Question about Breville Die Cast 800ESXL Espresso Machine
When I use the filter after a previous cup and it is still wet the coffee comes out very watery and undrinkable. When the filter is dry in the morning the coffee is perfect.
If the filter is still wet from previous use the coffee is watery but if the filter is dry the coffee is perfect.
  • Helen dillwynia
    Helen dillwynia Mar 20, 2014
    Thanks Steve for your suggestion. Helen
  • 23 Answers
I'd suggest you try tamping with a bit more pressure, watery coffee is typically the result of water getting "around" the ground coffee as opposed to getting forced through it.
Posted on Mar 19, 2014
4 Suggested Answers
SOURCE: after using coffee that was too small, I can't make coffee with one of the filters
I'm not sure you can. I did exactly the same thing, the very first time I used it -- I phoned Breville support and they told me to try soaking the filter in 2 tsp of baking soda dissolved in a cup of warm water. Which kinda seemed to work, although it was bit occasionally reluctant to give me my damned coffee.
I struggled on with it for maybe a year, but then the rubber seal around the bit the filter connects to blew out (with rather dramatic results). I think the extra pressure of the blocked filter did more damage that I suspected.
I got it serviced and they replaced both the seal and the filter. Worked great after that...
...until last week, when water started pouring out where no water should pour. Turns out that the black lock block that the filter holder goes into has developed a crack.
Looks like another trip to the service agent for me.
In short, you could try cleaning the 1-cup filter, but I would reccommend giving it up as a bad job and just buying another.
Before It Is Too Late.
(Signed, The Harbinger of Doom. Sorry about that.)
Posted on Feb 02, 2008
SOURCE: water on top of the filter after brewing
my experience with this machine is that this varies greatly with the type of beans you use. I would experiment with a few types of beans, roasts, and you might get lucky.
Posted on Dec 01, 2008
EsWorld
  • 1618 Answers
SOURCE: I am finding the coffee does not come through the
Adjust the grind, it is too fine.
Posted on Apr 27, 2010
My tassimo coffee comes out watery
Make sure you push the lid down all the way before putting the clamp down on the front.
I've noticed that the back of the lid on my vivy (t12) can get stuck up (even with the clamp down) causing the water jet to not be inserted all the way - which produced very weak coffee.
May 14, 2012 | Braun Tassimo Coffee Maker
Hi - our machine is playing up. No crema coming through, just a burnt smelling, watery coffee which is undrinkable. used to happen every now and then but is happening almost every time now. help! thanks
If you have hard water it's probably plugged even city water can be hard.
Try running a mix of white vinegar and water through it.The mix is 1 part vinegar to three parts water.
You will need to run clear water through it at least three time before useing then you can use it and see what happens.
Oct 22, 2009 | Coffee Makers & Espresso Machines
Breville Die Cast 800ESXL Espresso Machine: Problem... Watery espresso. My machine worked great for a year, then all the sudden, the espresso is watery and the basket where the grinds are is full of water...
Personnaly, when I use the big filter, the grinds are dry after the extraction, but for the small filter, it's all soggy. If you look at the documentation, ( http://kitchen.manualsonline.com/manuals/mfg/breville/breville_coffeemaker_product_list.html) they say wet coffee grind after extraction is normal.
But did you change the coffee brand ? Or the grinding level ? How do you grind your coffee ? I had big troubbles once with a commercial grinder at my grocery store, it's when I decided to buy my own Breville grinder.
Good luck,
JF
Oct 16, 2009 | Breville Die Cast 800ESXL Espresso Machine
Kitchenaid 14-Cup has plastic, chemical taste
Run 1/4 cup vingar with a pot of water. The coffee is not finishing its cycle and some remains in the works. You may have to do this several times. Washing the carafe with ice and salt by swirling it around a few times until it sparkels clean. Last thing for a good cup of coffee is filtered water which will keep the unit cleaner too. :)
Sep 18, 2009 | KitchenAid KCM400 Coffee Maker
Coffee out of the machine seems too watery
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Feb 22, 2009 | Gaggia Syncrony Compact Coffee...
Watery coffee
Sounds like you're not packing the coffee tightly enough into the unit. You've got to tamp it quite tightly...that's why the pumps are so strong. Each 'atmosphere' is 15 pounds of pressure. My son also likes to make his by doing two double loads to get one espresso cup.
Apr 29, 2008 | Gaggia Titanium Espresso Machine
Breville Die Cast 800ESXL Espresso Machine Logo
101 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Steve
Colin Stickland
Colin Stickland
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
