Question about Mr. Heater Big Buddy Heater
Heater shuts off
Turning the heater from low to medium then shuts off
  • Debbie Walker
    Debbie Walker Apr 12, 2016
    don't hold down the red knob completely when turning it from low to high, it does have a middle section when turning the heat...if it doesn't start, when using a full tank, tap or bang the propane tank on cement...sometimes the stem in the new/old tanks gets stuck. When I didn't know this, I connected it, and then went to bed, woke up then it turned on the gas.
    Master:
  • 996 Answers
Medium switch or its connecting wire is faulty,should be repair by an expert
Posted on Dec 11, 2014
I have been using my heater in the garage to prevent my water pipes from freezing. It just quit working today. The lights do not light and it will not heat any longer. What happened and what can I do to...
Have you checked the circuit breaker or fuse for the circuit that your heater is on? It's possible that you had something else come on that, combined with the current draw of your heater, popped the breaker. If that turns out to be the case, turn the heater switch from high to medium or from medium to low so that you're drawing less current.
Feb 24, 2015 | Comfort Zone CZ7007 Oil Filled Electric...
My propane heater shuts down when I switch it from low to medium.
Bunch of things here could be possible --- high limit switch/cut out---gas pressure----valve/switch
Nov 13, 2014 | Heating & Cooling
Heater blows cool when on medium and high
Heater core is partially plugged or the control valve for the heater is not working.
Jan 09, 2014 | 1999 Dodge Durango
I don't understand what the controls do pelonis oil filled radiator
I would try the thermostat one by turning it up to a higher heat. I feel the other one may heat on high but would not shut off. You would have to do it manually.
Sep 23, 2017 | Pelonis WM-HO202C Oil Filled Radiator...
I am having problems with turning my gas heater ( Rinnai Convector 404) on and also a high pitched ringing sound, we were given the heater a cpl weeks ago and managed to use it no probs for a few nights...
This noise you hear may be a result of a gas pressure problem to the heater. Generally, it's caused by low pressure. Low, meaning below the the standard required by the manufacturer for this heater. The gas regulator on the heater may be stuck in a partially open position or the line that furnishing the gas to the heater is to small in diameter. Also, check the gas line shut off vale, to make sure it's fully open.
Hope this helped you troubleshoot and solve the problem.
Jun 04, 2011 | Heating & Cooling
Jeep cherokee Heater blower problem
Its not the switch or the controller in the instrument cluster. On my jeep there was a panel on the passenger side under the dash board. It helped me find it by turning on the heater and going toward the sound of the blower. On the backside of the panel was a series of little coils that control the different speeds. one of those coils had been broken.
Feb 20, 2010 | 1989 Jeep Cherokee
Why won't my car heater shut off
You have a short in the switch or resistor pack. replace the switch
Feb 03, 2010 | 1999 Oldsmobile Intrigue
Low does not work, medium and high do
You probably cant fix it, this sounds like a multispeed blower with hi/medium/lo settings. You
can either replace the motor or connect one of the
working speeds to low/med or low/hi. or bump med to low and high to medium.
Jan 12, 2010 | Desa International Blower Glow Warm Wall...
Thermostat
Thermostat for what, a furnace with blower, an induction heater, baseboard heater, describe the thermostat, what it is for, how it is wired, and we can figure something out. Write to me at wbwill@sbcglobal.net or at allexperts.com, Will is my real name and wbwill is used for both help sites, the email is my home email
Oct 04, 2008 | Fahrenheat Electric Convector Baseboard...
Heating & Cooling Logo
245 people viewed this question
Top Mr. Heater Heating & Cooling Experts
Paul Carew
Mack Baxter
vance jones
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
