Question about Epson EX7200 Projector
If I am ceiling mounting my epson ex7200 projector how far from the wall is best
projdoc
  • 2236 Answers
SOURCE: I have an Epson projector on the ceiling of my
go into the menu and select the speakers. if you have external speakers connected, select external. if not, selct the internal.
Posted on Sep 03, 2009
fosg2000
  • 229 Answers
SOURCE: Epson 77c Projectors occasionally freeze - controls don't work
this is maybe overheating problem, check that the fan on it is working
Fosg2000, please Rate me
Posted on Mar 16, 2010
  • 59 Answers
SOURCE: How do I flip the
Press MENU on the remote control (as show on picture below)
the menu window displayed
Press down arrow key to select ADVANCED
press ENTER on the remote control
use down arrow key to select ceiling (as show in picture)
press RIGHT arrow key to select OFF to ON status
press MENU key to exit menu
(the projected images are horizontally and vertically reversed.)
Posted on Feb 14, 2011
heathgr
  • 442 Answers
SOURCE: Wanting to mount this projector
get the epson parts
ceiling mount ELPMB35
ceiling mount adapter ELPMBAPS
Posted on Feb 25, 2011
astig1977
  • 88 Answers
SOURCE: My Epson EX7200 was purchased May 3rd and until
I would recommend contacting Epson support. Your projector should have a 1-yr manufacture warranty, and they can verify that once you give them the serial number of the projector. In the meantime check your computer cable (if that's the input you're using) for bent pins. You can also apply the "Reset All" option, which restore all the settings back to factory default. However, in some cases the blue LCD panel might have gone out also.
Posted on Jun 21, 2011
Red temp light went on...what does that mean?
Your projector is overheating. Check to see if the filters and vents are clogged with dust. Epson recommends cleaning filters and vents after every 100 hours of use.
Sep 23, 2014 | Epson EX7200 Projector
Epson ex7200 yellow picture
all three RGB light not work together.
Nov 25, 2013 | Epson EX7200 Projector
My Epson EX7200 was purchased May 3rd and until recently has been working well. Now the projection has a blue tint to it
Jun 21, 2011 | Epson EX7200 Projector
Upside down picture
turn the projector up the other way,
or
Press the Menu button.
Select the Advanced menu. You see the features and their settings on the right side:
Press Enter and use the directional buttons and the Enter button to set the following option:
Projection
Front: Projector is in front of the screen
Front/Ceiling: Projector is in front of the screen, mounted upside-down from the ceiling
Rear: Projector is behind the screen
Rear/Ceiling: Projector is behind the screen, mounted upside-down from the ceiling
Feb 22, 2011 | Epson EMP-54 Multimedia Projector
Wanting to mount this projector from ceiling. How and what bracket should i use.
get the epson parts
Feb 22, 2011 | Epson PowerLite 50c Multimedia Projector
Can the Optoma EP739 be ceiling mounted and projected upside down? what are the steps to do so? also, what would be the best mount for said projector?
Mine has been in place for about three years. Because the ceiling was open I was able to create a connection for a tripod head on the ceiling and then using a STRONG tripod head and some small bolts (longer than the originals) I mounted an external base and with the tripod head fitting dttached to the projector it just became a matter of running the various connector cables from the sources I use that require projection to my wall.
Dec 02, 2010 | Optoma EP739 Multimedia Projector
My projectors image is upside down. how do i fix
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
Apr 11, 2010 | Epson EX30 LCD Projector
How can i flip the screen up side down on the projecter
Or you can hold down the [A/V Mute] button for about 5 seconds to change the projection setup from Front to Front/ceiling or Rear to Rear/Ceiling.
Mar 31, 2010 | Epson EMP-S4 LCD Projector
How to mount using a universal ceiling mount
first, find out the distance range on your projector for the best fitting image on your wall. next, what type of ceiling? if it's a drop ceiling, use a plate to span the 2 feet between braces and clamp it to them. and it's always safe to attach a safety cable from the mount to something sturdy, like wood or heavier metal. if you are putting it on a drywall ceiling, find a stud to screw it in to. do not use drywall anchors to hold it. if you can get above the drywall, use a backer board (2x4 or plywood, 1/2" or thicker) and screw the mount through the drywall into that. the other end of the mount screw into the bottom of the projector (3 or 4 m4 holes should be already on the bottom of the projector. use the screws provided. you'll have to adjust the mount so it matches the projector holes. once it's mounted, you'll have to adjust the image. go into the menu and select ceiling image, and adjust the keystone. pop in a movie and enjoy!
Dec 22, 2009 | Acer P3250 DLP Projector
Epson EX7200 Projector Logo
15 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
