Ibm 6734-ac1 tft stars but within 3 to4 seconds display goes off
5 Suggested Answers
Fix-4U
  • 293 Answers
SOURCE: monitor stops display
Hi...there,
It's seems your LCD Monitor backlight inverter it burnt out. Need a new inverter. Have a nice day!
Posted on Sep 08, 2008
alfa104
  • 78 Answers
SOURCE: No Display
Please look here..and vote me if its works.. http://images.google.nl/imgres?imgurl=http://mperlitsch.hintergrundbild.com/hp/HP1702_klein.jpg&imgrefurl=http://mperlitsch.hintergrundbild.com/hp1702.htm&usg=__Iw4raAzsQ1z20fR0DP2JRRwJYCw=&h=306&w=300&sz=27&hl=nl&start=3&um=1&tbnid=pVFWk-IRYjVy5M:&tbnh=117&tbnw=115&prev=/images%3Fq%3Dhp%2B1702%2Bmanuel%26hl%3Dnl%26lr%3Dlang_nl%26sa%3DN%26um%3D1
Posted on Jun 14, 2009
budmrtn
  • 11361 Answers
SOURCE: When I turn on my
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Mar 22, 2011
SOURCE: need a service manual for an IBM 6734-HB0 Monitor
MY IBM monitor is very dark screen even in setup menu at the start
Posted on Jul 24, 2011
My lcd is hpl1908w its display goes of 5 minutes on first starup and when its displays goes off i on and off the monitor display comes for fews seconds and then goes off again lcd light is green but...
well if your lcd has no bulge capacitors test your tft lamp both top & down of the screen( particularly top) with spare tft lamp. or use another screen to test it. secondly, test the c5607 transistors in the inverter section but if you know how to use spare tft lamp very well , you will easily detect between your screen & the inverter
Aug 06, 2015 | HP L1908W 19" LCD Monitor
Lenovo 9227ac1 comes on then goes black light on front stays green
When it have this kind of error is a problem of the power-board.
Anyway you must open it and look at the all capacitors and if are them inflated, if them are inflated must change them.
But can be a problem with inverters... control the transistors - MOSFET on the powerboard.
Mar 22, 2014 | Lenovo 17" Thinkvision L171 9227-Ac1 Lcd -...
I have a type 6734-LB1 17" Lenovo ThinkVision
where will i get to install the software/drivers of IBM 6734-L-B-1 for listening Music
Sep 30, 2011 | IBM L170M (Black) 17 in. Flat Panel LCD...
Monitor IBM thinkvision 6734-ACO 17", turn OFF
Sounds to me your high voltage powersupply is out. To repair open monitor and remove high voltage powersupply. Inspect the caps on the board. Look for the ends of the caps to be mushroomed out. Replace these caps, usally 470 uf caps. Replace with 25volt caps. Might also be some 100uf caps as well. This is a common problem with all LCD monitors.
Jul 22, 2011 | IBM Computers & Internet
My IBM ThinkVision monitor flickers the correct display then blacks out. The light goes green a moment, then goes amber with the blackout. I think it may be stuck in the Energy Star/Power Saver mode. Is...
skeltonh, Have you connected your L170 to a different "known-good" PC that has ALL power-save and screen saver modes disabled? Have you connected an old monitor to your PC to see if it will act same way as the L170? 12fixlouie
Jul 31, 2010 | IBM ThinkVision L170 17" LCD Monitor
Need a service manual for an IBM 6734-HB0 Monitor
Jan 26, 2010 | Computers & Internet
Gateway Monitor goes blank after a few seconds after startup.
Sounds like the inverter is broken or have a short circuit. This is a common failure on TFT displays.
Here is a website explaining this kind of failure:
http://josepino.com/?howto-repair-dell
Oct 09, 2009 | Gateway FPD2275W LCD Monitor
Hi, audio goes off after few seconds for IBM T42.
You may be installing the wrong verision of the driver or installing it the wrong way.
Jun 19, 2009 | IBM ThinkPad T42p: T42p Pentium M 1.8GHZ,...
Red Green stripes on IBM Thnikpad T60p tft monitor
Those are dead pixels if you want to get rid of them you will probably need to replace the monitor. They will probably charge you an arm and a leg to replace it so you might get a second quote from Computer repair shop.
Jan 31, 2009 | IBM Lenovo ThinkPad T60p Notebook
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
