down is: RAM CPU Motherboard HD Video card.
Some tips on procedure can damage your windows installation. Do not download Hijackthis software and do not change BIOS settings and do not touch hardware unless you are sure of what you are doing.
May 29, 2009 | HP Computers & Internet
Disk drive "disappeared"
Hit run then type chkdsk C: to find your harddrive, when found also check BIOS if it recognizes the drive, then check the device manager looking for the hard drive and Any exclaimation mark that point to problems. then if it still does show up run add hardwareapp and let the plug and play system find the drive , id that fails then you either need a new drive or have a virus ,need to remove the virus , or reformat this harddrive and re install the system
Mar 21, 2009 | HP Pavilion dv6768se Notebook
HP ZD7168CL Notebook Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
