Question about Samsung MX-FS9000 - 2560 Watt 2.2 Channel Mini Bluetooth Audio System CD/MP3
Paired ps3 but it wont work - Samsung MX-FS9000 - 2560 Watt 2.2 Channel Mini Bluetooth Audio System CD/MP3
My ps3 controller wont come on it just flashes 4 times and switches off maybe its because i opend my ps3 system but i put everything back to normal some 1 plz help me!
This usually means that your ps3 controller is no longer paired to your ps3, to re-pair them attach the controller to the ps3 using the usb cable, then press the ps button again when the ps3 is on.
Mar 21, 2011 | Sony Playstation 3 (PS3) Console
Bought new controller but it wont turn on the system when I press the PS button?
Ok first of all you need to pair it with your system by plugging it in manually through the usb cord. After that it should be ready to go now you can turn it on or off with the PS button.
Feb 28, 2011 | Sony Playstation 3 (PS3) Console
Gun will not pair
try to clean the guns lens in front, if it still wont pair, try the gun on another ps3..if it works fine, your ps3 receiver needs servicing..also try another gun on your ps3 to eliminate the problem..
Feb 09, 2011 | Activision Cabela's Dangerous Hunts 2011
My plantronics P90 model headset is paired with my PS3, but it wont work when i play call of duty MW2. please help!
Just bought the p90, paired it, registered it in manage bluetooth devices, activated it and verified ops in audio devices, and it did not work. I turned the ps3 of and back on, worked fine.
Jan 16, 2011 | Plantronics Radio Communications
My ps3 bluetooth headset wont pair with my ps3
go into accessory settings and connect the bluetooth device via USB so the drivers can be installed to your PS3. This is how i connected mine.
Feb 22, 2010 | Ubi Soft Entertainment Tom Clancy''s...
I connected my dualshock to one PS3 and now it wont connect to the other, it will only charge when plugged in.
When you connect the controller to a PS3 system via cable it pairs with it. And the only way that controller will work with another system is to plug it in also and let it pair with that one. That way when you turn the controller on it wont power up two systems and browse two systems at once. This is the way that Sony designed the controller.
Oct 31, 2009 | Sony Dual Shock 3 Controller for...
I a playstation 3 Blue-ray disc remote control which wont pair
Go to Accessory settings in the PS3 Settings menu,which will have you register/sync the BD controller with the system. Follow the onscreen instructions &it will give the controller a #. Remember that any universal remote wont work..it has to be the Sony PS3 remote, as they use bluetooth technology instead of the usual infrared.
Jun 20, 2009 | Sony BD Remote Control for Playstation 3
Unable to pair my bluetooth with PS3
Is The Blue Tooth In Find Mode? To Inable Find Mode Hold The Power Button Until The Blue Tooth Stays Solid Lit Or Flashes. Then Search For It With Your Device And Once Completed Hit The Power Button Again And It Should Be Able To Pair Right Up.
Mar 04, 2009 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
Can't pair bluetooth
....My madcatz bluetooth will not charge everytime i plug it in the ps3 the red light comes on then it goes off and it keeps on doing it and its a brand new bluetooth...i hold it for a long time and it still wont work..HELP PLEASE!!!!!!1
Feb 06, 2009 | Mad Catz PS3 Bluetooth® Headset Wireless...
Headset wont pair with new ps3
is this bluetooth
if it is blue tooth you have to hold blue tooth power on while the pairing mode is searching for headset
if its a cabled headset threw usb you gotta put in your disk for say example= logitech since these are common
the playstation has memmory card that stores the settings but requires you at least set up usb head set parameters either to ps3 or your memmory cards properties
your headset is fine you just require a new hardware setting with the disk that came with your head set
May 28, 2008 | Sony Playstation 3 (PS3) Console
Samsung MX-FS9000 - 2560 Watt 2.2 Channel Mini Bluetooth Audio System CD/MP3 Logo
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
