Question about GE Monogram® ZDIS15CBB
GE Icemaker has water flowing over evaporator plate, but no ice.
The icemaker suddenly stopped making ice. I opened it today and there was no ice in there, and it seemed very warm. I do clean it every few months with the nickel safe cleaner, and the coils are clean. Water is running over the plate, but it is not getting cold. Any ideas what may be causing this? Thank you.
  • GE Master
  • 4,654 Answers
Larry the parts for that machine are expensive so lets hope it is a start relay and overload. I need you to run the thing just enough to see if the compressor is getting hot on its top. Can you unplug the power and feel the top of the compressor for me? Warm, Hot? Too hot to keep hand there? I need to know about the compressor to see if it is trying to start. With the power disconnected I want you to examine both sides of the main control board=> WR55X10020 Main Control Board If you would like me to help you out here please let me know, Thanks John Tripp Appliance 911
You can try to contact me here on Fixya but I don't think they will let me know so=>
Contact Me Here
Posted on Feb 16, 2014
  • 11 more comments
  • Larry Tanner Feb 17, 2014
    John, thank you for helping out. The compressor felt fine, after running for an hour it felt cool. As for the control board, how do I get to it? When I tried to remove the top panel, I noticed there was a wire attached to it. How do I disconnect that?
  • John Tripp
    John Tripp Feb 18, 2014
    If you know that the compressor is running and either the evaporator plate is not cold or the condenser coil is not hot I would say you have a Freon leak. Most people sense that compressor is not running when in fact the fan vibrations are causing them to think that the compressor is running. Disconnect the fan wiring temporally to see if you still think the compressor fan is running? I won't be able to tell you how to get to everything so you may need someone that can provide you with a little help that has a electrical test meter and some shortcuts to getting inside the control panel. Sorry I don't have a machine here that I can simulate the problems you are running into. Some Techs seem to think that the Whirlpool ice maker is the same one that GE sells and because GE does not have a technical manuakl for theirs here is a SM for the Whirlpool below. http://appliance911seabreeze.com/15in_an...
  • John Tripp
    Lsrry if the compressor is running you will feel heat coming from the top of the compressor....JT
  • Larry Tanner Feb 18, 2014
    John, I found the manual on your site, and like you said in your first response, I have looked at both sides of the control board and it looks ok, but not sure what I am looking for. I guess to check the compressor I need to reassemble everything. I will do that.
    So, after putting everything back together and running it, the evaporating plate does not get cold, the condensor coil is not warm/hot. I have no idea if the compressor is running, but when I place my hand on top I do not feel any vibration or anything. Also, the compressor feels like room temperature. So, what is the next step? Finally, I would agree with those who say the Whirlpool and GE are the same. In fact, I have bought Whirlpool replacement parts because they are priced so much more reasonbly than the same GE part.
  • John Tripp
    John Tripp Feb 19, 2014
    I did not see your comment here again. I just checked to see if you said anything. Do you have a way to test voltage. Can you unplug and remove the start relay and overload and see if everything there along with testing voltage to compressor once you can safely check the wires with power plugged into the outlet. We need to know if 120 volts ac is being supplied to the compressor. Don't check with the capacitor being in the compressor circuit...JT
  • John Tripp
    John Tripp Feb 20, 2014
    Let me know what you find Larry. I am hoping you can gather some things to test with the Service Manual. Let me know if you have questions, Thanks JT
  • Larry Tanner Mar 04, 2014
    John, I've been out of town, and want to get back on this. Are you available this evening?
  • John Tripp
    John Tripp Mar 04, 2014
    Oh that is what happened to you? I'm here if you would like to ask me questions, John Tripp
  • Larry Tanner Mar 14, 2014
    John, apologies for the radio silence. I had to get a multimeter (borrowed from a friend) and have been busy with my regular job. The resistance for the compressor seemed normal, I got 9.6 and normal is supposed to be between 8 and 11. When I plugged the unit in and turned it on, the water pump started running and the lights came on, but I got no voltage reading for the compressor. Does that mean I need a new one? I guess I should get a professional now, since that will likely involve freon, correct?
    For future reference, I had a draft of the GE 2008 Technical Service Guide, and the KitchenAid 15" & 18" Technical Education job aid from you to help guide me. I believe the are in fact the same, and the KitchenAid guide is actually much better. Thank you for your help, John.
