Question about Elite Sl 3000 Ul Sliding Gate Operator
Elite SL3000 gate locked light on
Gate stuck, chain came off. Replaced the chain but now gate will not close. When using the remote the 'Gate Locked' light comes on but gate will not work. Checked manuals for troubleshooting but this is not mentioned.
2 Suggested Answers
  • 1156 Answers
SOURCE: My Elite SL3000 sliding gate is not responding to
Hi, Thanks for posting your Question.
When it comes to automatic usage of equipment or gadget that work with remotes sensors..It always malfunctions when water enters into it's electrical area..
Issues like this are have to be checked by an experienced Elite SL3000 sliding gate repairer..Water has enter either the coil area or the magnet that control the opening and closing function of the Gate..
It's not from the remote. That is if the battery of the remote still functions properly..
It needs to be serviced to clean the water inside and after cleaning it up, it will be ok..
Please make sure someone who has the experience should handle it. Thanks
Good luck ..
Posted on Aug 17, 2011
Gate will open pushing open button but cant use remote
General answers only, sorry. Look for loose or corroded connections, especially where wire nuts were used. Reprogram the remote receiver. Disconnect power to the receiver for a short time. Reconnect and reprogram. I hopes that any of this helps. I have operators to the much like witch craft, a black science!
May 10, 2016 | Elite Gate Opener Sl3000 Slide Gate...
How do i open my gate fatther new code and is deseased
Please read your question and reword it so it makes sense.
Feb 23, 2015 | Chamberlain Elite Q400 Circuit Board...
Hi Mary, do you have more than one remote for the gate? Your remote needs to be paired with the gate receiver. Normally you need to push a certain button on the control panel to enable learning mode then you press the remote button you want to use. You will have to follow this learning process for your device. Please keep in mind that just any remote will not work with your gate, it needs to be on the same frequency and use the same modulation mode.
Hope this helps.
Oct 28, 2014 | Elite Sl3000 1hp Slide Gate Motor,...
Rear lift gate lock stuck in the closed position
use a round bar under the lock tongue and pull it back as you press the button to open the latch
Jan 06, 2014 | 2008 Chevrolet Uplander
Trying to identify the "learn" button on my gate opener! Want to install the button for the gate on my Nissan Maxima 2013. Able to install the other two buttons for the two door garage openers but not for...
The elite comes with a liftmaster receiver located above the control box the older kinds were metallic under thelat cover there is a small learn button.
Oct 15, 2013 | Building Materials
How do I install the remote control
a remote control chain link gate is a common site in rural parts of the country, although the popularity is growing in more suburban neighborhoods, too. Remote control gates serve two main purposes. The first purpose is security. A closed gate is one obstacle to keep intruders and burglars off of your property. The second purpose is convenience. A remote control gate does not require you to get out of the car to open or close the gate. In rural areas, the gates also function to keep pets and livestock from wandering off your property
ceiling lights
Dec 24, 2011 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
I have a Miracle One gate opener and, as I've done a hundred times previously without incident, I clicked remote to leave gate partially open (to take trash cans out), about 20 seconds later, the gate then...
The memory could have been somehow corrupted. I would suggest that you call in an experienced person to reset and reprogram the open/close positions.
Hope this helps :)
Jan 01, 2011 | Elite Sl 3000 Ul Sliding Gate Operator
1. I have an elite slide gate opener it will open all the way and after a few sec will close. 2. With the remote the gate will not stop and stay in the open position.
the auto close has been set or the motor has been set up in reverse and it is auto reverseing,make sure the gate is opening up all the way, if it is not just help it along and see what happens.
Apr 13, 2010 | Elite Sl 3000 Ul Sliding Gate Operator
Elite Sl 3000 Ul Sliding Gate Operator Logo
308 people viewed this question
Top Elite Home Security Experts
ray gallant
Pierre Legault
Tom Chichester
Are you an Elite Home Security Expert? Answer questions, earn points and help others
