Question about Ovens
Trying to re-assemble over door for Westinghouse EW100
I have taken door apart and now need to re-assemble
How can oven door glass be cleaned?
The window is comprised of two pieces of tempered glass with a metal band seal around the outside. Because the metal and the glass have different rates of heat expansion, material expelled by baking items finds its way past the seal and in between the two pieces of glass. As a practical matter, it is better to live with the dirty window than to risk destroying the oven door to remove and clean it. Besides, if you were able to remove the window assembly how would you remove the metal seal, separate and clean both pieces of glass, and reassemble?
Apr 05, 2016 | Ovens
How do I fix my Westinghouse Oven
Hello Leonard;
My name is Peter. I am a retired Sears field service appliance technician.
The fault codes start with a "F'. The Do may mean Oven Door.
When you close the oven door is it loose at the top and not completely close?
If this is the case you have a bad oven door lock assembly (Part number W10195934). The assembly has a micro switch which activates a 1/4 turn motor.
The part if ordered locally will cost you $108.00 plus tax. If this is the problem you can search the internet and probably get it for $70.00.
If you call a Sears service technician it would be $108.00 x 2 plus $140.00 labor.
To access the door lock assembly, you need to remove the oven wall restrainer strips, Pull the oven out about 4-5 inches.
Go into the following website plug in your model number to see your oven diagrams.
This is a common failure.
Good luck,h
Water Filters Lawn Garden Appliance Parts
Jan 29, 2016 | Ovens
Can you please tell me how to remove the oven door?
If you are trying to clean between the inner (heat shield) glass and the outer glass (safety glass for looks), you may not have to remove the whole door. On most models, the outer glass is either integral to the handle and frame or at least is trapped by the handle and frame. Open the door and look inside. There should be either two or four screws right at the top that hold the handle and frame assembly in place. You may find that when you take these off, the handle slides off, and the glass can either slide up or the whole frame will rock outward. Be VERY careful, this is safety glass and shatters into 2mmx4mm pieces easily if you bump it.
If the whole door has to come off, most new models don't even need screws taken out... you just pry up the two metal tabs next to the hinges, and it unlocks and you slide the door up off the hinges. See the link for instructions if you need to remove the door and take it apart. This covers most oven doors.
Cleaning between the glass of an oven door Frigidaire Jim Carson
Jan 02, 2016 | Ovens
How do I clean inside double panes glass in oven
the door will have to removed and taken apart. Different stove ovens doors come apart differently. be careful and lay the door down on a sturdy surface when taking the door apart.
Oct 04, 2014 | Ovens
Frigidaire oven door glass clean inside
Good Morning Suzi - Generally, qualified technicians often perform complicated part replacement such as this, however this may or may not be specifically for your model. Below are generic instructions that I found on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Tools needed: Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. Refer to owners guide with door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
I hope this information helps to some degree.
May 24, 2013 | Frigidaire 27 in. Electric Double...
Westinghouse oven does not close fully.can door hinge be adjusted?
If it has a drop down door, the only solution is to replace both door hinges, if it is hinged on one side, then the door catch, or door striker could be worn, these are easily replaced,
Please rate my solution.
Thanks.
Oct 31, 2009 | Ovens
Is it possible to clean between the two pieces of glass on the oven doors?
You would need to take the door apart, and even then the glass isn't really made to be taken apart. So it COULD be done, but it would be easier to buy new glass and replace it. It all depends on how much you want it to look clean.
Jun 10, 2009 | Frigidaire 30 in. Electric Double...
Spills in between glasses of the oven door.
The door must be taken apart at least most of the way to clean glass. Just so you know, this is a problem with a LOT of the newer makes and models. If there are 2 screws behind the handle, take them out and some of them come apart enough to get your hand a paper towel in to clean. Otherwise, the door must be removed and completly diss-assembled.
Mar 23, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
How do I replace the inner glass on the oven door? I have taken the door off and it is apart, but the glass assembly looks to be one piece. How do I remove just the inner glass for replacement? JenW30400W
moz-screenshot-7.jpgmoz-screenshot-8.jpgTo replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
See diagram below , click on picture to enlarge:
Part here: _.gif PS2087058
Mar 14, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Ovens Logo
51 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
