Question about Sony CPD G420 19" CRT Monitor
Matsui 1436xa TV
The picture on the screen is too wide. it has choped the RH side off.
How do I reduce the width and then centre the picture?
0 characters
1 Points
When I play dvds or watch videos on youtube the screen has a black border on both sides reducing the size of the screen
If you hit full screen on the youtube video and its not full screen, then it sounds like your monitor resolution is to low.
Rt click on a place on your screen and pick screen resolution, then pick resolution and increase it.
The first number is width, so say it's on 800x600 then go 1024x768
Apr 05, 2013 | ASUS Computer Monitors
My Acer 22" wide screen
change the resolution on the pc to 1024 x 1024 and then increase one size bigger each time till you find the correct one. Click start > control Panel > display settings then click settings change it in there (XP)
Apr 17, 2011 | Acer Computer Monitors
My samtron 55v monitor screen is becoming wide. after many times doing power switch on and off the screen is adjusted. what is the cause?
hit your MONITOR lightly on left side or right side or on top & then observe will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some monitors on main board at some soldering joints crack develops....then due to loose contact picture becomes small in size or abnormal width,etc ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some solution is ......monitor main board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting monitor lightly if there is no response then main board has to be checked your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again ................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other contact good monitor service engineer .............iam from bangalore - 09986222774 - ( computers, laptop, printers, etc )
Jan 29, 2011 | SAMTRON 55V 15" CRT Monitor
Suddenly, I can see only a part of the display width. I can't control the width size in the screen setup (all the other functions are OK)
see that it may be from the resolutions..if you give it a smaller one ..and it is a wide screen format will hae black 2 inches wide band on each side... just right click on desktop properties and settings ..and restore a normal resolution on it ..
Apr 25, 2010 | Hyundai ImageQuest ImageQuest Q770 17" CRT...
Have black area on right side of screen and can't get full screen
What video-card does your computer have?
Some older video-cards do not support "wide-screen" monitors.
Thus, they only "paint" 80% of the width of the screen.
Oct 09, 2009 | Acer X203W 20" LCD Monitor
The the width of the picture on my Monitor is reduced.
you may click the right button of your mouse and go to the properties.From there you can adjust the screen resolution.
Jul 01, 2009 | Computer Monitors
Picture is too wide
please check the width section transistor and while it is good condition please check the power diode in width section near to lot and replace the fly back capacitor that range is high volt its situated near to lot.
Feb 05, 2009 | SAMTRON 55V 15" CRT Monitor
Lg flatron 775ft screen size problem
Hi Edit123,
U can chane output width and height from buttons given on LCD panel manually
Sep 19, 2008 | LG Flatron L1750S 17" LCD Monitor
Acer 19167W flat screen
Depending on the application you are viewing the picture in you can shrink the application window. You could reduce the size of the viewable area but that defeats the purpose of the wide screen which is to provide a better viewing experience (to quote the marketing types). It sounds like....since the wider screen really has nothing to do with your picture might want to adjust your picture size independent of screens and applications. There are a variety of free products out there that can do this...and some are really nifty...perhaps better than the software you might now be using.
Aug 02, 2007 | Acer AL1916W 19" LCD Monitor
Sony CPD G420 19" CRT Monitor Logo
74 people viewed this question
Top Sony Computer Monitors Experts
Lala Alonsi
Lala Alonsi
ray gallant
Are you a Sony Computer Monitor Expert? Answer questions, earn points and help others
