Question about Delonghi DC514T 14-Cup Programmable Coffee Maker with Glass Carafe -
PAC N125HP has switched off and is not working.. On off button flashes
We have unplugged unit, cleaned filter and checked extractor pipe fitting
  • 65 Answers
Check the heating element. Use an ohm meter to check it. The reading should be 0 - 150 ohms. If it reads a much higher number or a 1, the element is no good.
Posted on Apr 26, 2014
Codes
Flashing E-1 means your thermistor, a device attached to your thermostat that detects room temperature is shorted or broken. Replace or rewire thermistor. First turn power off to it. Second, clean air filter or replace if worn. Third, hit the reset button or scroll through menu until you find reset to factory settings. If no button or menu to scroll through unit then keep unplugged for 8 hrs to reset it. After that plug back in and power on and see if the e1 goes away. If not I recommend having it serviced. Also the owners manual is saying no pipe check operation check, try operating in auto addressing mode without pipe check. Sloution to check setting. Check piping connection and setting.
May 01, 2013 | Samsung MH050FXCA2A Free Joint Multi...
The tumble dryer bip and flash "empty water" even if no water. I have cleaned every filter (2 inside the big filter at the bottom of the tumble dryer) but still have the trouble
I want to first make sure that your dryer is serviced up. so i want you to do these steps.
Most of the problems will be resolved doing these......
As clothes are tumble dried, they drop fibres. Most of this fluff is trapped by the lint filter and this needs to be checked and cleaned regularly. Lint also builds up in the vent pipe and around the electric motor in the rear of the dryer.
1.clean lint filter
Wait until the dryer cools, open the door and lift out the lint filter.
Gently brush off lint using your fingers.
On many models, the filter may also be washed. Check your manual for instructions.
If the filter is damaged in any way, you should replace it.
2.Vacuum area where lint filter sits:
The area where the lint filter sits should be vacuumed .
Remove the lint filter, and use a narrow vacuum nozzle to remove dust and lint from the fitting.
3.Clean inside the tumble dryer:
1. Make sure the dryer is cool, switch it off and unplug it.
2. Unscrew the retaining screws on the back panel, and lift it off. Vacuum the blower area.
3. Also vacuum around the vent pipe connection.
4. Replace the back panel and refit all the screws.
4.Check tumble dryer vent hose:
8d2299a.jpgWait for the dryer to cool. Unplug the vent hose and inspect its entire length for snags in the pipe.
Make sure the vent is not obstructed on the outside wall, and fit a flap or screen to keep out small animals.
If your vent pipe is punctured or damaged, you should replace it.
To avoid dryer problems,
Make sure the dryer is level and does not rock, and consult the manufacturer's instructions for the maximum weight of clothing to dry at one time. Also, make sure clothes have been spun-dry before putting them into the dryer.
This is just initial help,
Post your comments about how things turned up, Ill be giving suggestions based on your reply........
Thanx for using fixya,
Cheers.
Sep 27, 2008 | LG Dryers
Grohe 42774 problem
Switch Off Supply Remove Pipe Going To Unit, Inside You Will Find Small Filter ,Clean Filter Replace And Re Fit Pipe .
Turn On Supply Check For Leaks, Rectify If Necessary. Problem Will Be Solved
Jan 27, 2013 | Grohe Home
Unit will not get cool, missing 1 of filter compartments and condensation canister, is that the problem?
Most units will not operate without the drainage tank in as there is a switch where the tank goes which hold the unit off fit the tank and the unit should start the filter will not cause the unit not to work but over time the coil will choke up
Jul 03, 2011 | DeLonghi Pinguino PAC-75 Air Conditioner
Galvanized nipple broke off in fitting
Hi grumpy, W/D here.
The easiest way to get a broken nipple out is to use a nipple extractor. It works like a bolt extractor, but has lobes that extend when you turn the end. I bought a set at a piping supply house for ~$10. This has 3/8", 1/2" and 3/4" extractors in it. If you do more than just a little pipe work, they're worth buying. I don't know the cost for a single extractor but they should be available too. Call ahead!
Best regards, --W/D--
Jan 14, 2011 | RTO Southland Pipe Nipple 10201 Galvanized...
2001 jeep wrangler oil pressure sensor switch broke - cannot get piece out if housing unit - how do i get it out or can i replace the whole housing
Use an extractor designed for removing broken pipe fittings and broken bolts. They're often called bolt extractors and are available from tool merchandisers. Sears probably sells them as well as auto parts stores.
Jan 14, 2010 | 2002 Jeep Wrangler
Delonghi pac w160a...''no water symbol'' stops on in airconditioning mode even though water tank is full
In the back of these units where the cord pulls out, there is usually a red reset button, try pushing that to reset the unit, also make sure the filter is clean, pulls from the top out of the unit. Make sure the coils are clean as well behind the filter.
Good Luck!
Nov 12, 2009 | DeLonghi Air-To-Air Portable Air...
Delonghi pac-02 a/c
I had similar problem .... on very humid days unit leaks ..... temp solution for me was to drain the unit .... inserted wire coat hanger into tube .... lots of watery gook came out.. - even tilted/tipped the unit inorder to get as much water out of it.......afterwards unit worked fine.
We are VERY SASTIFIED with the Delonghi Pinguino - bought it years ago when it first came out and it has provided years of troublefree service .... the water build up / leaking was only recently - in fact we never drained the thing until this year.
Aug 23, 2008 | DeLonghi Pinguino PAC-02 Air Conditioner
Error Message
It's actually "Ft", which means "Full Tank".  The instruction manual says to drain the internal safety tank through the drain hoses.
To drain the tank, open the cover on the rear of the appliance. Pull out the 2 drain hoses, take off the caps, and let all the residual water flow out.  When all the water has been drained, place the caps back on the hoses and put the hoses back inside.
It also says you need to clean the filters and let them dry thoroughly before putting them back.
This is also the procedure for "End of Season Operations."
Hope this helps!
Jun 05, 2008 | DeLonghi Pinguino PACL90 Portable Air...
Dryer won't work, Check Filter light is on
I had exactly the same problem with my newish LG dryer. I deduced that the dryer's computer essentially needed to be rebooted. I pulled the plug for a minute or so, then plugged it back in. It works perfectly now.
Mar 11, 2007 | LG DLE2514 Electric Dryer
Delonghi DC514T 14-Cup Programmable Coffee Maker with Glass Carafe - Logo
32 people viewed this question
Top Delonghi America Inc Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Delonghi America Inc Vehicle Part and Accessory Expert? Answer questions, earn points and help others
