Question about Food Mixers
Blender part falls off doesn't stay on shaft - Food Mixers
    Novelist:
    Scholar:
  • Food Mixers Expert
  • 134 Answers
What is the brand and model number of the mixer?
Posted on Mar 20, 2014
KP26M1XMR beater shaft falls off
The beater shaft on the 6 quart mixers is part of the planetary assembly. The planetary and center shaft are pressed together, and sometimes they will come apart. The only way to fix this is to replace the planetary or you can have the planetary machine pressed back together.
It is a lot cheaper and less expensive to just replace the planetary. Here is a link to the Planetary Assembly on our website. http://www.mendingshed.com/9708662.html
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Feb 18, 2013 | KitchenAid KP26M1XMR Professional 600...
Braun Vario 280 Watt type 480 hand held blender. The bowl top that the hand mixer fitsd into is frozen. The hand held motor works but the shaft in the top that turns the blade is frozen. I don't...
HI.This steps might be as well helpful.let me just clarify that you can't even manually twist the shafting.If the motor is working an yet it will not turn the shaft.Tha shafting bossing might as well been broken misallign inside..Better remove the cover by unscrewing it and then try to observe how the motor works.If it really does turn when ever it is plugg on to the source.Observe also misallign bosssing that connects the shafting and the motor's rotor.Thank you for choosing FIXYA.
Aug 16, 2011 | Braun M880 MultiMix Hand Mixer
The rotating head on the mixer keeps falling off. how do you get it to stay on? it comes off when were mixing.
The Planetary plate comes attached to the shaft from the factory. It is not supposed to get
loose and come apart but it often does due to the mixer's vibrations and the user's constant
attaching and removals of the flat beater, wire whip or dough hook onto the beater shaft.
Try to remove the Planetary plate first : Gently rock it from side to side while pulling on it
to separate from the shaft. Notice the groves on both the shaft and inside the planetary
housing. That is how they are attached to one another at the factory (just friction, no screws
or pins). Now for a permanent solution:
Take a trip to Home Depot or Ace hardware and buy the J-B Industro Weld Compound
(Not the 5 minute type). Mix an equal amount from both tubes (Black and Red). Use a Q-Tip
and apply a thin layer of the mixture on both the shaft (grooved section) and inside the
planetary housing. Now re-attach the planetary plate to the shaft. Use a long strip of duct tape
to hold the plate in place (to prevent it from falling back out). Allow the epoxy to dry overnight
or at least for 8 hours.
The Planetary assembly is now permanently attached to the shaft of the mixer.
Jun 10, 2011 | KitchenAid ProLine 600 Stand Mixer
I seem to have lost the instruction manual for my mixer. I would like to use the immersion blender, but I can't figure out how to attach it to the mixer body. The shaft on the blender is too short to...
Hi
The blender does not attach to any of the two holes for the whisks.
You need to push back the sliding cover in the center, bottom part between and behind where the whiskers attach. This will uncover a third attachment possibility, where you insert the blender and twist it a quarter turn into place.
Dec 13, 2010 | Braun M880 MultiMix Hand Mixer
Kenwood Chef A701A Blender needs new shaft seal
It uses a different thread = turn clockwise to undo - not the normal turn ccw to undo and the nut is attached to the 2 blades.
Jan 11, 2009 | Kenwood KM300 Chef Stand Mixer
I can't remove the blade from my Bamix hand blender
Shaft should be free for rotation that is ok.
Blade will come off with determined force of pull make sure grasp blade with towel to prevent injury to the fingers.
Dec 13, 2008 | Bamix De Luxe Hand Mixer
Gear cap which attaches to the drive spindle falls off
there should be a lip on the shaft that hold this up. You insert the shaft from the bottom and a pin goes through the gear to hold it in place. Look at the IPB HERE.
May 25, 2008 | KitchenAid KP2671 Professional 6 Series...
Food Mixers Logo
Top Food Mixers Experts
eyecam
Are you a Food Mixer Expert? Answer questions, earn points and help others
