Question about HP LaserJet 4100dtn Printer
HP LaserJet 4100dtn error 54.1 - HP LaserJet 4100dtn Printer
3 Suggested Answers
pdouglasss
  • 125 Answers
SOURCE: installing hp laserjet 4100dtn over the network using tcp/ip addr
Hi admin30:
Here is some info for you.
EIO menu (networked printers)
The EIO (enhanced input/output) menu appears only when an EIO device is installed in an EIO slot
on the printer (such as an HP JetDirect print server). The items in the menu depend on the particular
accessory product installed. If the printer contains an HP JetDirect print server EIO card, you can
configure basic networking parameters using the EIO menu. These and other parameters can also
be configured through HP Web JetAdmin.
Table 27. EIO menu
Item Values Explanation
CFG NETWORK=NO NO
YES
Select whether or not you want to use
the HP JetDirect menu.
NO: Bypass the HP JetDirect menu.
YES: Use the HP JetDirect menu. You
must change this to YES each time you
want to use the menu.
Note
You must select CFG NETWORK=YES to
display the following items.
IPX/SPX=ON ON
OFF
Select whether the IPX/SPX protocol
stack (in Novell NetWare networks, for
example) is enabled (ON) or disabled
(OFF).
DLC/LLC=ON ON
OFF
Select whether the DLC/LLC protocol
stack is enabled (ON) or disabled (OFF).
TCP/IP=ON ON
OFF
Select whether the TCP/IP protocol
ATALK=ON ON
OFF
FG IPX/SPX=NO NO
YES
Select whether you want to use the IPX/
SPX menu and set IPX/SPX protocol
parameters.
NO: Bypass the IPX/SPX menu items.
YES: Use the IPX/SPX menu items.
In the IPX/SPX menu, you can specify
the frame-type parameter used on your
network.
The default is AUTO, to automatically set
and limit the frame type to the first one
detected.
For Ethernet cards, frame type
selections are EN_8023, EN_II,
EN_8022, EN_SNAP.
For Token Ring cards, frame type
selections include TR_8022, TR_SNAP.
In the IPX/SPX menu for Token Ring
cards, you can also specify NetWare
Source Routing parameters, which are
SRC RT=AUTO (default), OFF, SINGLE R, or
ALL RT.
CFG TCP/IP=NO NO
YES
TCP/IP menu and set TCP/IP protocol
parameters.
NO: Bypass the TCP/IP menu items.
YES: Use the TCP/IP menu items.
In the TCP/IP menu, you can specify
BOOTP=YES or DHCP=YES for TCP/IP
parameters to be automatically loaded
from a bootP or DHCP server when the
printer is turned on.
If you specify BOOTP=NO and DHCP=NO, you
can manually set the following TCP/IP
parameters from the control panel: each
byte of the IP address (IP), Subnet Mask
(SM), Syslog Server (LG), and Default
Gateway (GW). You can also manually
set the idle timeout period.
Print an HP JetDirect configuration page
to verify your settings. However, note that
the print server might overwrite selected
parameters with values that ensure
proper operation.
Table 27. EIO menu (continued)
Select whether the Apple EtherTalk
protocol stack is enabled (ON) or disabled
(OFF).
Posted on May 26, 2009
seeker5211
  • 1089 Answers
SOURCE: Problem Error Code 54.OC.01 For HP Color LaserJet
If the error won't go away, the DC Controller in the printer will have to be replaced.
The ".0C.01" part of the error can't be found in the service manual, but I don't think that it will change the fix.
Posted on Mar 05, 2011
54.(xx) error after installed and tried 3 diferent toners, machie turned of each try and still having same issues, HP M4345xs mfp any idea why I'm still getting the error??
A 54.XX error is a sensor problem. What possessed you to play with the toner cartridges? Could be a thermal problem or a bad sensor. You are going to need technical help.
Jul 12, 2012 | HP LaserJet M4345 MultiFunction Printer
It says 50.2 fuser error
50.2 is a laser/scanner error. If it doesn't go away after power cycling the printer, have a trained tech look at it. Probably needs a replacement laser/scanner assembly.
The 13.9 is some kind of paper jam. I can't find the description of that one in the service manual.
I would worry more about the 50.2.
Good luck
Mar 16, 2012 | HP LaserJet 4100dtn Printer
How do I connect my HP Laserjet 4100 to my router?
HP LaserJet 4100 printer C8049A HP LaserJet 4100n network-ready printer C8050A HP LaserJet 4100tn network-ready additional tray printer C8051A HP LaserJet 4100dtn network-ready duplex printer C8052A
Which model do you have? There is an optional card to install before you can have it connected to an Ethernet network if you just have the 4100 model.
Oct 29, 2010 | Computers & Internet
Printer does'nt initialize
This could be a Jetdirect network card fault. Remove the card and power the printer on. If it powers up and goes ready then power it off again, refit the card and try again.Sometime reseating the jetdirect card will sort this problem If it doesn't work, then i recommend replacing the jetdirect netwok card.
Oct 13, 2009 | HP LaserJet 4100dtn Printer
Hp 4100dtn powersave issue
I see that your machines are not on a network but do they have network cards installed?
The jet direct card can cause various problems. Look to see if they are in your machines and remove them if they are.
If that doesn't work you can print an event log and see if any errors corespond with the condition.
Hope this helps
Jan 12, 2009 | HP LaserJet 4100dtn Printer
HP 4100DTN
Run a half test. Start printing a few pages, as it prints open the cover, remove the toner and look down at the paper. Does it have lines on the right side? If yes - replace the toner cartridge.
May 06, 2008 | HP LaserJet 4100dtn Printer
HP LaserJet 4100dtn Printer Logo
27 people viewed this question
Seeker5211
Seeker5211