  • John Tripp
    John Tripp Mar 14, 2014
    No this does not sound like a sealed system problem and you don't need a new compressor. This tells me that there is a break in the circuit somewhere. Example would be a defective push button, on off switch or a bad relay on the main board. Is the condenser fan coming on? When you usually turn the ice maker on there is a sequence of events that should take place in order. Anything that is out of order in that sequence will stop ice production. If the ice bin thermistor is defective and tells the motherboard that the ice bin is full it will also shut down the compressor. Is ZDIS15CBB the correct model number found on the inside wall of the ice machine? Your ice maker also should have a self diagnostic feature as noted in the service manual. Have you tried that to see if something is out of order? I would have enjoyed being able to spot the problem with your ice maker but these machines have a somewhat complex sequence of events and will require a large amount of attention on what may be causing the compressor and condenser fan to not be running. You looked at the circuit board and did not see any signs of heat, burn marks or swollen tops on the capacitors? I will hang in there as long as you want to do this yourself. Tell me what you see in the flow charts and the diagnostics so we can see what may be happening, Thanks John Tripp
  • Larry Tanner Apr 27, 2014
    Just to close the loop on this, ended up replacing the entire icemaker. However, talked GE into replacing it for about one-half the cost of a new one. John, thank you for all your help.
4 Suggested Answers
watugot
  • 290 Answers
SOURCE: GE Icemaker flap door won't open causes ice jam in chute
There is an electric solenoid that opens the door. If you look up inside the dispenser you can see the solenoid. Either the solenoid is bad or the dispenser module that puts power to it is out. You will need to remove dispenser front and check for voltage to solenoid. If you have power from module, replace solenoid, if no power, replace both parts. It is common for solenoid to short out and damage the module so that both must be replaced. If solenoid is shorted and you replace module, new part will fry.
Posted on Oct 02, 2007
SOURCE: Our GE PSC25PSTA fridge drips water from the icemaker
I have this model also for just over 3 years and it developed the same problem. The issue turned out to be the unit was in defrost mode too long caused by a failing control circuit board (found in the back under a panel cover). The board controls all refrig functions. This was replaced and the unit works normally now. The board costs around $200 plus the service call ... still cheaper than a new refig.
Posted on Apr 29, 2010
mreid542
  • 166 Answers
SOURCE: GE Profile Icemaker freezing up; water freezes
This sounds like your water valve is not completely closing allowing water to drip and freeze. First check to make sure that the water tube going into the cup of the ice maker is lined up correctly and not causing this problem - if it is lined up correctly then replace the water valve on the back of the refrigerator that your main line is connected to.
Posted on Jul 01, 2010
How to trouble shoot GE ice maker that is not producing ice
Here is some information for you to study
  • GE Refrigerator - Ice Maker Not Making Ice - Easy Fix and ... www.youtube.com/watch?v=fPeZ29XdX5U
    • BY DIGITALPIMPLE
    • 4 MIN
    • 295K VIEWS
    • ADDED 2013-05-15
    Video embedded · How to fix your GE Refrigerator if it stops making ice. Easy quick Ice Maker fix if your ice tray suddenly stops filling. Check for this issue before going ...
  • How To Fix Refrigerator That's Not Making Ice ' Fridge Repair www.partselect.com/Repair/Refrigerator/Not-Making-Ice Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common ... can cause a refrigerator's ice maker to not ... GE Parts ...
  • Icemaker Not Producing Ice - products.geappliances.com products.geappliances.com/appliance/gea-support-search-content?... Icemaker Not Producing Ice. To minimize the possibility of electric shock, unplug this appliance from the power supply or turn the house circuit breaker/fuse to the ...
  • New Icemaker Not Producing Ice - GE Appliances products.geappliances.com/appliance/gea-support-search-content?... New Icemaker Not Producing Ice. If the refrigerator icemaker has just been installed, there are a few things that must happen before it can produce ice:
  • Jan 02, 2016 | GE Refrigerators
    Water leak on back wall of my freezer and a hell of noise from my icemaker when on
    Water leak and noise are due to wrong temp setting or malfunction of defrost cycking.Keep temp setting between 3 and 5 degree centigrade. Due to over frosting, the freezer fan fan hits over the ice and working to cool fridge compartment.And also check defrost timer, and heaterworking properly to defrost in time. And if your ice maker is making sound, due to:
    • You will hear a buzzing sound when the water valve opens to fill the water reservoir for each cycle.
    • Rattling noises may come from the flow of the refrigerant or water line. Items stored on top of the ice maker can also make noises.
    • The high-efficiency compressor may make a pulsating or high-pitched sound.
    • Water running over the evaporator plate may make a splashing sound.
    • Water running from the evaporator plate to the water reservoir may make a splashing sound.
    • As each cycle ends, you may hear a gurgling sound due to the refrigerant flowing in your ice maker.
    • You may hear air being forced over the condenser by the condenser fan.
    • During the harvest cycle, you may hear a "thud" when the ice sheet slides from the evaporator onto the cutter grid.
    • When you first start the ice maker, you may hear water running continuously. The ice maker is programmed to run a rinse cycle before it begins to make ice.
