Question about Smart Box Games Android Apps
Ethernet stopped working
Using a NETGEAR powerline connection to my Android SmartBox used to work fine but the Ethernet connection has stopped working - The wifi still works on the SmartBox. The NETGEAR and Powerline Ethernet work fine but just on the SmartBox it no-longer works. Have checked and changed the Ethernet cable and that works fine.
Keliath
  • 39 Answers
SOURCE: Actiontec GT704-WG wireless connection not working
you say it suddenly stopped working, if you can connect to the router via ethernet cable then try to access the router's web utility page and make sure your router is in mixed or G-only. If you can't still connect to the router through wireless then try restarting the Wireless Zero Configuration from windows. This is how it's made: Go to control panel and double-click "administrative tools", then double-click "services". You will see a list, scroll down to Wireless Zero Configuration and click "stop", you'll see a progress bar. After that click "start", you'll see another progress bar. Now try connecting to your router via wireless connection. If you still can't connect then repair the connection by right-clicking the wireless icon at the bottom right corner. Keep repairing until you connect.
Hope this works!
Posted on Feb 17, 2008
damonumber5
  • 340 Answers
SOURCE: i have 2 comtrend dh-10pf
To start you need to factory reset both adapters,
plug them both into a wall socket next to each other, press the config/f reset button, hold in until ap light goes off, repeat on the other one.
Now you should have a red status light on both.
Press the config/f reset button on one for about 5 seconds, wait until ap light stays on, this one is now your access point (ap) that should be plugged in to your router when you have finished config.
Now press the ap adapter config button again for about 5 seconds until ap light flashes, then press the config button on the other adapter until ap light flashes, wait until they both stop flashing, wait a few seconds, the status light on both adapters should be green, and one adapter should have an amber ap light.
Hope this helps.
Posted on Mar 09, 2009
  • 193 Answers
SOURCE: Powerline ethernet lost connection
this is usually caused by dirty power, have you installed cfl light bulbs recently?
you might also check to see if any existing full fluorescent lights produce a buzzing noise.
Posted on Aug 14, 2009
SOURCE: connecting powerline ethernet adapters through orange livebox
  1. Make sure the LiveBox is set to "TV ethernet non active"
  2. Set OFF other existing connections (such as wifi), if any.
M. Razaire
Posted on Aug 20, 2009
  • 88 Answers
SOURCE: Can you explain to an idiot, which exactly what is
Plug the PowerLine adapter into the wall
Plug one end of the ethernet cable into PowerLine wall adapter
Plug the other end of the ethernet cable into the Orange LiveBox
Plug the Orange LiveBox power adapter into the wall
Posted on Apr 03, 2010
How do i fix after modem reset
Basically, you unplug all of the Netgear Xe104 units, wait a minute, then plug the one nearest to the Router back into a wall socket first. Wait a few seconds then plug in a second Xe104 and give it a minute to "talk" to the first unit. Then plug other Xe104's in one at a time. Below you'll find the official troubleshooting steps which you should read carefully if the basic steps above do not resolve the problem.
Also, i should tell you that Powerline adapters such as yours have improved greatly in the last few years, and you can buy a pair of new ones that are very, very much faster than yours for a very modest cost. For example, TP-LINK TL-PA4010KIT
or NETGEAR Powerline 500 1-Port Starter Kit (XAVB5201) or
ZyXEL PLA4225 4-Port 500 Mbps Powerline Gigabit
XE104 User Guide 4-2 Troubleshooting v1.0, September 2005
Power Light Not On Make sure that, if power to the AC power outlet is controlled by a wall switch, the wall switch is in the on position. Verify that the wall socket is live by disconnecting the XE104 85 Mbps Wall-Plugged Ethernet Switch and plugging in some other electrical product, such as a lamp or a hairdryer. If the error persists and you have confirmed the power outlet you are using is live, you have a hardware problem and should contact technical support.
HomePlug Light Not On If the power light is on but the HomePlug light is not, check the following: • Make sure that power is being provided to more than one PowerLine device. Another PowerLine device must be installed for successful communication across the PowerLine. • Verify that the network password is the same on all devices in the PowerLine network.
Ethernet Light is Off • Make sure that the Ethernet cable is plugged in properly at both ends. • Be sure you are using the correct cable on the router that the first XE104 is connected to. When connecting the router's Internet port to a cable or DSL modem, use the cable that was supplied with the cable or DSL modem. This cable could be a standard straight-through Ethernet cable or an Ethernet crossover cable. • On attached Ethernet device or network adapter card, check that the Link light is
Feb 25, 2015 | NetGear Xe104 Wall Plugged Ethernet Switch...
