Question about Samsung UN39FH5000FXZA - 39in 1080p 240 Cmr Led Fh5000 Series
Does this television have a timer? - Samsung UN39FH5000FXZA - 39in 1080p 240 Cmr Led Fh5000 Series
How to reset tv lamp on mitsubishi wd-65831
RESET LAMP TIMER
    • 1 Turn on the television after replacing your television's projection lamp with a new unit. If a dialog box displays on the screen asking you to reset the lamp timer, use your remote control's "Arrow" buttons, highlight "Yes" and press "Enter." If the dialog box does not appear on your screen after turning your television on, proceed to the next steps.
    • 2 Turn on the television, then press the "Menu" button on your control. Navigate to the "Setup" menu, press "Enter" and choose "Low Powericon1.png" from the menu options displayed on the screen. Press the "Exit" button on your remote control and turn off the television.
    • 3 Repeat the first step to reset your television's lamp timer. If your television screen is unable to produce a picture after replacing the projection lamp, press the "<", ">" and "Power" buttons on your remote control at the same timeicon1.png to reset the lamp timer.
Read more: http://www.ehow.com/how_7358147_reset-lamp-timer-mitsubishi-65731.html#ixzz33n0pJu2S
Jun 05, 2014 | Panasonic Televison & Video
Osd timer turns tv off while watching i believe, sleep timer is off and osd timer is on 60s
Used the remote,make sure the osd timer is off the 60s will not auto tv turn off.
Jul 12, 2010 | Akai LCT2060 Television
Tv powers off by itself
go to your menu on your television, go to timer and check to make sure that your timer is off. Your timer is probably set to power off after a certain amount of time of inactivity. If it is not in timer, then check power if that is a choice in your menu. Good luck!
Jun 30, 2009 | LG 42LG50 42 in. LCD HDTV
Can you use a Sleep Timer
A Sleep timer on your TV has nothing to do with the connection or service provider. Yes you can use a timer to turn on and off your TV. this is not provider specific. Thanks for you good ratings
May 21, 2009 | Norcent Technologies PT4231 42 in....
Reser timer for lamp
I can help you reset the lamp timer for your Panasonic PT-52LCX66 Projection HDTV.
Follow the steps in my Fixya Tip for the complete lamp timer reset procedure.
I hope that helps.
Mar 02, 2009 | Panasonic PT-52LCX66 Projection Television
How to reset lamp timer
Go to the menu and you'll find lamp timer section.
Aug 27, 2008 | Vivitek V37835 46 in. LCD Television
Lamp timer
From the Vivitek RP51 manual:
To Reset Lamp Timer please follow these steps:
1.) Press "MENU" and "VOL ADJ >" buttons on the right hand side of the RPTV for three (3) seconds while the RPTV is on.
2.) "Lamp Timer Reset" should appear on screen.
3.) Press "OK" to reset the lamp timer.
Jul 18, 2008 | Televison & Video
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Timer on television
The user manual is available here:
Pioneer website - PDP5060HD
Setting of the sleep timer is on page 58, quote:
You can also use the menu to set the Sleep Timer.
1 Press HOME MENU.
2 Select “Sleep Timer”. ( / then ENTER)
3 Select the desired time. ( / then ENTER)
4 Press HOME MENU to exit the menu.
Nov 17, 2007 | Pioneer PDP-5060HD 50 in. Plasma...
Samsung UN39FH5000FXZA - 39in 1080p 240 Cmr Led Fh5000 Series Logo
16 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
