Question about Jenn-Air Dishwashers
Jenn-air dishwasher Mod. # JDB3600AWS5- control panel stuck on Plate warmer" option, can't turn on or off
The touch panel with the various options is stuck on "plate warmer" option. It wont cancel, and cannot change to another option. It's blinking constantly. I turned off circuit breaker off, then on and did not reset- just blinks-won't cancel. help
mohammed387
  • 1952 Answers
SOURCE: Cancel Light Flashing on Kitchen Aid Dishwasher
I found this post elsewhere. It seems to have worked for me: Our KitchenAid KUDP series dishwasher went into a mode where it would not start and would only respond to the cancel/drain button. The clean light would flash 7 times in a row, stop, and then repeat. I read that the 7 flashes indicates an error code and that the dishwasher has detected a problem in the heater element circuit. I tried to reset the error mode by turning off power for 15 minutes, however, that did not work.
We called for a repair. The service person found that the dishwasher was completely fine except that it had gone into an error mode. The technician reset the error mode and charge us $115.00.
The reset sequence used was reported to be the following:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
We were told the dishwasher expects to see the dish water temperature rise in a certain way. If the water does not heat in this way, the dishwasher becomes confused and thinks the heater element has failed. In deed, this happened just following and extended power failure and our hot water tank was cool. I am curious if this code will work for anybody else with the same problem and save a service call and 115 bucks. Overall, this seems to be a serious logic flaw in the design.
Posted on Sep 21, 2008
SOURCE: problem with operating new dishwasher:
problem not solved. will contact the dealer.
Thank you.
mcrae891
Posted on Oct 12, 2008
  • 69 Answers
SOURCE: 3 sec light on control panel blinks .. dishwasher
go to maytag website they have all kinds of help there
Posted on Sep 20, 2009
joe_lishman
  • 192 Answers
SOURCE: GE Dishwasher no water upon start, humming, blinking lights
Seems like the anti flood is activated when water (even a small amount) appears on the bottom of the machiene. This is usualy a leaking pipe but can also be caused by a clogged pipe. Most machiens do have a plastic pipe that (from the flat water tank) feeds water to the bottom of the machiene in case of an internal fault. The anti flood is normaly a polystireen float with micro switch on the base of the washer. This automatically puts the outlet pump on to drain the water. The machiene does not work exept the outlet pump in this mode.
Posted on Jan 18, 2010
mc1bean
  • 3053 Answers
SOURCE: GE profile dishwasher tripped breaker.
Hello, jjesup
I was trying to help you out here. I am not sure if this well help you? But here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting on most common dishwashers. If you go to this link and click around, I am sure you will find out so much about your Dishwasher, you will know more that the company that made it.If you already solved the problem this is good for future problems. Here Is the link for you to click on.
http://home.howstuffworks.com/dishwasher.htm
Please if this helps you at all, and if you can find the time to rate my help and some kind words written would be appreciated for my free help. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks So Much, Mike :)
http://beta.fixya.com/users/mc1bean
Posted on Oct 27, 2011
I have a GE dishwasher model number GLDT696TSS. I does not turn on. No lights on the panel. Tried various outlets. Any suggestion?
The control panel is defective, it is about a $200-$300 (USD) repair, so weigh you options new or repair.
Jan 07, 2017 | GE Dishwashers
Jenn-air dishwasher will not start
it is usually the panel that fails
Apr 12, 2015 | Jenn-Air Dishwashers
Kenmore dishwasher model #665 15872000 is stuck on time saver option for washing and I can't get it to switch to any of the other options such as normal wash
Similar Kenmore Dishwasher 665.18664000. Time saver and Quick rinse were the only programs that would run. I pressed "high temp scrub" then "air dry" then "high temp scrub" then "air dry" and the machine went into a diagnostic mode and counted down from 10 while running a series of tests. After about 10 minutes and various test cycles the machine reset and the "normal wash" light had come back on. If this doesn't work then you may have a problem with the controller which other threads have mentioned replacing yourself for about $120.
Feb 11, 2012 | Dishwashers
Hi i have a jenn-air dishwasher JDB8910AWW about 10 yrs oldand started to have problems that it wouldn't drain now I can't get it to turn on..any advice??
I have a Jenn air dishwasher JDB8910AWW It fills with water but will not wash also i hear a clicking sound and the control panel blinks
Nov 18, 2009 | Jenn-Air 24 in. JDB8910 Built-in...
I ordered a front panel for a Jenn Air dishwasher. I received no instructions. I just paid for premium service and got disconnected. I am trying to get the answer. The email tells me just to sign in and...
You should try an easier site. Go to www.applianceart.com and they have a bunch of options for you to order and they are shipped right away. I think dishwasherpanels.com is them too.
Jul 04, 2009 | Jenn-Air 24 in. JDB1080AW Built-in...
Jennair dishwasher jdb1250aws not drying fully and compartment is still damp inside
There should be an led control panel, select menu and you should see an option there to enable your wi fi
Feb 28, 2009 | Jenn-Air 24 in. JDB1250AWS Stainless Steel...
Problem with operating new dishwasher:
Thank you.
mcrae891
Oct 12, 2008 | GE Dishwashers
Jenn air diswasher mod # JDB1100AWS
disassemble front door to get to the latch. Check if the latch is properly in place, sometimes the metal cylinder that hold it in place, slips out of position.
Jul 08, 2008 | Jenn-Air 24 in. JDB1100AWS Built-in...
Dishwashers Logo
179 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
