Question about Grundig S350 AM/FM/SW Radio
Set time grundig s350
How to set time
memturbo
  • 226 Answers
SOURCE: I need only the antenna for a Grundig S350 Radio.
here
Posted on Mar 27, 2009
kb8dns
  • 494 Answers
SOURCE: I also have a broken antenna and need a
Call Eton, look it up on a Google search
Posted on Feb 09, 2010
kb8dns
  • 494 Answers
SOURCE: dropped my portable grundig s350. Stopped working
Anything could happen in a fall, no telling what needs attention, could be a bad battery connection a cracked circuit board. If it is under warranty send it in if not a good technician is needed.
SOURCE: Looking for inexpensive shortwave antenna for
Simple wire can make a great antenna, and it's relatively inexpensive. I've had the best shortwave and AM reception thus far using a long loop (actually a rectangle) of copper wire as an antenna (but folks shouldn't try a loop with some radios designed for use with powered antennas without inserting an appropriate capacitor in series). If you do try wire, you would want to try to make the loop shape as large as possible, and connect the ends of the wire to your radio's antenna connectors.
Posted on Apr 08, 2010
hmerchant110
  • 7191 Answers
SOURCE: I need the technical manual for the grundig s350.
You can download and print the instruction manual in PDF format from:
http://www.etoncorp.com/product_card/?p_ProductDbId=6282
Here is the direct link to download the manual:
http://www.etoncorp.com/upload/contents/307/S350_manual_lowres_GRUN.pdf
Adobe PDF Reader is required to view this manual. Click here to download the latest version of Adobe Reader.
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Posted on Sep 25, 2010
Dewalt service center
The Grundig S350 (DL) runs on one of three power sources: electrical outlet, DD batteries, and AA batteries. There is a switch in the battery compartment that permits to change battery type. I do not know how different the S350 and the S350 DL are, but you should try to find out if it works with any of the two battery types before having it serviced. Clean all contacts of any acid corrosion. Check the manual to see if you have to specify the battery type in the setup too.
Feb 05, 2014 | Grundig Audio Players & Recorders
My Grundig s350 radio powers off as if it is on some sort of timer. I cannot figure out why or how to stop it.
The ON button is also a SLEEP timer. The timer can be set to 90 minutes, 75, and son on. The shortest time period is about 1 minute. Press the ON/SLEEP button several times. After each press read the number displayed. As you push the button again you will cycle through all available timer settings. Choose one that its long enough for you.
However if you press the ON/Sleep button for a few seconds the radio will play continusously until you turn it off.
Just play with the RED button a few times to get an idea how long to press to make the radio play continuously.
Feb 13, 2013 | Grundig S350 AM/FM/SW Radio
Grundig s350, installed new batteries and radio keeps shutting off by itself
When you press the Power/Sleep button the radio turns on and displays a number 90, or some other numbers. This is the play time that the radio will stay on then turns itself off. It could be that yours is configured with a sleep timer set to 01 minute, 10 or 15. You need to set the timer for a longer period. Thus we turn it on by pressing the Power/Sleep button, read the timer length then press again. Keep making short presses: The timer will cycle through all preset sleep timer durations. Select the length you want.
Jun 19, 2011 | Grundig S350 AM/FM/SW Radio
How do I get the BBC on the Grundig S350?
You need to know the broadcast frequencies (or wavwlengths) and the times at which BBC is broadcasting towards you part of the world. With frequency in hand tune in to it at the time BBC is broadcasting towards your location. There is a book which is published annualy. The title of the book is World Radio Handbook or some such thing.
Jan 08, 2011 | Grundig S350 AM/FM/SW Radio
I purchase a Grundig S 350 and purchased the sangean Antenna-60, I don't know where the antenna attaches???
The Sangean ANT-60 comes with an adapter that lets you clamp onto the existing antenna on your S350. Using this adapter and the clip provided will be a good enough connection. The S350 does not come with an external antenna connection port for a 1/8" mini plug antenna so this necessitates the use of that adapter and clip.
Jun 08, 2010 | Grundig S350 AM/FM/SW Radio
Clock
Ask here:
http://manualfox.com/link/grundig.htm
they can get you every Grundig manual.
May 12, 2010 | Grundig S350 AM/FM/SW Radio
Dropped my portable grundig s350. Stopped working
Jan 24, 2010 | Grundig S350 AM/FM/SW Radio
Grundig S350 AM/FM/SW Radio Logo
47 people viewed this question
Top Grundig Audio Players & Recorders Experts
k24674
Greg Cann
Greg Cann
xxxxxx xxx
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
