Question about Taylor Ice Cream Makers
Barrel too hot - Taylor Ice Cream Makers
WHAT IT MEANS R-HPR THERMAL FAIL FOR TAYLOR ICE CREAM MACHINE MODEL C713
That code means the right side hopper thermistor probe has failed. That is the sensor that reads the temperature of product in the mix hopper.
This is the part you need:
http://www.softserveparts.com/i-26471492-thermistor-probe-c712-c713-barrel-stanbye-probe.html
If you order it from us, I would be happy to put a technician on the phone to help you install it yourself.
Aug 01, 2017 | Taylor Ice Cream Makers
Had a "comp on too long" message on the machine
this is normal if you just started the machine up from room temperature to freeze a batch, just reset it and it should not reappear , if you didn't and it's been running for days then your refrigerant is low or your cooling tubes are blocked with goo
Oct 20, 2015 | Taylor 2008 C713-27 Soft Serve Ice Cream...
On the soft Serve side of my Taylor ice cream machine it is freezing up and not letting any product come out pump still works don't know what the problem is I take everything apart clean it put it back...
if the product is frozen in the barrle for sure then you have a bad micro switch that is telling the compressor to keep running, but that product would be super frozen and come out in the shape of the barrel. if it is the consistancy of ice cream then your pump gasket might be bad and not properly pressurizing your barrel and giving you the impression of a frozen barrel.
Feb 19, 2015 | Taylor Ice Cream Makers
Product comes out frozen after all night on standby in a 754 taylor
The same thing happened to my Taylor 8756 and it was the thermistor probe. The probe is a thin copper tube that is near the freeze cylinder. It cost me about $20 for the part and $200 for the labor to have a technician put it in. Hope this helps and good luck.
Apr 18, 2014 | Taylor 2001 754 Air Cooled Soft Serve...
Chocolate ice cream has turned a funny color and that side is running loudly
A grey color often indicates the beater bar is grinding on the inside of the barrel. What you may be seeing is metal. Be sure your beater bar is not bent. Visually inspect the inside of the barrel for marks. Wear is not normal. If you see wear and the beater bar is not bent, be sure all plastic bearings and components are installed. Also, it is normal to have some drip and lube in the drip pans, excessive amounts usually indicate problems though. Hope this helps you.
Mar 14, 2013 | Taylor 2008 C713-27 Soft Serve Ice Cream...
Drive shaft stuck
if you can't get it out thru the barrel then you will need to remove the gear box behind the shaft and push it out that way. you should align the shaft afterwards to not rub also make sure your not lubing the bolt pattern on the shaft. after its out use the cleaning brush and clean the coupling.
Mar 02, 2013 | Taylor 794-27 Soft Serve Twin Twist Water...
Barrel Therm Bad, keeps beeping on right side
Pretty much what it sounds like, the thermometer in the freezing chamber (barrel) died, and you can't operate until it is replaced. Drain all yogurt and clean and unplug. You need to call a technician out; call 800.255.0626 to find out your local service center.
Sep 15, 2012 | Taylor Crown C713-27 Soft Serve Ice Cream...
My barrel on my white mountian ice cream is leaking from the seams of the wood. it is only one year. its not allowing the brime to come from weep hole
The wood will shrink when it is dry. It will swell up and close the seams if kept wet. Place the barrel in a container and fill with water inside and out to get the seams to swell and close before you use the freezer to make ice cream.
Jul 19, 2009 | White Mountain F69206X 6 Quart Ice Cream...
Ice Cream Makers Logo
29 people viewed this question
Top Taylor Ice Cream Makers Experts
Dennis Boxerman
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Taylor Ice Cream Maker Expert? Answer questions, earn points and help others
