Question about Shuttle SG33G5 (XPC-SG33G5) Barebone
Sg33g5 boots only with disabled audio - Shuttle SG33G5 (XPC-SG33G5) Barebone
Sg33g5 turns off after I power it on. And keeps doing it. Why?
It is most likly a bad power cable . Please replace power cable.
May 20, 2014 | Office Equipment & Supplies
Sg33g5 motherboard schematic
Schematics are not normally available as due to the complexity of the pcboard, they are not classed as a repairable item, just replacement.
Mar 07, 2014 | Computers & Internet
I can't install the audio driver. it shows "install Realtek HD audio driver failure".so what I can do now..plz help me...:(
Hello
Im guessing your using a sound card? Not onboard sound.You need to disable your motherboard sound or onboard sound in the system bios.
Hit the delete key while booting up or the f 12 key.
Once your at the main bios screen find the audio or system audio and disable it.Then it save and exit.Pc will reboot..once its started you should be able to install your sound card drivers.
May 25, 2011 | Acer AOpen AW 724 Sound Card
I have a Dell R200 with Windows 7 that has a PCI-X Riser card. On this card, there is a PCI-e Video card and a PCI-X audio card. When trying to install the audio card it states "Not enough...
Couple things to try if you haven't already.
1. Check Control Panel -> System --> Device Manager. Check Display Adaptors and Sound for any issues or marks, remove them and reboot.
or
2. Reboot and go into the BIOS, probably by hitting F2 while booting, disable the onboard audio, save and allow it to restart.
Nov 01, 2017 | Dell PCI-X Riser Card for PowerEdge R200/...
Sound problem
First of all try to disable the onboard sound card.
Enter the bios by pressing "del" or F2 during the boot process, navigate to find sound options and disable the onboard audio. Boot the pc normally, go to the device manager and uninstall any audio drivers. Shut down the pc, unplug the power cord and plug-in your new pci audio card. Start the pc and install the drivers for your new audio card.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Mar 04, 2010 | VIA P4MA Motherboard
Audio static during boot up. Windows vista,no new
go in control panel,sounds,startup sounds and disable all
Feb 10, 2010 | Compaq Presario SR1050NX (DW257A) PC...
How to disable onboard sound on a Gateway GT 5692 (Vista 64)
Go into the control panel,then the device manager,then the sounds and game controllers tab, right click on the audio device or devices,then click disable.Now the audio device will be disabled until you re-enable it.
Oct 02, 2009 | Gateway GT5692 Desktop Computer
Shuttle xpc suddenly turns itself off
Could be overheating.
Suggest you check the Processor Fan is working, usually you can hear it.
If it stays on longer when starting from cold then that could indicate fan trouble.
Most PCs have onboard sensors which can be monitored by programs like Speedfan see http://www.almico.com/sfdownload.php then click on SpeedFan 4.39
Good Luck
Jul 28, 2009 | Shuttle SG33G5 (XPC-SG33G5) Barebone
SG33G5 & Radeon x1950 pro 512mb
sg335g5 mb. only supports 385mb video memory
Nov 11, 2007 | Shuttle (SB83G5) Barebone
Shuttle SG33G5 (XPC-SG33G5) Barebone Logo
43 people viewed this question
Top Shuttle Computers & Internet Experts
Iqbal Husain
Iqbal Husain
David
David
Alun Cox
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
