Question about Saeco Talea Touch 14-Cup Coffee Maker
Cannot stop watr priming on start up saeco talea touch
dutchman05
  • 487 Answers
SOURCE: Saeco Talea Ring Plus
ok with a machine you have already for a while :
Putt descaling solution in the machine. unplu the machine and open the watere valve. Aftre about 2 days it should have desolved.
BUT>>>>>>>>>> what also can be is that the valve on the bottom of the water tank is not working.
Fill it a little and wiggle the valve until water comes out and than try again.
Priming normally goes.
Water in tank. push water button and open valve.
Posted on Jun 03, 2008
SOURCE: Saeco Talea Ring Plus not frothing milk
per il milk island asciugare bene la valvolina e tutti i fori del blocco di plastica che fa da montalatte devono essere perfettamente asciutti dare dei colpetti alla valvola per fare uscire eventuale acqua all interno.
MORENO
Posted on Apr 12, 2009
SOURCE: Doesn't start up properly...
Actually I decided to day to deliver to a service point for Saeco in Warsaw ,Poalnd.
Anyway ,thank's..
Best regards
Johnny
Posted on May 15, 2009
SOURCE: Error Code 4 on Saeco Talea Ring
I need to know what error code 4 means as well.
Has anyone helped you yet?
Posted on Jul 27, 2009
  • 20 Answers
Grinder motor is not working.When the machine do the self test on startup, it senses the grinder motor is in open circuit(error 1).
Have to replace the grinder motor.
Remove the coff beans hopper.then..front spout by pulling the knob off and undo the screws...lift the top cover up from the back to unclick then pull the front part towards you from the center then slide over the spout area. You will see the grinder is covered with rubber cover with 4 screws holding it...remove the screws and then push down the rubber protrution through hole to detach from the grinder.The grinder is yours.
Posted on Dec 23, 2009
What to do when prime water curcuit comes on
When prime water circuit comes on turn on the steam/water valve may need to select hot water the machine will run water until primed
Nov 16, 2014 | Saeco Talea Touch 14-Cup Coffee Maker
Saeco talea giro flashing red exclamation point
take out the coffee waste bin, on the side facing into the machine, there's a little metal bit, it's a kind of sensor.
Clean it if it's dirty with a screwdriver or some wire wool.
Have you cleaned the brew group lately?
Sep 06, 2014 | Saeco Talea Giro Espresso Machine
How do u prime the pump for saeco talea giro plus expresso machine
Should be just a matter of switching the machine off, if it doesn't prime then switch off, leave a few minutes and try again *obviously making sure there's water in the tank....
Jul 16, 2014 | Saeco Talea Giro Espresso Machine
My Talea touch plus is struck in the cleaning cycle after a de-scaling.
Normally it drips at the beginning and then becomes a steady stream throughout the shot. The truly determining factor is how fast the shot is coming out. You want to get 2 to 2 1/2 ounces of espresso in 20 to 25 seconds. If it's coming out that slow it's going to be a lot longer, and odds are the grind is still a touch too fine still. Sounds like you need to just tweak a bit to get an even better shot. Also, keep in mind with the Saeco supers, there is a 2-3 shot delay in changes you make in grind before it makes an effect.
Jul 22, 2012 | Saeco Talea Touch Plus Automatic Espresso...
My Saeco Talea Touch machine stopped working this morning after a first cup of coffee. The error code on the screen said Restart to solve the problem (with a wrench key). I restarted the machine but the...
Had the wrench icon problem on a used Talea Touch that I bought.
Don't know how it started with the previous owner.
Solution - cleaned compressed coffee grounds from the grinder discharge. You need to manually spin the motor to clean all grounds from the rotation discharge gate.Also needed to probe and press the electrical connections to the motor. The brush spring and capacitors are press connected.
This solved the problem.
I've owned abnd repaired many Saeco machines. They are poorly designed and over priced.
None the less the majority of their problems can be fixed by simply cleaning the components.
Enjoy
MDR
Sep 08, 2011 | Saeco Talea Touch 14-Cup Coffee Maker
Seaco talea ring plus Q: what i have to do when
Press hot water button and open valve to run the pump.
Aug 22, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Anyway ,thank's..
Best regards
Johnny
May 14, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Talea Touch - Drip Tray not raising/lowering smoothly
It can be the sensor or the engine that have to be replaced:-(
Best regards
/Mirran
Sep 08, 2008 | Saeco Talea Touch 14-Cup Coffee Maker
Saeco Talea Touch 14-Cup Coffee Maker Logo
13 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
