USB Adapter WG602 v4 - Computers & Internet
Driver wireless adapter
Try www.driveridentifier.com.(helps me a lot!)
Jan 24, 2014 | TP-LINK TL-WN727N , 150Mbps Wireless Lite...
Hello, I have Netgear WG602 V4 access point. now I am facing a problem loging in the product which it will not allow me to get in . I tryed so many times by typing the IP ( 192.168.0.227) but without...
I believe you are using the wrong IP. Try 192.168.0.1 instead. The way you can confirm is go to start>run type in "ipconfig" and press enter. Look for your gateway ipaddress. This is most commonly the IP you need to use to login to the router.
Mar 28, 2011 | NetGear WG602 802.11g/b Wireless Access...
I have an old Power Mac G5 WITHOUT wireless capability. Just bought a Belkin F7D2101 Surf & Share Wireless USB Adapter. But I can't seem to find a driver for Mac. Is there a solution?
Belkin surf is not compatible with any versions of Mac osX...Take it back to stores...
The list of belkin adapters that supports MAC OSX are...
buy any of the following models...
f5d9050 v4
f5d6050 v2
f5d5055 v1 & v2
Feb 06, 2011 | Belkin Surf Share Wireless USB Adapters...
I just installed my new netgear router and i have the hardtime to get a username and password..what is the best way to fix this problem
Default settings will be as mentioned below....
IP address:
//192.168.1.1
Username: admin
Passsword: password
Thanks,
Satheesh
Jan 27, 2011 | Computers & Internet
Power light on - the rest off
It has happened to me on a couple of occassions. Call your Internet Service Provider, sometimes you lose the connection because of something on their end. If they are any good they will walk you thru some troubleshooting steps to verify if its on their end or yours and set you up an work ticket to fix. If you have any questions let me know. Pls rate this solution.
Apr 30, 2009 | NetGear WG602 802.11g/b Wireless Access...
Netgear DG834G V4 Website connection problems
Please try to use a difrent DNS service.
For example open DNS:
Primary: 208.67.222.222
Secundary: 208.67.220.220
Jan 14, 2009 | NetGear DG834G Router
Netgear wg602
The advertised power output of a NetGear WG602 is 16dbm, using an online converter, that would be 39.81 milliwatts.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 22, 2008 | NetGear WG602 802.11g/b Wireless Access...
Blue screen
this is a sign of a resource conflict on your computer, there is no actual issue ont he card or the computer, only a conflict or an incompatibility, the only way to get around this issue is to reinstall the card in another PCI slot in your computer or have the adapter replaced with another version or perhaps an wireless USB adapter of the same brand, like the WUSB54GS.
hope this helps, if you have other questions just let me know.
Aug 04, 2008 | Linksys (WMP54GS) 802.11g/b Wireless...
How to Configyre a wirless adapter
If this is a wireless adapter just install the driver, on the PC (the disk that came with the adapter) then plug it into the PC and connect to the wireless router.
Hope that helped.
Oct 18, 2007 | NetGear WG602 54Mbps Wireless G Access...
Computers & Internet Logo
David Payne
David Payne