I am using powerline ethernet adapters from my pc to ps3 was working fine for 12 months uddenly ps3 will no longer connect to internet, however using wifi it will,having moved adapter to ...
A power surge during a storm can damage the powerline adapters, in a heartbeat. This is a very strong possibility and you may need to replace the adapter(s). If it fried one, it can fry them both. Was any other electroonics connected to the power outlets in the home damaged? If so, then you may be out of luck, and need to replace them both.
Oct 03, 2013 | Powerline Ethernet Network Adapter
How to turn Netgear WNR834B into a repeater
I don't think the Netgear WNR834B is capable of acting as a repeater but there is another solution. I would decide where I want to put the Netgear WNR834B for best coverage and then do the following. Go buy the Powerline Ethernet Adapters of your choice and put one at the main connection and plug a ethernet cable into a open switch port. Second go to where the repeater is to be located and plug the 2nd Powerline Ethernet Adapters in and connect to the Netgear WNR834B LAN port. Be sure to turn off DHCP on the Netgear WNR834B and assign a IP address that is not used. I normally use the highest address in the last octet so that I can remember for management. xxx.xxx.xxx.254. I hope this helps you.
Apr 28, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
The middle ight keeps blinking and it wont work how do i fix it
Blinking middle light indicates an issue with the powerline used between the powerline adapters. To isolate the issue plug both the poweline adapters in the same room and check the lights on them. If they work fine in the same room then the issue is with the powerline. You may have circuit breaker, surge protector between the powerline adapters and that will prevent you to get a connection.
Hope this helps.
Regards
Anand
Mar 12, 2010 | NetGear XE102 Powerline Ethernet Adapter...
I have MacBook and it is not recognizing the ethernet connection
1. First check the light status of the XE102.
2. Then hard reset the Xe102
3. As this is a plug n play device all the lights should come on.
4. In case if the lights wont come on.
5. Check the powerline ..
6. And if that will not work , get a new adapter or replace the existing one from netgear ( 1-888-638-4327 )
Jan 26, 2010 | NetGear Powerline XE102 Ethernet Bridge...
The middle light on my netgear ethernet bridge xe102 wont stay on
-- Xe102 device is simply a plug n play device
-- so if the connection light shut off after some time
-- first hard resett the powerline adapter
-- and after that get the powerline checked
-- If that doesnt work there is no specific configuration
get the adapter replaced ..
Jul 01, 2009 | Powerline Netgear XE102 Ethernet Bridge...
Netgear WGX102 stops working after some usage
As the device works fine when connected in the same room. the issue does not seem to be with the powerline adapters but with the powerline itself.
If you still suspect the powerline adapter to be faulty then try connecting another powerline adapter at the same place and check if it works. This will help you for a speedy resolution
Jun 12, 2009 | NetGear WGX102 Repeater
Trouble installing XE102 Powerline
there wasn't actually any problem with the device. For these bridges to work, you need to be on the same phase of the wiring. If the devices are on different phases then they can't communicate. But I still couldn't get the encryption to work. Netgear support doesn't seemed to be bothered with that...they told me to ignore it.
Dec 16, 2008 | NetGear XE102 Powerline Ethernet Adapter...
Netgear xe102 isnot picking up an ip address
-- Xe102 is a plug n play powerline device
-- there is no specific configuration required for that .
-- try hard resetting from the reset hole on the back of the device
-- then get the powerline checked
-- check the light status of the powerline device.
And if the problem still persists , upgrade the powerline device ..
Follow the link below ::
http://kb.netgear.com/app/answers/detail/a_id/901
Nov 15, 2008 | NetGear XE102 Powerline Ethernet Adapter...
Netgear ethernet xe102
You have to be on the same transformer leg Xmitter and reciver try moving the input device to a diffeent outlet. or use one of the ethernet only units to see if you have etherne tconnectivity, also there is a pricatical distance limitation of about 600 feet. are you in that range. Best of Luck Graeme at ctcco.com
Oct 09, 2007 | NetGear XE102 Powerline Ethernet Adapter...
Android Apps Logo
Top Smart Box Games Apps Experts
Brett Duxbury
Brett Duxbury
Marvin
Marvin
Are you a Smart Box Games App Expert? Answer questions, earn points and help others
