SOURCE: Sharp AR ? M208N
You have to use a Vista driver for that machine, check sharp's website and see if they have a driver specificcaly for Vista.
SOURCE: Sharp AR-M208N with OFH4-00 error code
Hello sir; This code require simulation to reset the procedure as follow; press "#", "interupt", "clear", "interupt", then enter 14 press start. turn power off and back on, then all set.
SOURCE: Sharp AR-M208N copier with error code U2-40. What
reset u2
press c -interrupt-#-interrupt
press 16
press start
machine off
again machine on
remove this signal.
SOURCE: How do I get our sharp AR-M208N to work with
go to www.sharp.ca
Select Service Support > Downloads and slect Photocopiers. This machine is listed as an AR 208. Click on DONE and the drivers will be presented. Scroll to the PCL English version and download from there.
