Question about Kenmore 8503 White Microhood Microwave 1.6 Cu Ft, 1000 Watts
Door does not close
Panel states door not shut and won't work
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 78 Answers
Did you try forcing it? It might have been badly engineered. refer to your warantee
Posted on Feb 18, 2014
Won't shut off
You may have a problem with a door switch or door switch mount, or there may be a shorted relay on the control board, which can easily be repaired.
Our help file on door switches is here, and the Advantium 120 service manual is here.
You can order GE parts from the Pros here.
Jun 06, 2013 | GE Advantium 120 Convection/Microwave Oven
Microwave won't start
I have the same problem. Is the light still on inside the microwave? Mine is on and the microwave thinks the door is not shut. I took the top off of the microwave and the latch needs to push down on a switch once shut. The latch was reaching the switch, but I think some spring in the door, pushing the latches down, has broken since it reaches the switch when closed but there isn't any downward force to flip the switch.
I am trying to figure out how to repair the latch but if your light is on when you "shut" the door, you may have the same problem.
Aug 23, 2012 | Cuisinart CWM-100 Microwave Oven
I have a Haier microwave and tonight after heating some food, I went to close the door and upon closing it, the carousel started turning and it won't shut off.
It sounds like one of the door switches has become defective, each must be disconnected on the one side and tested with a digital meter using the ohms scale.
Jun 07, 2012 | Haier Microwave Ovens
Kenmore 401.80083700 won't turn off
It is one of two things, a defective door switch, or the keypad control board has failed.
Apr 18, 2012 | Kenmore 68361 Microwave Oven
Power won't shut off when door closes
One or two micro switches are defective, "door switch"
Apr 02, 2012 | GE Profile Spacemaker Over-the-Range...
Oven won't shut off
One of the door switches is defective, caused by a build up of food particles or normal ware, to correct this a professional will need to identify the problem and replace it.
Mar 07, 2012 | GE Advantium 120 Convection/Microwave Oven
Door indicator prevents microwave from starting
This is usually an indication of a bad door interlock. Take resistance readings with the power turned off on the primary and secondary interlocks. You will need to remove the control panel to access them. There should be a wiring diagram somewhere inside the control panel to assist you in determining if the interlock is normally OPEN, or normally CLOSED. As you open and close the door the interlock should change states. Additionally, double all your connectors to make sure they are plugged in correctly. I had a similar problem once and it turned out to be a loose connection on one of the interlocks. I hope this helps you.
Aug 04, 2007 | KitchenAid KBMC140HSS Convection/Microwave...
Microwave door
It sounds like the mount which holds tension on your door latch heads (door hooks) is broken. You can confirm that by pushing up on the door hook. If it goes up with no real resistance, the spring is unhooked. Fixing that would require disassembly of the door (by separating the panels) and repairing or replacing either the door hook assembly or the door panel inside.
Sep 11, 2006 | Samsung SMH7159 Microwave Oven
Kenmore 8503 White Microhood Microwave 1.6 Cu Ft, 1000 Watts Logo
24 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
