Question about Sony Cyber-Shot DSC-F828 Digital Camera
Yes i reset my camera but not flash why - Sony Cyber-Shot DSC-F828 Digital Camera
Reset on Moultrie game camera Modle Number is dgs-160, Serial Number is CD080108101
from within setup mode, scholl up/down until you find "delete all images NO";press select & NO starts flashing up/down changes NO to YES flashing press select/enter...do same on "EVENTS"...scroll to default settings NO..up/down buttons to yes; select...scroll to setup...reprogram your custom settings.
Oct 27, 2011 | Moultrie GameSpy 4.0 Digital Camera Deluxe
I have a Kodak EasyShare M530 camera. My flash has stopped working on it. I have not changed any of the settings on it. I dont know what has happened. Is there a reset button on this camera or anything?
I see you mentioned the flash has stopped working, yes in the menu just look for the option to reset to factory defaults or reset to defaults, this will reset the camera to the original settings.
But then I see the Flash is the issue on the camera and it is possible that resetting the camera will not help at all.
I t will be best to have the camera check on the issue, or have it service for proper repairs on the issue, this can be a possible Hardware failure.
Is the camera in warranty if it is then calling Kodak is the best possible option that you will have for the best result in having it repaired.
I hope this helps.
have a nice day,
mvincentc
Sep 08, 2011 | Kodak EasyShare M530 Digital Camera
Flash on Nikon Coolpix s200 camera not working
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
Jun 28, 2009 | Nikon COOLPIX S200 Digital Camera
Flash doesn`t work
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...thank u!!!
rate me!!
May 29, 2009 | Kodak EasyShare DX7630 Digital Camera
I have a samsung digital camera the one where the flash pops up at the top....yesterday the flash only opened half way and now the flash wont work at all no matter what mode i use
thank u!!!
Apr 13, 2009 | Samsung NV20 Digital Camera
Flash stopped working
Have you tried to reset the camera to its factory defaults to see if it is a setting that is causing the flash not to fire? To reset the camera go to the menu left arrow to reset - highlight yes and press ok. This will set the camera back to factory settings. See if the flash fires now. If it does then, good. If not, then it is a repair issue with the flash assembly internally in the camera.
Mar 23, 2009 | Olympus FE-210 Digital Camera
Olympus 1030 sw -Flash doesn´t work anymore
Have you tried to reset the camera to the factory defaults? To do this: have the camera in shooting mode - go to Menu - left arrow to reset - press ok - Highlight Yes and press ok. This will reset the camera to factory settings. See if flash works now.
Feb 11, 2009 | Olympus Mju 725 SW Digital Camera
Flash dont work on my fe 230
Have you tried to reset the camera to the factory default settings? There may be a setting that has the flash disabled. To reset the camera: have the camera in shooting mode - press Menu - left arrow to reset and press Ok. You will see Reset Yes or No. Highlight Yes and press Ok. This will reset the camera to factory settings. It will not affect any images that have already been taken. See if the flash is able to fire now.
Jan 12, 2009 | Olympus FE-230 Digital Camera
Olympus FE-140 ok except that flash does not work
Make sure you try and reset the camera to the factory default settings. There may be a setting that you are using that has disabled the flash functionality. To reset the camera - have the camera in shooting mode - press the menu button - left arrow to reset and press ok - you will see reset yes or no - highlight yes and press ok - camera will be back in factory settings - see if flash is able to work now.
Dec 28, 2008 | Olympus FE-140 Digital Camera
Olympus E-500 - Flash not working at all
you will need to try to reset the camera first through the camera menu by placing the camera mode to P, press menu, right arrow to card, down one to custom reset, right arrow, ok, yes to reset. else you will need to send to repair center
Oct 06, 2008 | Olympus EVOLT E-500 Digital Camera
Sony Cyber-Shot DSC-F828 Digital Camera Logo
24 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
