Question about ASUS K8V-MX Motherboard
Usb too low - ASUS K8V-MX Motherboard
How to charge low battery
The Nuvi uses a standard USB connector. You can try charging it with the USB cable attached to your computer or to a USB phone charger. If it still won't charge fully, the battery needs replaced.
Oct 27, 2015 | Garmin Nuvi 255WT 4.4 in. Car GPS Receiver
Signal strength went from Good to Low
Either move the computer closer to the router or the router closer to the computer. You could also try connecting the usb adapter to a usb hub to remove any interference from the computer.
Mar 19, 2014 | Belkin Basic Wireless N150 USB Adapter
How can i remove my write protect from my usb drive?
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format usb drive
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Feb 16, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I can't get my card reader to work on my pc
when plugging into a USB you'll hear one of two sounds
a sound from low to high or a sound from high to low
the low to high sound it that the USB is working fine
the high to low means the USB is not working , on
another note SanDisk uses a utility on everyone of its
cards a troublesome utility that is not easily worked
the older it is the less performance it will have , but ultimately the sound has to be there the sound is the
computer recognizing the plugged in device which you'll find in my computer .
Jan 14, 2010 | SanDisk MobileMate SD Plus 5-in-1 Media...
Dear sir, I cannot format my 8Gb USB removable disc...while the formating its says that ur disc is protected...how can format then?
2. Format
Nov 11, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
High Speed USB Port
This list of cardbus adapters on ebay should do the trick for you. You would have to use a pcmcia device (hopefully you have a slot available).
Mar 01, 2009 | Compaq Armada 110 Notebook
2009 map update for garmin c330 street pilot
Perhaps your are using a low speed USB port. I once use the low speed USB and does not work. This unit only works in high speed USB. Hope this will help.
Dec 31, 2008 | GPS
All in One psc2210xi printer
Hello, the electrical spike may have also affected your pnter's USB port or worse. Does it copy/scan/fax ok? Try using the one of the USB ports from the back of your computer. USB printers do not like low speed, low power USB ports. Are you using a USB hub or plugging it into a usb port on your keyboard? I doubt the cable is bad, but check it carefully for any black marks on both ends. Have you tried other USB devices on this newly rebuilt computer? Good Luck!
Sep 23, 2008 | HP PSC 2210xi All-In-One InkJet Printer
My YP U3 don't turn on
DONT TROW IT AWAY!!!!!!!!! push hold buton and the play/rec butons, this will reset your system, and than! tcharã! ok again!
Apr 03, 2008 | Samsung YP-U3 MP3 Player
SAMAUNG-YP-Z5,LOW-BATTERY
Try getting a new USB Cable.
I myself have had the Same Problems.
And that seems to help.
Feb 10, 2008 | Samsung YP-Z5 MP3 Player
ASUS K8V-MX Motherboard Logo
14 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
