Question about Alphaline Bluetooth Headset for PS3
Wont sync or connect
I had in scanning for 15 min with light on bluetooth flashing and it wont pick up the bluetooth device
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 33 Answers
Maybe your bluetooth is duff in either machine... take it to a shop
Posted on Feb 17, 2014
Testimonial: "It was working one minute just fine than nada...Um...May sound a bit blonde to ask this but what is duff????"
How to connect the blue tooth head set to this phone
go to settings, wireless and networks, bluetooth.
make sure bluetooth is on.
turn on your headset, to sync the new headset, normally you have to turn on the device and continue to hold the power button until the headset goes into bluetooth sync mode.
normally around 10-15 seconds of holding the power button.
THen tell HTC to scan for devices. Your headset should appear. if it asks you to type in a code, it is generally 0000 or 1111
Feb 12, 2011 | HTC F3188 Smartphone
I bought a madcatz bluetooth headset for ps3 and it wont connect and let me scan. it was made in 2007. Any way I can fix it??
did it ever work for you are you holding the power-sync button long enough on the bt headset's load up light should stay solid or keep blinking till it sync's up start the ps3 bluetooth settings to start looking while you start to connect it hope that helps if not the bt set could be faulty try syncing it to a cell phone
Nov 17, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
How to sync my bluetooth?
Hold the power button down approx.
6 seconds until the blue indicator light turns on and remains
steadily lit. (The light will flash while you
hold the Call button.)
If the indicator light is flashing or does not
remain steadily lit, turn off the headset and
repeat step 1.
Go to your cell phone after you've done the above directions and:
Select (Menu) > Settings > Connection >
Bluetooth Link > Handsfree > Look for Devices.
The phone lists all Bluetooth devices it finds.
Select Motorola H500.
Press OK or Yes to pair (link) the handsfree
device.
Enter the passkey 0000 and press OK.
Note: Passkey cannot be changed
from 0000.
I hope this helps anyone else who's having a problem pairing their Motorola H500 Bluetooth headset :)!!! I just got mine to work w/ the same info!!!
-Rebecca :)
Dec 29, 2009 | Motorola Mobility H500 Wireless Headset
Cannot pair my emerson (em227) headset to my ps3
turn the device off (red LED flashes) then hold the button for atleast 10 seconds until both BLUE and RED LED flash aternatively... not just blue, pairing code is 0000
Aug 25, 2009 | Samsung WEP200 Headset
How to pair the bluetooth headset to the ps3
This is the info i got when i was looking to pair my headset with my PS3.
1. Turn your bluetooth headset on. It should flash on/off every few seconds.
2. Go to Settings > Accessory settings > Manage bluetooth devices.
3. Put the headset in "pairing mode".
4. Start to scan for the device. PS3 should pick it up. It will display the model if successful.
5. Once it's found it hit the options button. Connect the device (pairing mode) A blue icon will pop up.
6. Your headset will stop flashing meaning it has connected successfully.
7. Go back out and click on the audio device settings.
8. Input device > select "your headset". > output device > "your headset".
9. Hit the "connect bluetooth" icon. Then OK.
10. Your headset should now be successfully connected.. start talking into it to see the bar level move up and down to confirm its working.
Hope it helps.
Best Wishes,
Karlos
Jun 28, 2009 | Radio Communications
My bluetooth wont connect to my phone. ive connected it b4. you jus hold dwn the button until it flashes a few times to pair but its not workin. knw where i can find a users manual on line?
I GOT THE ANSWER FROM ANOTHER Z9 ISSUE RAISED BY SOMEONE.
HOLD THE RED BUTTON FOR A WHILE WHILE KEEPING THE NEW DEVICE IN BLUE TOOTH SEARCH MODE. THE BLUE LIGHT IN BA STAYS STEADY AND TELEPHONE DEVICE PICKED UP THE SIGNAL . PAIRING WAS DONE AS DIRECTED BY PHONE DEVICE.
Apr 28, 2009 | Blueant Z9 Wireless Headset
Bluetooth not picking up mp3
@psychurmine you may need to go into the settings of the actual music player application on your phone and tell it to output to headphones.
@ejr420hotora it could be several problems. Did you have it working at one point or is this your first time installing it? Is this your first bluetooth device or do you have others?
Feb 12, 2009 | Insignia Bluetooth Wireless Headphones...
Can't get to bluetooth setting on my garmin nuvi 750
The Nuvi 750 does not have Bluetooth capabilities. Simply put, there is no way to connect your phone with the Nuvi 750 via Bluetooth.
Dec 31, 2008 | Garmin (010-00583-00) for nuvi 750/760/770
I can't sync my Bluetooth Plantronics 220 to my Tmobile Dash...
I had the same problem which led me to this forum. The default passcode is indeed "0000". It could be paired to another device, or incorrectly. Shut down your phone completely, then turn off the plantronics by holding the power for at least 5 seconds, until you see a red light blink on the power. Then, turn the phone back on, turn the bluetooth back on by holding power for a second or two until you see a blue light blink. Then go into your phone and scan for bluetooth. While it is scanning, hold down power on the plantronics for a second until you hear a 'BEEP', then you will see it pop up on your phone. Connect to the plantronics, type in "0000" and hit enter, and it should work, did for me, at least. Age old problem with electronics, when they get confused, disconnect all power to them, and start over, works a lot of the time ;)
Jun 23, 2008 | Nokia 6030 Cellular Phone
Motorola H350 User Manual
On your bluetooth headset, hold down the power button until the light stays on steady. (it will blink when you initially power it on, but continue to hold for another few seconds for the steady light!) Your headset is now in pairing mode.
On your RAZR, press Menu > Settings and Tools > Connections > Bluetooth > Handsfree > Look for devices. Your phone will then scan for any bluetooth devices that are in pairing mode. When your headset pops up on the list, highlight it and press ok to connect.
If the device asks permission to bond with the phone, select yes. It will then prompt you for a pin code. The pin will be 0000 .
Jan 08, 2008 | Motorola Mobility Bluetooth Hands Free...
Alphaline Bluetooth Headset for PS3 Logo
100 people viewed this question
Top Alphaline Radio Communications Experts
eradiostore
eradiostore
Are you an Alphaline Radio Communication Expert? Answer questions, earn points and help others
