Question about Pioneer AVIC-Z3 Car GPS Receiver
How to set time on avic h - Pioneer AVIC-Z3 Car GPS Receiver
AVIC-X910BT Destination Menu-Address isn't lit up. Can't put in an address. Settings isn't lit up can't change settings or enter address. What is the cause?
The only time a Navigation unit will grey out the ability to enter an address is if it thinks the car is moving. Check your connections. If you connected the VSS (vehicle speed sense) wire to a tachometer or generator signal then the unit is getting the same signal as if the car were moving.
Feb 09, 2013 | Pioneer AVIC-X910BT 5.8 in. Car DVD Player
How do you set clock?
Under settings menu, select Time.
Here is an excerpt from the manual:
Here is the manual, if you like:
http://www.docshare.com/doc/225202/Pioneer-AVIC-N1-Hardware-Manual
Jul 12, 2010 | Pioneer AVIC-N2 Car DVD Player
How do i set time
manual link below.
http://www.pioneerelectronics.com/StaticFiles/Manuals/Navigation/AVIC-Z3_OperationManual0218.pdf When you use the navigation system for the first time, [Regional Settings] screen appears. On [Regional Settings] screen, you can change the language or time. (The settings can also be changed afterward.) = For details, refer to Customizing the Regional Settings on page 88
Mar 17, 2010 | Pioneer AVIC-Z3 Car GPS Receiver
How do i set the clock on a pioneer avic-n2?
Manual (PDF) for AVIC-N2 can be downloaded here. (It might take up to 2 minutes, depending on your internet connection).
Chapter 5 of the manual deals with "Customizing your navigation system." Page 67 lists specific instructions on how to change the time.
Good Luck!
Jan 22, 2010 | Pioneer AVIC-N2 Car DVD Player
How can I set the clock on a Pioneer AVIC-N2 Nave Rcvr
Good Luck!
Jan 16, 2010 | Pioneer AVIC-N2 DVD Navi Rcvr with 6.5"...
Don't know how to set the clock on the Pioneer AVIC-D2 head unit
drop by your local car stereo dealer and ask them NICELY to reprogram the time for you...then, a NICE person would but the guy lunch, what $10?
Good Luck
Jun 15, 2009 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
I installed the Pioneer AVIC-F900BT and it has been
Windows CE is used to operate the Pioneer AVIC F series, which yours falls into. That version of Windows has not been patched or updated with the new day light savings times and since the player uses GPS to get the current time and Windows to make the time change for your zone then your time will not update until the orginal daylight savings time occurs. You can try to change the time to manual in the Pioneer settings, deal with the wrong time for just a lil bit longer until the original Daylight Savings Time takes place, or re-search an update and way to update the players OS which is Windows CE. Hope this helps :)
Mar 10, 2009 | Pioneer AVIC-F900BT Car GPS Receiver
How do I set the clock on my Pioneer AVIC-D3, it's an hour off?
I live on the east coast and had to change my time to be all the way out to one end and manually i have to turn on or off the "summer" time setting, which is kind of like DST.
Dec 31, 2007 | Pioneer AVIC-D3 Car DVD Player
Time
Press the right toggle switch in and the setting is in that menu. The gps automatically sets the minutes
Aug 25, 2007 | Pioneer AVIC-N2 Car DVD Player
Pioneer AVIC-Z3 Car GPS Receiver Logo
16 people viewed this question
Top Pioneer GPS Experts
David Burbee
David Burbee
Are you a Pioneer GPS Expert? Answer questions, earn points and help others
