Question about Dishwashers
Lg ld2131sh machine gives an error code e1
  • 423 Answers
SOURCE: What is an E1 error code for an LG Dishwasher? Model LD12AW2
Please check at both ends of the drain hose and confirm that you do nit have a leak. Also, please confirm that water is not leaking directly under the dishwasher.
If you are certain that you do not have a real leak, check the impeller (under the mesh filter in the sump area beneath the lower dish rack) is not damaged and is firmly in place.
The E1 error code is a Leakage Error, detected by the motor spinning faster than it should if the unit is filled with water.
Please report back with what you find. Good Luck!
Posted on Mar 30, 2009
  • 423 Answers
SOURCE: LG Dishwasher making grinding noise then blinking E1 code 10 minutes later
Well done by resolving this problem. The other way to avoid the siphoning problem through the drain hose is adding an air gap valve/connector (available at any hardware store). You can use it even if you don't have a garbage disposal in your kitchen sink. That will assure that you have the proper height of the drain hose.
Hope this helps!
SOURCE: LG LD2131SH dishwasher has an HE error code. What can that be
I need operating manual of LD2131SH, thanks
Posted on Aug 09, 2010
  • 500 Answers
SOURCE: LG LD2131SH Dishwasher displays a
Hi santjiesfras,
The error code your receiving is an "Inlet Error" message. This means that no water is going into the Dishwasher. Please check the following:
1) Is the tap open.
2) Is the inlet hose kinked?
3) Is your water pressure fine? Because anything less than 0.3kgf/cm(bar) is not going to work
If all of the above is fine, then take off the inlet hose of the dishwasher, and clean the filter which is between the hose and machine (small circular filter). If still not working, then you will need to replace the inlet valve. I would suggest getting a L.G service agent to do so.
Good Luck :-) - J.Q
* If you found this solution helpful, please vote positively. A 4 four thumbs up will do nicely too :-)
Posted on Apr 13, 2011
  • 500 Answers
SOURCE: E1 error on LG washing machine LD-1204W1
Hi gmann947,
*Nice nickname, reminds me of Jeremy Mansfield, a retired radio presenter on 94.7 fm - Hehe*
To help you with your request, I'd advise you to look at my Tip below, it has the full description on how to fix the E1 error:
L.G DISHWASHER E1 ERROR...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it.
Posted on Jul 21, 2011
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    We keep getting an error message E1. We have an LG 2120 model
    The E1 or 1E error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
    Dec 13, 2014 | LG Dishwashers
    HOW to fix E1 code for LG direct drive washing machine
    The IE or 1E error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve
    Aug 25, 2014 | LG Washing Machines
    Machine LD2131WH was in 5 cm of water but now water problem solved however machine keep giving code E1 even when taken of the mains for more than 30 minutes
    Hi jwvdbok,
    You are receiving the E1 error because the Circulation Motor is faulty. Please check my Tip below on how to repair it:
    Kind Regards
    JEDEMEYER1
    * If you found this solution helpful, please rate it.
    Jul 10, 2011 | Dishwashers
    Getting a E1 code one the front panel and will not finish the cycle
    There is not a reference for an E1 error code.
    The listed LG error codes are:
    IE, UE, OE, FE, PE, dE, tE, LE, EE, and PF.
    May 18, 2010 | LG WM2016C
    LG dishwasher error code E1
    E1 is a code that the dishwasher displays after detecting a leak. There is a sensor on the pan at the very bottom of the unit. Take the bottom front panel off, look under the unit at the hose coming off the pump and your fill line to be sure no water is dripping. Run the unit in a wash cycle while doing this if possible.
    Nov 21, 2017 | LG Dishwashers
    LG 3 in 1 Dishwasher model LD2131SH showing E1, leaks water
    e1 is a leakage error. you will have to find where it is leaking from...crack hose .crack motor assy.. water must be leaking
    The excessive RPM of Washing Motor happened during Wash cycle due to water leakage.
    Water leakage in Hose connections. Water is leaked by damages. The Motor Water Seal leakage of Sump assembly. The height of Drain Hose connection (sink-Drain Hose) is not over 20 . Impeller of the Washing Pump is worn away.
    Sep 11, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
    E1=Water inlet Error
    Not reached to the normal
    water level in spite
    of 10 min. water supply
    Causes:
    The Water Supply Tap is closed.
    The Water Supply is shut off.
    The Inlet Hose is kinked.
    The Water Pressure is very low.
    (below 10 psi)
    Inlet Valve is OK?
    The filter of Inlet Valve is clogged
    by impure water.
    The Hall sensor is OK?
    The Impeller of Air Guide is bound
    Solutions:
    Take action on Water Supply
    device.
    Measure the electric resistance of
    Inlet Valve. (950-1300 )
    Clean the filter of Inlet Valve.
    Check the frequency of Inlet Water
    by the Test Mode.
    Replace the Air Braker.
    Aug 14, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
    Dishwashers Logo
    15 people viewed this question
    Top Dishwashers Experts
