Question about Jura Capresso Impressa Coffee Makers & Espresso Machines
How to manualy start clean program Jura F70 - Impressa Jura Capresso Coffee Makers & Espresso Machines
2 Suggested Answers
CoffeeLoverZ
  • 33 Answers
SOURCE: jura f70 error 8
There is a Jura Error Guide that says:
  • Turn machine off, turn the main power switch off and unplug machine for at least one minute.
  • Turn machine on again. If the error message comes up again, try one more time.
Posted on Feb 13, 2010
Jura Capresso Impressa 50. It doesn't always rinse when first turned on now and that just started. I unplug and sometimes it resets and is fine and sometimes it doesn't.
Rinsing cycle at start up is electronically programmed function. Unplugging is a temporary solution.
Jura will not sell parts or offer any guidance.
I could look into more details to find an answer but the model Capressa 50 is not listed in my Data base.
Dec 29, 2016 | Jura Capresso Coffee Makers & Espresso...
How to clean jura C5 grinder
How to access grinder itself? Where is it? My Jura C5 doesn't grind coffee beans at all. Firstly grinder has started with starnge noise and then stopped with alarm "no beans", now it doesn't start at all..
Mar 06, 2012 | Jura Capresso Impressa Coffee Makers &...
My capresso coffeeTeamGS maker will grind the coffee but will not brew it????
Hi. Your brew unit is by passing the water that is supose to brew. You'll have to clean the brew unit. Jura brewunits are not easly removeable, + you can't buy parts unless your a authorised repairer. Try doing a manual descale cycle. You need to add descale solution to the watertank and operate the hot water and steam functions, which allows the solution to enter the system. Open these functions until water and steam are pumping through, then switch them off and let it sit for a few minutes, then repeat the above 5 or 6 times. This allows the solution to break up any build up. OK, now you have manualy descaled the steam and hot water circuits. Now allow the machine to try and make coffees." we are only trying to clean the machine, so dont drink the coffee." Try 5 or 6 times to see if this is starting to brew better. WE DO NOT LEAVE THE DESCALE SOLUTION IN THE MACHINE. We need to flush the system with fresh water as per above. Descale is corrosive, so we need to get it all out. I hope this has worked for you, other wise you'll have to take it to an authorised repairer. Dazza REPAIRER
Sep 24, 2011 | Jura Capresso CoffeeTEAM GS 46405
Where do you put the calc pill?...how does it open? what are those long white pieces that come in a package about 6-7 inches? and with them, a box with something 'poison' on it? IT NEEDS TO BE...
The long white piece is a water filter. It filters calc (lime) out of the water. It should fit in the water container at the back. Just click it in.
The cleaning pills are not for de-scaling. You should run the cleaning program. To do this open the small lid at the top of the machine, press the P-button until the screen changes (a few seconds). Turn the dial until service is in the screen push the dial and turn until cleaning appears. Push the dial button again.The pill should be put in the coffee powder entrance. If you start the cleaning program it will state when you should do that.
Oct 06, 2010 | Jura Capresso Jura Ena 5 2Cup Coffee Maker
Jura F70 Grinder stopped working
The switch or photo sensor is not sensing any beans present.
So it can't continue
Use torch to inspect bean entry area
Small brush etc
Apr 18, 2010 | Jura Capresso Coffee Makers & Espresso...
I have an Impressa Z5 and it won't **** milk up the tube as either part of the cappucino program or the stand alone milk program. I've checked and nothing in the nozzle is blocked and the plastic pipe...
There are three possible causes to milk not frothing: 1. The frothing tap is blocked: to unblock either use the cappuccino cleaner from Jura, or in 400ml of luke warm water dissolve a teaspoon of vinegar or 1/2 teaspoon of bicarb and run this liquid through the frother until completely finished (or run the cleaning program). The run about 600-800ml of water through the system. While passing the liquid through let the tap rest at froth, and milk setting for 5 seconds at a time. Repeat if necessary. To prevent this in future clean frother after 5 minute of none use. 2. The breathing nozzle is blocked, you can use the Jura Maintenance guide to see how to disassemble and clean and reassemble, but most Juras come with a spare, so replace it. 3. The machine needs to be descaled, since there is lime or scale in it.
Jan 15, 2010 | Jura Capresso Impressa Z5 Espresso/Coffee...
Jura f70 error 8 solution
Dec 31, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
Malfunction 8
The brew unit having problems with positioning it self. Use your finger and clean out all used ground from the brew unit you can find. Start the cleaning program with tablet, hopefully you will get around the error code.
Aug 14, 2009 | Jura Capresso Impressa F9 Espresso Machine
Cleaning with tablet
Your water system is clogged with minerals. Try decac first. If that doesn't work you will have to have a pro manualy search for the blockage. www.hotncold.com
Jul 04, 2008 | Jura Capresso C1000 Espresso & Coffee...
Coffee Makers & Espresso Machines Logo
44 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
