Question about Eizo CX270-BK-CN 27" Widescreen ColorEdge IPS Monitor
CX270 Eizo monitor: has it fans inside?
And if it has fans, do they make noise? Even almost inaudibly? I intend to use it in a very, very quiet environment so the CX270 has absolutely silent: no fan noise, no buzzing power supply.
3 Suggested Answers
nileshsingh2
  • 246 Answers
SOURCE: I have an EIZO T962 CRT 21 inch monitor with bright screen
CHECK FOR DAMAGED RESISTORS ON BOARD NEAR HIGH VOLTAGE AND ALSO ON CRT SOCKET, ITS A COMPONENT PROBLEM, RECTIFY IT..CHANGE THE DAMAGED COMPONENT, ALSO CAPACITORS IF POSSIBLE..
Posted on Oct 16, 2009
  • 732 Answers
SOURCE: Eizo color edge 241W is the monitor. It starts up
pencilstudio, The electronics inside the monitor will need some work!! You will NOT fix with strokes to your keyboard!! And besides that, YOU'RE using your head!!! Most BLACK screen users fail to even try to verify the PC's VGA port with another KNOWN GOOD monitor!!! What you need to do is the flashlight test (trick) to evaluate the state of the units "switch-mode-power-supply". Reconnect 241W to a knowngood port that is sending WIN-desktop to monitor. Then and only then "turn-on" the 241W . Note how long you see the desktop for , before the LCD psnel goes to BLACK!! Then POINT bright flashlight 1 inch from screen and note if you can still see a very FAINT image of the desktop.. SEE= SMPS is in partial shutdown mode. NO SEE= SMPS in full shutdown. In any case, unit will need work done on it. If unit is still in warranty then have them fix it. If warranty not an option, then you or someone will need to do the work. Your monitor WORKS!!! Just not LONG enough!!! It can possibly be repaired with about $8.00 in parts, and you are capable of handling the labor part. Read some of my other responses to the more than 130 other BLACK SCREEN lcd owners. Follow the LEADS to other websites that will help you make the decision to do a DIY or to farm out the work as cheap as possible. DO THE RESEARCH FIRST. Then if you still are stuck for a solution, come back to fixya and make additional comment to this posting. 12fixlouie
Posted on Dec 23, 2009
How to reset eizo monitor
resetting Eizo monitors - RetouchPRO
www.retouchpro.com > RetouchPRO > Tools > Hardware
Apr 10, 2008 - 6 posts - ‎4 authors
is it possible to rest a CG241W to the default factory settings?..the consultant that is working with us is having trouble getting a decent ...
Eizo
www.eizo.se/default.aspx?page=21
EizoOften there are no faulty sub-pixel on a EIZO LCD monitor, but according to the EIZO... Reset the monitor to the factory default settings by choosing 'Reset* in the ...
Setting Eizo Logo Display On/off; Resuming The Default ...
www.manualslib.com > ... > Monitor > FlexScan S2202W > User manual
The EIZO logo appears on the display when turning on the monitor. This ... default settings, and the other is to reset all the settings to the default settings. ?.
Jan 23, 2016 | Eizo Computers & Internet
Pixelated appearance
Hello Anon, it seems you may be looking at a driver conflict here. Setting up this project is easy; bring in a second monitor and prepare to swap between the two frequently.
1. On the Eizo's menu initiate the self calibration.
2. When the Eizo completes the self calibration and the Pixelation persists, uninstall all the Graphic Card drivers on your computer.
3. Install the manufacturer's specific graphics card drivers from the manufacturers website.
4. If the monitor continues to be pixelated then ensure that your GC is 4k ready. (That it can natively display 2560x1440 @ 16:9 aspect ratio).
I suspect your Graphics Card is not up to par, it likely has full 1080 but not enough to push 4k as your monitor natively runs. Purchase any GC with a 4k ready capacity and you will enjoy the full beauty of your purchase.
Source:
http://www.tomshardware.com/forum/304706-33-completely-uninstall-graphics-drivers-install-ones
http://en.wikipedia.org/wiki/Graphics_display_resolution
http://www.eizo.se/default.aspx?page=11&product=CG277-BK
Mar 06, 2015 | Eizo Nanao Eizo - CG277-BK 27"" Wide...
Eizo foris fx2431 osd problem
If you downloaded and installed any software with this monitor, uninstall it, see if the issue goes away then reinstall it.
The other thing to look at is if you are using any adapters in conjunction with your video cable.
Dec 03, 2013 | Eizo FORIS FX2431 Widescreen LCD Monitor ...
Hello. I am looking for a driver for my vintage Eizo Flexscan T67S CRT monitor for Vista O/S. Is there a source for this kind of driver?
You probably do NOT need any "device-driver" software,
because it is a "plug-and-play" device that Windows will automatically recognize.
Click with the RIGHT mouse-button anywhere on your "wallpaper".
Click Properties.
Click Settings.
Click Advanced.
Click Monitor.
Click Properties.
Your monitor should be listed.
Jan 04, 2010 | Eizo FlexScan T 566 17" CRT Monitor
Dec 23, 2009 | Eizo ColorEdge CG21 21.3 in. Flat Panel...
I have an EIZO T962 CRT 21 inch monitor with bright screen. I can't adjust brightnes with conventional means ( adjusting via buttons). In the past I correct this problem on Sony trinitron 19 inch monitor...
Oct 16, 2009 | Eizo FlexScan TX D7S Monitor
Almost inaudible handset because its so quiet.
A speaker is the first suspect, the second is the speaker connection, the audio amp final ckt. Check for a lose wire, dirty connection, flux, a bad solder connection, ect on the main ckt Bd.
Nov 28, 2008 | Motorola Walkie Talkie 2-Way Radio
Noise when fan runs.
try cleaning the fan blades
dust/debris build up unbalances the fan and wears the bearings out
oil will only cure the problem for a short while - best option is to relace the fan
Nov 18, 2008 | Humidifiers
Eizo flexscan f78
go to www.driveragent.com they have it. or I have the file I could send to you.
Jun 12, 2008 | Gateway FPD2275W LCD Monitor
Eizo CX270-BK-CN 27" Widescreen ColorEdge IPS Monitor Logo
Top Eizo Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
Jerry Umali
Raj Patel
Are you an Eizo Computer and Internet Expert? Answer questions, earn points and help others
