Question about Refrigerators
Gear up 55L fridge/freezer alert sound
Was running fine,but now has an high pitched alert beep
SOURCE: Whining noise from freezer
turn the freazer nob to zero for a second or two, the noise will stop. turn it back to your normal setting.
Emad
Posted on Feb 18, 2008
SOURCE: Ge side by side - high low humming noise from freezer section
I have a hotpoint HSS25GFPJWW fridg. The coil that opens the flapper door for the ice was bad so i replaced it . Now when i push the leaver in to get ice the fridge shut's down like ther is a large power drain. This was doing this before i replaced the coil but the flapper door was not opening then now it opens. It evens shut's the compressor off.
Posted on Apr 22, 2008
SOURCE: fridge is whistling
Mine was making a moaning, whistling noise coming from just above the ice maker. It happened when the fan speed changed. I learned on this site that the motherboard was probably defective.
Rather than go thru GE, we found a new one online for 66 bucks. I replaced it in about ten minutes and it's all fixed. Poor materials on the original, but this site was very helpful.
Posted on May 03, 2008
SOURCE: My freezer is making this high pitch noise, its an industrial Beaufort freezer on wheels
Zaria:
I have the same kind of fridge and it also makes this kind of noises, however, they are on the acceptable level. They sound more like a seal being happy with the new food. It is not all the time but sometimes. I think it is the contraction and expansion of the pipes that cause the noise and is not a sign of any problem. Of course all depends on the level of the noise you have...
Hope it helps. Greg.
Posted on Nov 06, 2009
heatman101
  • 43501 Answers
SOURCE: Fridge unit was cooling poorly
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Aug 22, 2011
Constant high pitched shrill when turned on
Sounds like the evaporator fan motor bearings are shot and the motor needs to be replaced. This motor is found near the cooling coil in the freezer section.
May 30, 2015 | Whirlpool Refrigerators
Why would a brand new fridge make strange noises already?
Good Afternoon Friend,
I understand that your Frigidaire refrigerator, model# FFSS2614QS, is making a strange humming noise. Your new, high-efficiency refrigerator may introduce unfamiliar sounds. These sounds normally indicate your refrigerator is operating correctly. Some surfaces on floors, walls, and kitchen cabinets may make these sounds more noticeable. This could possibly be the compressor that you are hearing. Modern, high-efficiency compressors run much faster than in the past. The compressor may have a high-pitched hum or pulsating sound. Hope this is helpful.
-Best Regards-
WP
Jul 02, 2014 | Frigidaire FFSS2614QS FFSS2614QS 26 Cu....
High-pitched chirp at same time every night
High pitch noises are very difficult to isolate. Since you have replaced the refrigerator, I would look for something else in the immediate vicinity that might be generating the sound.
Feb 16, 2014 | Refrigerators
FRIG KEEPS BEEPING BUT DOORS R CLOSED TIGHT
Not knowing the make and model of your fridge, I would suggest reseting the fridge and freezer temperature settings, inside your fridge. With some fridges like Fisher & Paykel, when the power is cut to the fridge, it will beep until you select the temperature level inside the fridge.
Failing that, a constant beep is a warning code to alert that a fridge component has failed.
Ash
Sep 11, 2011 | Refrigerators
Buzzing/high pitch noise for 10 seconds with clicking on and off
hmm do you know where the noise is coming from, go to the back and touch the compressor and lets see if the noise is there so we can rule that out
Jun 23, 2009 | Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ...
Noisy Compressor
either the compressor is under charged or it is near breakdown. compressor cost is almost the 1/3 of the freezer cost.
May 08, 2009 | Haier HTE16WAA Top Freezer Refrigerator
Zaria:
Apr 17, 2009 | LG LRTP1231W Top Freezer Refrigerator
Making a high pitched solid beep tone
This is an alarm alerting you that the temperature has dropped or the alarm is bad and falsely alerting.
Jan 31, 2009 | Freezers
High pitched sound
condensers do not run compressors do however and they run until the cooling /freezing need is met .
Mar 21, 2017 | GE Profile PFSF6PK Bottom Freezer French...
Refrigerators Logo
16 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
