Question about Dynasty DGRSC 30 Gas Kitchen Range
Oven doesn't turn on and we don't smell gas, is there a pilot light or just an ignition
4 Suggested Answers
  • 3 Answers
SOURCE: Oven failing to light
The ignitor needs at least 3.2 amps current flow to heat the bi metal in the gas  control valve enough to allow the gas to flow. cold ignitor (red) will not flow enough current, when ignightor gets yellow resistance drops enogh to allow bi metal to heat and allow gas valve to flow and ignight gas. most likely your ignitor is shot
Posted on Jan 25, 2009
SOURCE: I have a dynasty DGRSC-30-4
Are you using natural gas or LP??
Posted on Dec 12, 2010
ftw1952
  • 10319 Answers
SOURCE: Turning on the oven - I get a delayed start up and
when you turn on the oven the igniter (aka hot surface igniter, glow bar ) should come on (yellowish glow). About a minute later the gas should enter the burner and ignite. How long is it taking for the burner to ignite? As the igniters age it takes longer and longer (2 -5 minutes) until eventually the burner NEVER ignites. However, even though the burner is not igniting the low amperage draw from the igniter causes a PARTIAL opening of the safety valve allowing gas to enter the oven burner. This gas is not sufficient enough to ignite the burner but sufficient enough for a noticeable gas odor to emanate from the oven cavity. So if the igniter glows but the burner takes more than 1-2 minutes to ignite I would change the igniter.
Posted on Apr 17, 2011
When i turn on oven all i smell is gas i cleaned with a wire brush still nothing. also is the pilot light always have to be on and can you see it when oven is off
Most gas ovens that aren't electronic ignition usually have a pilot light.
Usually one in the oven area and one for each burner. (Sometimes shared between two burners.)
These pilot lights must lit at all times...otherwise it won't light up and you'll smell gas.
Usually the pilot light is in the very back of the oven and can be seen with the broiler drawer opened.
There is a small set screw located at the pilot light assembly in the oven and also at every burner.
This allows you to adjust pilot light up or down, thereby letting you set pilot light flame to a level that doesn't get blown out by a draft...or you can turn it off completely.
If you use that set screw to turn off the pilot light gas, you'd need to strike a match to light the oven or burners everytime you needed them.
Jul 17, 2011 | Ovens
Caloric range oven, older at least 20 years old, the range burners spark, but will not light, i am assuming that its electronic ignition, no pilot light?
If you don't smell gas, then it is probably electronic ignition and not a pilot light.
But if your oven and none of the range burners light, are you sure you are getting gas to the unit or from the range valve to the burners and oven? Can you light the burners with a match? If you can you can rule out the valve and incoming gas line, and concentrate on the ignitors.
Jun 07, 2011 | Kitchen Ranges
Our 17year old GE gas oven/broiler stopped lighting today. What might be the problem? Stove burners work.
Most likely culprit is the igniter.
When you turn the oven on it opens a gas valve allowing a small amount of gas to flow thru the pilot light. The igniter then lights the pilot and when the sensor determines the pilot is lit it opens th emain gas valve and the oven lights. If the igniter fails and doesn't light the pilot the sensor doesn't heat up and it shuts down the pilot and nothing works.
The igniter is usually accessable under the oven by removing the drawer. It has a single wire attached and looks like a short cigarette made of ceramic witha metal tip.
You didn't provide model number so I can't give you part number but if you look it up here you may be able to get one from Sears
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001
May 18, 2011 | Ovens
I had problem with the GE Profile Spectra JGBP90 Gas Kitchen Range try to turn the stoe on , clicking noice but no flame. smell lots of gas. how can I light the pilot light back, where is it?
This range doesn't have a pilot,it has an electronic igniter. If you are smelling gas while trying to light, your igniter is bad and needs to be replaced. Remove the racks from the oven. Remove bottom panel in the oven. Remove the metal plate that covers the flame spreader. The igniter will now be visible. Try turning on the oven again. Take note of how bright the igniter gets. If it stays a orangish color it needs to be replaced. It needs to get to an almost bright white,
Feb 11, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Maytag gas oven doesn't heat, but oven's pilot light is on.
Get the oven checked out by a professional, if you have a gas leak you can easily blow up the entire house and you with it. I think you have a faulty gas valve based on what you wrote
Mar 03, 2017 | Ovens
Gas oven will not ignite
It sounds like somebody bypassed the flame sensor on the oven, no oven should ever release gas for more than a couple seconds if there is no ignition. This oven is very dangerous and should not be used until it is looked at by a professional.
Dec 19, 2008 | Ovens
How to light Oven Pilot for Magic Chef stove 31000 PAW
There is a cover plate that has two screws holding it down. Inspect the pilot area and you will see a hot surface igniter sitting right next to it.. That is what lights pilot and then the pilot lights main burner. You need a new igniter. Also do not touch any part of the hot surface igniter as human oil will shorten the life of part.
Nov 25, 2008 | GE JGRP17 Gas Single Oven
Tappan TGFS26C, Oven igniter not even
Lets take the oven problem first. Sounds like you have a Hot Surface Ignitor problem. This is the device that glows and lights the burner. You can buy a universal ignitor at most appliance or heating and air conditioning supply houses. Note carefully how the old one is mounted. You may have to make some adjustments to mount the new ignitor, but it MUST be close to the gas burner like the old one! You don't smell gas because the gas valve will not open until the ignitor is hot. All ignitors work with the same voltage, so simply connect the new wires to the old ones.
I'm not certain if you have a standing pilot for the stove top burners or electronic ignition. Remove the top panel to check. If you have a gas pilot, relight it. If electronic ignition, clean the ignitors. If that does not solve the problem you may have to call a technician, as these systems can be complex.
Hope this helps.
Ray
Nov 20, 2008 | Tappan TGF363 Gas Kitchen Range
Oven does not heat up, can smell gas.
You probably need an oven igniter, it's weak. Remove oven bottom and find caged unit attached to burner. Replace this oven igniter. The 2 wires can go either way.
Nov 22, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Dynasty DGRSC 30 Gas Kitchen Range Logo
50 people viewed this question
Top Dynasty Kitchen Ranges Experts
Ismael Rodriguez...
Sal DeAngelo
Jaime Hernandez
Are you a Dynasty Kitchen Range Expert? Answer questions, earn points and help others
