Question about Dell VT1GD PowerConnect 5524 24-Pt Gigabit L3 Managed Switch
Switch hanging we have a problem that the hub room switches are hanging on some time
Computer in wall network wire stopped working after 6 years.
I would use a spare hub or switch in place of the existing hub. This sounds like a failing hub or switch to me. Two cables would not normally go bad at once.
May 25, 2015 | Computers & Internet
Internet not working
Make sure the router is set to DHCP to avoid any IP conflicts. This may be caused by connecting a switch before the router and blocking the routing table.
Jun 11, 2013 | D-Link Computers & Internet
I am using des1024d 10/100 eathernet switch.switch is working only 10minites & then it's hang after restart it work again for few times.
I will recommend to take the backup of the switch configuration.
Check for logs and make sure there is no loop in the switch ports.
Then log into the switch management and reset to factory default,
Once done then again load the configuration what you have taken as backup.
Jan 09, 2011 | D-Link Computers & Internet
Have a copier problem, in the small bussiness office i am troubleshooting, one office room cannot connect with the copier in another room, we have several routers and use 5,6 majic jacks for cheap phone...
The PC to connect with the Coppier needs below points.
The both the devices should be connected to network equipment ( Hub or Switch)
They must be in same VLAN.
As per your explanantion what I suspect that the PC and the coppier are not in same VLAN.
So you have to loginto the connected switch and check for the switchport status and then either change the switchport connecting to the PC to the VLAN of Coppeir or vice versa.
But I recommend to do this if you have enough knowledge on the switch configuration and VLAN assignment.
Jan 08, 2011 | Computers & Internet
3Com 4500 Gigabit ethernet switch hangs after 3 minutes. Has to be rebooted.
yes reboot and than it will run properly may be some load issue on your switch
Dec 14, 2010 | 3Com 4500G 24-Port Gigabit Ethernet Switch...
My d-link des-1024d fast ethernet switch is hanging problam
My First option is to restore the switch to factory default once and then reconfigure the switch.
What is the IOS running on the DES-1024D ?
Are you getting any error message in the log when the switch is hanging. ( through console connection).
Second Option is to upgrade the IOS to a recent one.
Dec 06, 2010 | D-Link DES-1024D Express EtherNetwork...
Doen Linksys sr224 support SRW224. I have SR224 & required one more switch...
Should be no problem. I would use the SRW224 as your main switch and hang the other one off one of its 100mbit ports.
Oct 19, 2010 | Linksys SR224 (srw224) 2x1000 Mbps...
Machine hangs and freezes.
check for viruses in the system, try to update virus database defintions engine, the keep full system scan hope it will works.
Mar 23, 2009 | Quintum Tenor DX6120 (501011900) 8x10/100...
Handing Problem
You might consider trying to upgrade the BIOS's on the affected switches
Aug 26, 2006 | 3Com SuperStack 3 4228G (3C17304-US)...
Dell VT1GD PowerConnect 5524 24-Pt Gigabit L3 Managed Switch Logo
24 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
