Question about Refrigerators
Just bought a Kenmore pro refrigerator. The frig has digital and analog gages on the front. the digital is set for 34 degrees and the analog gage which is supposed to read actual temp is also reading
When digital temp is set. the digital gage corrects to that temp within an hour or so.
  • mark barncord
    mark barncord Feb 16, 2014
    34 degrees. So the frog thinks the temp is correct but inside temp is 48 degrees.
  • John Tripp
    John Tripp Feb 16, 2014
    Mark what is the model number? Kenmore model numbers look like 321.1234567
Bob Gemmell
  • 209 Answers
SOURCE: Samsung RS2545SH Freezing Everything
Sounds like a thermostat problem. There will be a thermostat sensor inside the fridge usually inside the interior light housing.
Posted on Sep 28, 2007
  • 203 Answers
SOURCE: temp gage reads very low
your thermostat is probably stuck open. does the rad get hot. if this helps please rate me thank joe
Posted on Nov 23, 2008
tborn6
  • 700 Answers
SOURCE: samsung rs2533sw fridge not cooling
it sounds like the refrigerator evap is frozen up causing the compartment to get too hot. shut the unit off and let it thaw out. then take the screws out of the cover to check the stryrofoam on the back side of the cover to see if theres broken spots on it causing the air to bypass the evap causing it to freeze. Theres two screws behind the light cover and two at the very bottom of the cover and two behind the decorative plugs about 1/2 way
Posted on Dec 22, 2008
  • 508 Answers
SOURCE: gage reads 10-50 degrees below actual tempiture
The needle on the dash gage can be pulled off and slipped back onto the stem of the gage. First get an accurate temp gage to be sure what the engine temp is operating at. Then remove the face of the dash gages and remove the needle and place it back onto the stem to reflect the current correct engine temp and you should be good.
Posted on Mar 12, 2009
  • 14036 Answers
SOURCE: TEMP GAGE READ IN A 2000 ALERO
TEMP GAUGE SHOULD STAY IN MIDDLE.IF ITS MOVING UP A LITTLE CLOSE TO RED.CHANGE THERMOSTAT AND RADIATOR PRESSURE CAP MINE RELATIVE CAR DONE THE THE SAME.I REPLACED THEM BOTH -.WARNING IF ITS YOUR FIRST TIME LET A GARAGE DO IT BECAUSE YOU GOING TO HAVE TO TAKE THROTTLE BODY OFF.TO GET TO THERMOSTAT.THEN COOLANT SYSTEM IS GOING TO TO BE BLEED.TO KEEP ENGINE FROM OVER HEATING.IF YOU BEEN USE TO WORKING ON CARS. ALL IS GOOD.
Posted on Jul 21, 2009
Why isnt my frigidaire side by side refrigerator cooling and compressor is working?
you need to put a set of gages on the unit and check the Freon amount
Jun 12, 2014 | Frigidaire Refrigerators
What is the mormal temperature swing of a Refrigerator?
What you call temperature swing, is hysteresis. For a refrigerator it only is allowed a few degrees. 1 or 2 up and down. A swing from 32 to 45 is far to big. Unless the factory can prove they advertise these figures. I would never buy a frig like that.
I would contact the dealer and ask him / her to replace the thermostat and if that is not possible to bring another refrigerator.
Something is really wrong with yours.
Jun 11, 2014 | Kenmore Side by Side Refrigerator
My true freezer temperature gage has a P1 flashing code
Have a look at the Make and model of your thermostat and download the Instructions from the internet or give ur local refrigeration mechanic a call and ask him they are easy to set
Mar 23, 2010 | True Commercial Freezer TM74F
What is the check gauges light
CHECK GAGES light (1) indicates a potential engine failure(low oil pressure, low coolant, coolant overheating) has occurred.
· Check gages and shut down engine. Gages should read as follows: Oil pressure 5 to 10 psi (34 to 69 kPa) at idle; Water Temp gage below 230 degrees (110 C).
· Check engine oil level (Para 2-11) if OIL PRESS gage indicates low reading. Check coolant level (Para 2-11) if Water Temp gage indicates high reading. Notify Unit Maintenance if levels are low.
If CHECK ENGINE light (2) is on, check engine oil pressure gage (3) and water temperature gage (4). If both indicate normal, proceed with mission and then notify Unit Maintenance. If either one does not indicate normal, stop engine immediately and notify Unit Maintenance
Oct 16, 2009 | 1999 GMC Jimmy
Frig is staying at 64 degrees, freezer is very cold, it is a whirlpool made frig, under kenmore name
set freezer temp warmer, this allows more air into the fridge compartment, its opposite from hoe=w they look! and a common service call issue thats nuisance related
Aug 23, 2009 | Kenmore Refrigerators
Gage reads 10-50 degrees below actual tempiture
Mar 11, 2009 | 2001 Ford F150 Styleside SuperCrew
Lg frig side is warm but freezer side is good
You are setting your fresh foods side to 34 but the display will go back to showing the actual temp. It is still set at 34. The refrig should be able to reach the 34 setting, so although 40 is an OK temp for a refrig, it is not what you set it to and you are definitely having a problem with the unit. Instead of starting to go through a long list of checks, I would advise you to call for warranty service, as the unit is only 3 months old.
Please don't bother rating this solution, as anything but a FixYa will lower my score. Thanks.
Nov 30, 2008 | LG LRSC26940ST 36" Side-by-Side...
Refrigerator not cooling properly
you need to turn the frezzer downso it lets more cold air into frig. and put the frig setting back in the middle,aslo vac off your coils under the frig.all this should work,if not let me know,also check to see if you have any frost buildup on the freezer walls-mike
Oct 14, 2008 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
13 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
