Question about Philips Senseo HD-7810 Coffee Maker
The machine keeps switching off after a few seconds
Please help-the suction on our dc26 keeps cutting out a few seconds after switching machine on. Filters all cleaned and no visible blockage. What should I do?
Take it to your local vac shop for diagnosis. It could be several different things that can cause that.
Feb 19, 2015 | Vacuums
Intermittent Start (expanded explanation)
Lint will jam the start/run switch on the motor. Vacuum out the motor real good and check that the switch moves freely, and all the wires to it are plugged in good.
Nov 30, 2013 | Maytag Dryers
Kenmore washing machine 110.22082 does not drain
you probably looking for a new drain pump ( control board also possible)
Sep 05, 2009 | Washing Machines
Powers on for a few seconds then goes off
Your machine is not booting to the bios... time for a new machine/mother board
Aug 13, 2009 | E-Machines REXUS SPE-300 ATX 300W P4 Power...
Fisher & paykel - SPIN light keeps flashing and machine beeps
could be a faulty off load switch
running off balance
machine not level
depends how old the machine is then
if none of those
worn machine motor or internals
might the the circuit board
Apr 16, 2017 | Fisher Paykel EcoSmart GWL15
My Koro Expresso machine keeps saing Install Bioler? What do i do to rectify the problem
The boiler is the preheat reservoir so you don't have to wait. Keep filling the machine untill it won't take anymore and chk for another switch that is always left on at rear side of machine. In =a few second you should hear the water heating Dry run the first time, just have your carafe in place but no coffee, good luck.
Jun 25, 2009 | Coffee Makers & Espresso Machines
Indesit wia 121 door lock keeps flashing and when put machine on it goes to a wash without turning dial to correct wash no.
these machines have a memory built into the pcb's which means that if they are switched off or there is a powercut etc they will just carry on from where they were in the cycle as soon as they next power up. if there is a black dot on the timer settings turn the dial to it then switch machine on and this should reset it for you after a few seconds. if this does not work count how many times the doorlock light flashes as this is a fault analysis code they will usually flas then pause for a second then flash again and repeat this sequence until a longer pause (3 seconds) then the sequence starts over.
hope this helps
Jul 28, 2008 | Indesit Washing Machines
Smartdrive 708
The out of balance micro-switch is faulty/corroded. This switch is located under the motor control module on the right of the machine and is activated by a plastic lever that goes down beside the outer tub. Replace the micro-switch.
Oct 07, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Philips Senseo HD-7810 Coffee Maker Logo
Top Philips Coffee Makers & Espresso Machines Experts
Kolbrun...
Lisa
Lisa
just-ice
Are you a Philips Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
