Question about Moultrie D-50 Digital Camera
Night photos are not visible on DGS-LX30IR - Moultrie D-50 Digital Camera
This unit was purchased over a year ago and they will not take it back. can it be shipped to Moultrie directly. Ray
Return it to the store you bought it from for a refund or a replacement, plus hopefully a voucher as compensation for your trouble.
Apr 15, 2016 | Moultrie MFH-DGS-100 Digital Camera
What is the purpose of the IR function?
IR means Infrared and is used to take pictures at night or in very dim light. If you are wanting to take pictures in low light or at night it needs to be turned on.
Sep 23, 2014 | Moultrie MFH-DGS-200 Digital Camera
Camera on and SD working - but not taking pictures
Check flash is not obscured by the case
Check AF is set to infinity or [set by range]
Ensure target is within AF zone...might be aiming too low in order for it to register movement.
Nov 22, 2013 | Moultrie MFH-DGS-200 Digital Camera
Game Watcher 100 won't take any photos at all
What size batteries go into moultrie camera model mfh-dgs-m80
Nov 14, 2013 | Moultrie MFH-DGS-200 Digital Camera
Need manual for moultrie lx30ir game spy camera
http://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&ved=0CFYQFjAD&url=http%3A%2F%2Fimages.ebsco.com%2Fpob%2Fmoultrie%2Fcatalog%2Flx-30ir-manual-english-web.pdf&ei=L1OWUpeBOJHroAT8uoDoBQ&usg=AFQjCNGjUoTkqHNBh4gzdHE-vfWaQ5WciA&sig2=PeXQyB31Lb7Y8VxpqBiU3w&bvm=bv.57155469,d.cGU
Sep 10, 2012 | Moultrie Feeders Lx30ir Game Spy Camera
I interconnect a D-Link DES-10160 with D-Link Gigabit Switch DGS-1024D network and my network becomes slow
connect only DGS -1024D to your network....it will be faster...
because DGS supports 10/100/1000 speed.... but DES supports only 10/100 speed...
connect DGS directly to your network and work with that... if you wish to extend the number of ports then connect the DES to one of the ports of DGS
and dont connect DGS to one of the ports of DES
May 10, 2010 | D-Link DES-1024D Express EtherNetwork...
Flash will not "fire".
The camera has a "motion detector". And is generally for taking pictures automatically whenever a "subject", such as wild game, come within the detector.
That flash is for taking pictures of subjects less than 12 ft away and not a darkened area beyond 12 ft.
If you are using it to automatically capture in the evening, then point the camera lower, like to the ground 12 ~ 20 feet away. It will shoot some nice, but somewhat grainy pictures!
If you are holding the camera to take pictures, it wasn't designed for that, but it will work for "close" shots.
Sep 25, 2009 | Moultrie MFH-DGS-200 Digital Camera
Night problems
have you tried it with the led flash mode
Sep 23, 2008 | Bushnell 11-9900 Camcorder
Dgs 100
If the pink & white pics are a small percentage of your photos you should probably just live with it. I have 6 cameras in operation for 2 yrs & they have about 10% like this. Great pics otherwise. Probably caused by the angle of the sun or reflection of the flash off a nearby object.
Don
Jan 18, 2008 | Moultrie MFH-DGS-100 Digital Camera
Moultrie D-50 Digital Camera Logo
23 people viewed this question
Top Moultrie Cameras Experts
Steve
AZBen
AZBen
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
