Question about HTC Cell Phones
HTC T320e One V screen replacement
Which replacement screen do I need to order for this phone? Also is it fairly difficult to replace yourself? Or should I take it in to a cellphone repair shop instead?
    Sergeant:
  • 166 Answers
You want to Google HTC T320e screen replacement and find a YouTube video of the process. You can then decide if you can do this. Hint: When you order the replacement part, order the kit with the tools. The torque screwdrivers are small and hard to find at hardware store.
Posted on Feb 17, 2014
5 Suggested Answers
  • 277 Answers
SOURCE: wet phone
hi take apart the battry look in the battry socket, there are "star" screws inside buy a screwdeiver with that head open the shell(after removing the screws) gently shove a flat blade in the side shell if you will use force you will brake the little tabs which holds the two half shells in place opened it ? good seek for corrosion on the little soldering clean it all WELL!! take a spry conductor and give it hell check if the other mic fits and works... if not buy a brand new 1 assemble the whole thing togheter (gently) good luck
Posted on Apr 09, 2006
IrishDruid
  • 2712 Answers
SOURCE: Replacing a LCD screen for a cellphone-Sanyo 8300
Yes, you can transfer pics to your PC. You will need a USB cable (that must have come with your handset).
Simply right click on 'START' button on your PC, and select 'Explore'.
Next scroll down on the left panel and find the drive that corresponds to your device . (It will usually be found after your DVD/CDROM drives). Now click the (+) next to the entry to expand the folders. Browse to the folder that holds your pics, right click and select (use right click and CTRL button to select more than one photo) and copy.
Next browse to a folder on your PC where you would like to store the pics, right click and paste.
You can delete files/pics from your device in the same way.
However, to accomplish all this, your device will have to be detected by the PC, and in some cases, you may have to install the device software on your PC to accomplish this.
Another alternative, is to transfer all the files on your phone to your memory card. (Please read instruction manuals on how to do this, as procedure varies from phone to phone). Now using a card reader attached to your PC, you can transfer files in the same way as described above.
Replacing the screen can be a bit tricky if you are not experienced in this, and best left to a professional..
Hope that helps. And don't forget a Fixya rating if my solution helped in any way !
Cheers!
IrishDruid
Posted on May 26, 2008
SOURCE: Need step by step instructions on repairing htc fuze LCD screen
you can open your phone, and then replace the it yourself, you can just buy it in our online shop. it is cheaper and easy. And if you need, we can provide the instruction guild.
thanks
Posted on May 13, 2010
  • 189 Answers
SOURCE: i need a replacement screen or a repair shop to
send it to me call me 09025048459 yog (chennai)
Posted on Jun 28, 2011
Htc one v reboot
Hi Melissa, can you describe the problem please?
Sep 28, 2013 | HTC Mobile Phone One V T320E UNLOCKED
How to restore HTC One V T320e smartphone
Performing a factory reset using hardware buttons
If you can't turn HTC One V on or access settings, you can still perform a factory reset by using the hardware buttons on HTC One V.
1. Press and hold the VOLUME DOWN button, and then press and hold the POWER button.
2. Wait for the screen with the three Android images to appear, and then release the POWER and VOLUME DOWN buttons.
3. Press VOLUME DOWN to select FACTORY RESET, and then press the POWER button.
[img title="unlock HTC ONE V hard reset forgotten password" alt="HTC ONE V hard reset" src="http://www.hard-reset.com/images/htc_one_v_hard_reset.jpg" height="350" width="180">
will remove any applications you've downloaded and installed. Be sure to back up
any data and files you want to keep before you do a factory reset.
Performing a factory reset from settings
1. Slide the Notifications panel open, and then tap Settings.
2. Tap Storage > Factory data reset.
3. Tap Reset phone, and then tap Erase everything.Performing a factory reset via settings
The most convenient way to do a factory reset is via the settings.
1. From the Home screen, press MENU, and then tap Settings.
2. Tap SD & phone storage > Factory data reset.
HTC One V not responding?
If HTC One V frozen and does not respond when you touch the screen or press the buttons, you can still restart it by press and hold the POWER button for at least 10 seconds, and then release it. HTC One V then restarts.
Sep 26, 2013 | HTC One V T320e - 4gb - Grey Unlocked...
Htc dead,won't charge
htc v t320e dead plz give the salution
Jan 20, 2013 | HTC One V T320e - 4gb - Grey Unlocked...
Can I get the cracked screen of my HTC desire HD with sence fixed... How much?!?
You must buy the replacement screen online for about $30. After you purchase the screen you must replace the screen yourself.
You can find the instructions to replacing the screen here:
http://www.ifixit.com/Answers/View/53084/How+to+replace+the+HTC+Desire+HD+glass
Jan 03, 2012 | HTC Cell Phones
Yesterday my phone fell down and the screen shatter ,could it be repaired or i have to discard the phone
Several companies offer to fix your phone for a small fee - for example www.htcphonerepairs.co.uk
Another option is to do it yourself. Parts can be bought from specialist websites, but you will have to perform the screen replacement yourself.
For example: http://www.mobilefun.co.uk/htc-hd2-replacement-touch-screen-p23734.htm
Mar 26, 2011 | HTC HD2 Smartphone
Screen is cracked
http://www.ownta.com/original-htc-g1-cell-phone-reparing-lcd-display-screen-replacement.html
This is what you need, just fix it by yourself, if you know how to repair.
May 27, 2010 | HTC G1
I have a replacement screen, how do i take phone apart?
thanks
Apr 30, 2010 | HTC Touch HD Smartphone
thanks
Sep 01, 2009 | HTC FUZE Smartphone
Cell Phones Logo
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