    Hope, it's helpful>
    Feb 05, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
    Having a problem with Kenmore refrigerator, model number 106.78862891, icemaker. The water going into the icemaker will not stop. It has a continuous stream of water. The icemaker makes ice when I MANUALLY...
    first checkthe inlet solinoid valve if has a continuity or when u energized valve it activate or produce magnet that open the valve and water enter may this solinoid is stuck up try to dismantle. or check or clean the water level sensor using sand paper or rating 1000
    Feb 01, 2011 | Kenmore Refrigerators
    I have a GE profile TFX26PPdaWW refrigertor which has stopped making ice. The bar is down, so the icemaker is on. Every once in a while the interior arm will turn to force ice out, but nothing comes...
    The place to start is at the fill tube going into icemaker...look into that and make sure its not frozen up with an ice plug. if it is, the inlet valve is bad..defrost the tube and this will give you temp service while looking for new valve..
    if no ice plug , then the fill valve is bad or your icemaker. if you have water and ice..its a dual valve..One side does water and the other does ice..the ice side could be bad, but you have to replace the whole assembly...I would take a ohm meter and ohm out the coil,or run a cheater cord to it and see if it opens.(this means run 110 volts directly to coil) if you get water inside to icemaker, more than likely the icemaker module is bad, but ,I would replace complete icemaker assembly
    Jan 23, 2011 | GE Refrigerators
    My U-Line CO2075FS ice maker seems to over fill and drip water into the ice cube storage drawer. How do I adjust the water flow or fill level limit?
    If your water is overfilling then you probably need a faceplate for your icemaker. If you remove the cover on your icemaker(pry on the corners and pull @ same time) You will see a screw with a spring on it. That adjust the water flow. If you tighten you decrease the water. Make sure the gears are not corrioded. If it is. Replace the plate with the gears on it.
    Oct 08, 2009 | U-Line Icemaker
    GE Icemaker stopped making ice. everything else
    Try these steps
    1. Check the shutoff arm
    2. Check the supply valve
    3. Inspect the water supply line
    4. Test the shutoff switch
    5. Check the freezer temperature
    6. Inspect the ejector gear
    7. Test the ejector motor
    8. Test the ice mold heater
    9. Test the holding switch
    10. Test the water inlet switch
    11. Test the thermostat
    12. Test the water inlet valve
    pls rate my suggestion.......
    Jul 25, 2009 | GE Monogram ZDI15C Automatic Icemaker
    Bosch Side by Side, top shelves dont freeze food, bottom does
    majority of refrigerators today are equipped with an automatic icemaker. The water valve supplying the icemaker is a key component of the icemaking system, and it should be the first thing you check if the icemaker's performance is erratic or if the icemaker stops working. When the icemaker calls for ice, its switch closes an electrical circuit and energizes the solenoid-operated water valve. This allows water to flow through the valve and into the ice cube tray. The water is frozen into cubes, and the cubes are dumped into the ice bin. As time passes, strange things may happen to the refrigerator's icemaking capability. The cubes may be small or there may be a solid chunk of ice instead of individual cubes. It's also possible that the icemaker will stop working. These are all signs of a malfunctioning water valve. The valve is equipped with a screen on its inlet to remove minerals and sediments in the water supply. Over time, minerals and sediment build up on the screen and restrict flow through the valve, or even block it completely. Minerals that make it through the screen can cause the valve to stick in the open position, overfilling the ice cube tray in the process. This is a common problem in areas with hard water, but it can happen just about anywhere. Another malfunction that will cause the icemaker to stop working is a break in the solenoid coil winding. This is known as an open coil. The coil winding generates a magnetic field as current passes through it, and this magnetic field opens the plunger valve that controls water flow. A break in the coil winding stops current flow and this prevents the valve from operating. Test And Inspect The icemaker's valve is easy to inspect and test. First, gently pull the refrigerator away from the wall, and unplug it. Turn off the water supply to the icemaker by closing the shut-off valve in the copper waterline leading to the valve (Fig. 1). Use a screwdriver or nutdriver to remove the rear lower access panel from the refrigerator's back. Next, remove the fill tubing from the water valve. Use a wrench to loosen the flare nut on the brass fitting on the inlet side of the valve (above). Place a container under the valve to catch the small amount of water that will spill from the valve and tubing. Now use a screwdriver or a nutdriver to remove the screw holding the valve's mounting bracket to the refrigerator cabinet (Fig. 2). Pull the valve out of the compartment and remove the tube on the valve's outlet. Then, remove the solenoid's electrical contacts (Fig. 3).
    Mar 29, 2009 | Bosch KGU66920 Side by Side Refrigerator
    No ice from icemaker
    Read the manual and see if the icemaker has a thermostat that prevents the admission of water into the tray if the freezer temp is too high. Also..make sure the ice level bar is down.
    Mar 09, 2009 | GE Monogram ZDI15C Automatic Icemaker
    Kenmore Side By Side Refrigrator ICe Make Not working
    Is the icemaker producing ice and it's just not coming through the door? Or is the icemaker not even producing ice???
    Mar 01, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
    GE Monogram® ZDIS15CBB Logo
    87 people viewed this question
    Top Refrigerators Experts
    Sal DeAngelo
    dweatherby
