On some gas-powered appliances -- such as gas ranges, water heaters, boilers and gas fireplaces -- the pilot light works to ignite the main flame when the gas is switched on to the burner by the regulating valve. If the pilot light is not lit, the gas burner will not ignite, which could cause a dangerous situation by letting highly flammable gas escape into the air. If the pilot light goes out, you can relight it after the gas is shut off using a match or the unit's electronic ignitor if it has one, following the proper safety precautions
Have you tried it on electric?
If the fridge is level, and the rear coils of the fridge are warm and the fridge does not cool, you will more then likely require a cooling unit. Arcticold refrigeration manufactures brand new replacement cooling units that are available throughout north america Visit ArctiCold Refrigeration We keep it cold
I assume the water heater and water inside it is cold (otherwise you would not be lighting it). You light the pilot. The main burner comes on and the pilot lights it. The main burner should stay on until the tank is hot, When the tank gets hot the main burner should shut off but the pilot stay on. If you draw hot water, cold water will run in and cool the tank. If yu do nothing the tank will eventually just cools off. then the main burner should come back on to reheat the tank.
When running on Electric insure that the rear coils of the cooling unit are getting warm. If the refrigerator is level and the coils are warm and the refrigerator does not cool then you more then likely will require a replacement cooling unit. I have attached a small video that may help with the diagnoses. You can also give us a call toll free 1-888-782-6665 ArctiCold Refrigeration We keep it cold
First Make sure the gas is turned off. You then need to clean the gas orifice and make sure it is not plugged up. Remove the front burner, using a paper clip clean the orifice. Make sore the burner is not plugged up and if it is use a wire brush to clean the burner. If this does not fix your problem the you will need to change the gas control for that burner. I hope this heps you with your problem.
my RM2652 refrigerator will not get cold on gas or elec. freezer cold (not much) but main box nothing. also fairly warm/hot to the touch around the edge of the unit. Any ideas??
