This is a new problem maybe having to do with the keyboard getting wet. The keyboard is dry and workking fine now.
SOURCE: No sound. Have checked
have you accidently installed another sound driver my friend had same problen i rolled back the driver and it worked fine
SOURCE: One of my library files needed to run control panel is missing
If the system came with a cd for the keyboard, reinstall it. otherwise, reinstall the windows.
SOURCE: no sound on my3100c
Uninstall the old drivers and try the drivers from here.
Rate if useful.
SOURCE: I have an Acer Aspire with Realtek HD Audio
Hello
I had the same problem a few months ago, i also looked to see if i saw a mute function that was active anywhere.
I did not find anything so i just reinstalled the application and my problem was fixed. At the link below you can find the realtek audio app. for xp and vista.
Vusta/Win7:
http://www.brothersoft.com/realtek-high-definition-audio-driver-65158.html
Please rate this solution
Best regards
SOURCE: i have a Sony vaio vgc-m1 , i think some liquid
the beeping is cause by a key that is pressed constanly try and find that key and unpress it manually that should solve your problem
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administration tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if you need more help with this poat a reply
hope this helps you
