Question about Dometic Refrigerators
Domitec fridge will not cool
It seems to select the proper power sores it will light burner and it stays lit just will not get cold
  • Official Brand Answer
  • 73 Answers
Have you tried it on electric?
If the fridge is level, and the rear coils of the fridge are warm and the fridge does not cool, you will more then likely require a cooling unit. Arcticold refrigeration manufactures brand new replacement cooling units that are available throughout north america Visit ArctiCold Refrigeration We keep it cold
Posted on Mar 07, 2014
4 Suggested Answers
  • 68 Answers
SOURCE: AC,DC, gas RV fridge Dometic
You more than likely need to replace the control cable between the upper and lower board. It comes as a kit with the upper board. You can also do a bypass test by unplugging your thermoster from the circuit board. The thermoster is the temperature control for the refrigerator nothing to do with the freezer.
rvtech@myway.com
www.coachtech.info
734 777 6432
Posted on Mar 18, 2009
SOURCE: Hotpoint Fridge Freezer FF187e - 3 lights flashing
i have just fixed my fridge freezer by following the instruction from KarenBa and GWoman i have also managed to stop the lights (super cool and super freeze) from flashing by turning the temperature to zero on both fridge and freezer so they turn off then holding both super buttons down for about 15 seconds then turning the temperature back up. hope this helps
Posted on Feb 24, 2009
  • 15 Answers
SOURCE: norcold refrigerator burner will not stay lit
u need to replace the thermocuple or be sure its near the pilot also be sure to blow out any and all dust in that area
Posted on Jan 29, 2010
Does not get cold
disconnect thermistor on board run overnite if ok replace thermistor if not bad cooling unit
Feb 16, 2014 | Dometic Refrigerators
LG gn253sqa electro cool- temp. control lights in fridge keep flashing and fridge not cooling so good, help?
This has happened to me a couple of times.The problem is that when the fridge door is opened too may times the warm air of summer will block the cold outlets in the fridge with ice.The cold air comes direct from the freezer and the chamber connecting to the fridge clogs up with ice.What one has to do is completely empty the fridge and freezer,leave open both doors so the the ice build-up can melt.Then after about at least 4-5 hours (very important to stick by this time-frame as I tried a less time,but it did not work.),close both the freezer and fridge doors and switch it on.After about 1/2 hour replace your goods in the fridge.The down-side of this is that you will need the kindness of a neighbor or two to use their fridge to store your food whilst this fix is underway..
Feb 28, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
My cozy floor furnace wont come on
NEED MORE INFORMATION. IS THERE A LED LIGHT THAT FLASHES A CODE?. IS THE THERMOSTAT OPERATING PROPERLY? IS THIS UNITS FLUE EXHAUST VENTED TO THE OUTSIDE? & IS IT FREE OF OBSTRUCTIONS?,
Dec 25, 2012 | Cozy Heating & Cooling
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
98 trailer with a Dometic RM2652 will not ignite on propane
Dometic DM 2652 just installed in travel trailer. Went to plug in and turn on later and discovered no lights or power? what do I start checking?
Apr 19, 2010 | Dometic RM2652 Refrigerator
Wall mounted CBN30T, pilot goes out
IF its balance flue it could be blocked . Burner or orifice blocked lack of air to pilot slightly blocked thermocouple defective .
Mar 03, 2017 | Desa International CBN20T Heater
I have dometic modle R M 2333. It will not cool when set to gas. But is ok on AC. Burner flame is good, gas flow is good.
If the unit has a good flame and is staying lit throughout the cycle of the fridge, then you probably have a bad cooling unit. Does is cool ok on Electric? If so, then there is another problem. You may have rust build up in the flue that is not allowing the heat from the gas to work correctly. Try taking a screwdriver and small claw hammer. Remove the cover from the burner assembly and place the head of the screwdriver on the flue just above the burner. Tap the screwdriver lightly with the hammer and see if rust falls. If so, continue to do this until it stops. You then need to blow out the burner and try the fridge again.
Hope this helps,
Jeff
Jul 07, 2009 | Dometic Refrigerators
Freezer isn't staying cold
What is the solution? What can we do to engage the refrig. again?
Mar 31, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Refrigerators Logo
143 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
