Question about IBM X225 (86463bx) Server
UEFI PLATFORM INITIALIZATION - IBM X225 (86463bx) Server
Is there a way to get the 32 bit or 64 bit windows XP to install on a dell inspiron 6000 ?
as far as i can find out because windows xp does not exists anymore plus xp does not update anymore according to microsoft.
some new laptops will not allow windows xp to be put on..
if your laptop was xp to start with then it should work.
To specify the boot sequence.
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. ...
  2. Choose to enter BIOS setup. ...
  3. Use the arrow keys to select the BOOT tab. ...
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list..
  5. try and boot your disc this way if it still wont have it then your laptop may not allow it.
Nov 20, 2016 | Dell Computers & Internet
I need to replace the harddrive in a Acer Travelmate P453 laptop. The unit has InsydeH20 bios, and it will not recognize a new drive when installed internally. Acer support says can use only OE part
Hi
This is quite complicated. Firstly InsydeH2O is a UEFI system rather than the well known BIOS. The details can be found here:
UEFI BIOS for Mobile Desktop Embedded and Server Platforms InsydeH2O
and a fuller explanation can be found here:
Unified Extensible Firmware Interface
In particular, you may find that your original disk had a GPT or EFI partition which you may or may not have removed, as they don't show up in the usual way, and they are sometimes necessary for a disk to be bootable with a UEFI BIOS, but of course the disks you have tried won't have one. I would think that a detailed review of the Wikipedia page above might clarify things. With this sort of system I have had some degree of success (not always) with Maxblast 5 for Windows, which you could get from the Maxtor site (haven't tried recently). I put both disks, new and old, onto a separate computer with an existing boot drive, as subsidiary disks, either from the SATA connections on the motherboard (make sure you still boot from the original disk of the separate computer).
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 22, 2014 | Acer TravelMate P453-M...
How do I exit out of the uefi bio utility mode it keeps going back to the same screen when I exit
When it boots back to the uefi bios page there should be some settings tab/s that you can change the boot from uefi only to normal the only other things i can suggest if you dont want to go into those settings to far for whatever reason , when it boots into your bios from uefi mode press f10 or whatever the defualt settings button may be for your bios, make sure you save and exit then aoll should be fine , FAIL THE ABOVE , ITS TIME FOR A BIOS UPDATE !!
Dec 04, 2014 | ASUS Computers & Internet
Uefi platform initilization
This would probably a motherboard issue. Sometimes firmware updates(Uefi and IMM) can resolve issue.
Same message appear when server has memory faults also, so check memory has no amber.
You would have to for motherboard replacement when no memory issue found on server
Thanks
Dec 16, 2013 | IBM System x3400 M3 7379 Server tower 5U...
Can't boot from CD or USB drive even though they have set to 1st at the boot order!
Hi try to change the BIOS or UEFI settings. Change to Legacy if it is on UEFI and vise versa. See if this will work. If you are trying to reset it to factory defaults there is an OKR button usually beside the power button or on the side of the laptop. It looks like a small arrow pointing downwards. Press that, select One Key Recover or System Repair > restore from initial backup then follow the on screen instructions.
Sep 20, 2013 | Lenovo B590 6274 - 15.6" - Core i3 2328M -...
I'm having problems installing Ubuntu on Windows 8.
restart the computer HOLD the keys CTRL+F11 OR F12 depend of your model, and restore to the factory defaulty, and try it again.
God bless you
Jul 09, 2013 | Dell Latitude D531 Laptop Computer PC...
Is there a list of beep codes for UEFI?
I think you might be looking for this... http://www.clunk.org.uk/forums/hardware/39557-uefi-bios-error-post-codes.html, out of the 3 years I've been fixing PCs, i've never actually worked with a UEFI motherboard so I'm not sure wether each model is the same, hope this helps :)
Feb 24, 2013 | MSI Computers & Internet
IBM System x3400 M3 7379 not booting displays orange colour (!), hangs at EFI Initialization what might be the problem. Thanks in advance.
check the indicators on the right side of the front panel for more detail of the error. search online for the manual.
Nov 28, 2011 | IBM System x3400 M3 7379 Server tower 5U...
IBM X225 (86463bx) Server Logo
44 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
